The tire situation
Discussion in 'Prius c Technical Discussion' started by zen_, Mar 7, 2018.
  1. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    Hellow, new (to me) Prius C owner here!
    Really liking the car so far, but I'm not liking the Goodyear Assurance Fuel Max tires that came on my car at all, and they are approaching 4/32" where I replace tires anyway.
    Options seem pretty limited in the 175/65R15 size though. I am wondering if I'll have any trouble running 185/65R15 tires where some better options like Pirelli P4 Plus, Continental TrueContact, and Michelin Defenders are available? I know most owners run LRR tires for max fuel economy, but I would much prefer any of those tires over a tiny MPG gain. All those tires do also have rolling resistance improvement...just not sure if it's quite as good as Fuel Max or Energy Savers.
  2. pcdriver14
    pcdriver14 New Member
    2014 Prius c
    I too was not a fan of the fuelmax. Their ice/snow traction was particularly bad when the treadwear was at 6/32". I looked at tirerack on the web for a grand touring tire and ended up with Uniroyal Tigerpaw All Season Grand Touring tires. It is Michelin's value brand. So far they have been great and I do a lot of winter driving. I did not use a larger size, but to answer your other question about mpg. I did not notice that much of a change; maybe 1 mpg, but I don't have enough data to back that up yet. I drive this car on the highway a lot and often have the 5 minute trend histogram on the display. I routinely get 50 mpg ( real time; about 43 avg right now in winter) no matter the tires used. While the tread helps somewhat, from observation, it doesn't seem to matter as much as tire inflation, tire size, outside air temperature, and driving style.
    It is best to closely monitor your tire pressure with these cars because I have noticed a difference in driving behavior/mpg when they are just a few psi low due to a large overnight temperature swing, etc. Also, the Toyota dealer told me that fuelmax tires have a harder compound which makes them less effective in winter conditions. Not sure how accurate that is, or if it varies from brand to brand. Hope this helps!
  3. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    Ended up sticking with the OE 175/65R15 size because Sam's Club would only install the OE size, and I wasn't aware that increasing the width with the same profile will still alter the rotations per mile slightly (speedo accuracy). As such, I went with General AltiMax RT43 tires, which are performing very well. The OE FuelMax tires with 5/32" tread still left were loud, rode poorly, were borderline scary in rain, and were always skidding on loose bits making tight turns at full lock.
    The AltiMax tires are a huge improvement in every department, and it would seem cost very little in MPG (1 or 2 in city driving). Only downside I have observed so far is that they seem to tramline more at highway speeds on poor roads, but it's hard to tell since this car is squirmy to begin with at anything over 60 MPH, or if the wind is blowing...at all.
  4. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    I went up to the 185/65R/15 from the original equipment. I also had done the same on my old Yaris. Because the tire is larger, there is a 2% difference in tread circumference. 2% less miles on the odo.
  5. JCW3
    JCW3 Junior Member
    VA
    I had 195/65 Hankook on our 13' PriusC and those was the best tires. Went great in snow or dry weather. Excellent tire life and very quite. The only issue I noticed was if a large gravel/stone ever got stuck in the tread, you could hear it. Same goes for snow. Even with a heavy load, I never noticed the tires scrubbing or any issues. I found the Hankook tires got much better gas mileage than the replacement.
    Last fall I replaced the tires on my PriusC with Costco Michelin tires in 185/65 size. I am not dis-satisfied with the tires, but they are not as nice as the Hankooks. The Costco Michelin tires are MUCH louder and seem to have a more stiff ride. Being a smaller diameter and closer to the factory size, I thought I would see a increase in mileage, but I actually saw a decrease.
    I would not fear going with a larger tire. I feel the 195/65 looks the best, but 185/65 does look decent.
  6. rjdriver
    rjdriver Active Member
    410
    170
    Rhode Island
    I have been riding on the General Alti max RT43s for over a year and like them a lot. Haven't noticed any loss in MPG, and they do very well in snow for an All Season. The only downside I have noticed is they do not stick as well in rainy weather. But that is a minor fault easily made up for by their unusually good snow performance.
  7. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I dont think this is true. Only increase/ decrease in circumference effects the speedometer.
  8. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    The width with absolutely change the height if the "profile" isn't changed. The "profile" is actually the aspect ratio.
    Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
    175/65-15 4.5in 12.0in 24.0in 75.3in 842 0.0%
    185/65-15 4.7in 12.2in 24.5in 76.9in 824 2.1%
    205/50-16 4.0in 12.0in 24.1in 75.6in 838 0.5%
    taken from Tire size calculator
    That's also how I decided on a 205/50 when I went 16's rather than the 195/50.
  9. roadrunner
    61
    36
    2015 Prius c
    So going up one size will show a 2.1% decrease in miles on the odo. This will make it appear that you are getting less mpg, when you are not getting less. I ride on 185/65-15s, and did on my Yaris for 10 years. What I have found was the larger tires were actually cheaper to purchase.
  10. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Which Brand/type tire did you choose at 185/65/15 ? I have ecopia 422 plus' at the moment 175/65/15's. They need to be replaced since all 4 are now down to 4/32 tread. I wouldn't mind switching to a 185/65/15 size tire. Just couldn't find a decent tire in my minimal time of searching.
  11. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    I got General AltiMax RT43 tires in the OE size because they were rated as good all-around tires, and only cost $300 mounted, balanced, and taxed after the $50 rebate.
    Probably the best tire outright in the larger 185/75R15 size in the Michelin Premier, but they are expensive. I also had great luck with Pirelli P4 Plus tires on another vehicle, but they are hard to find, and might perform much differently on this vehicle.
  12. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Also, Out of curiosity, what's the MPG you average? The Michelin Premier aren't that much more than the Ecopia 422 plus I am looking at. About 18 - 20 more per tire, so at most $80 dollars more.
    I wanted a quiet and comfortable tire, and if it helps with handling that's an added bonus. Not sure If going with a non-LRR tire, will it ride louder?
  13. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    I'm still getting 48-52 MPG in pure city driving depending on A/C use and ambient temperatures (temps varied wildly in my first month of ownership). Literally no worse than the Goodyear Fuel Max tires I rode on the first two weeks, and I don't really try to hypermile.
    True LRR tires usually do have some sacrifice in comfort and traction too.
    Mo G likes this.
  14. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Thanks for the info.
  15. roadrunner
    61
    36
    2015 Prius c
    I went with the Goodyear Assur Fuel Max @ $72./ tire, plus install cost @ $19./ tire. I am very happy with them.[/QUOTE]
  16. BlueSoap
    BlueSoap Junior Member
    39
    Singapore
    2015 Aqua
    Using a 17inch conti premium contact sport 6 and loving it. I didn't even skid when I jam braked on a wet road once.
