The ultimate accessory, built in Pizza Carrier!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sshaw10, Jul 15, 2013.
  1. sshaw10
    sshaw10 Member
    103
    West Los Angeles
    USE AT YOUR OWN RISK! RESULTS WILL VARY! I'M NOT RESPONSIBLE FOR HOT CHEESE IN YOUR LAP!
    Transporting a pizza is difficult when you're driving alone. A fresh pie is fragile, if kept at an angle the precious cheese and toppings will congregate at one side leaving half the pizza naked. In extreme cases a gooey pool can form inside the box and at that point the patient is dead. One day I got in my Prius and set a pizza on that mini desk of a dashboard and then noticed that the corner of the box fit neatly into the slot there. I've never looked back. Small, medium, large, think crust, thin crust, Chicago, they all fit because just about every pizza box is the same thickness. The attached picture illustrates the principle and despite the skew in the photo the box there is pretty level. It takes a quick moment to position the box just right and I find that some sort of angle gives me the best chance of getting it sitting pretty. With a little practice you too might be able to make use of this unknown, secret, clever design element.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    That looks like a disaster waiting to happen.
    What's wrong with the floor of the passenger area ( if available) ?
    I've even placed a pizza in the rear hatch area. Level, flat, safe.
    I think there are many other options.
    Wedging it in the dashboard?
    Think I'm going to pass on this hint.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    The floor of the passenger area if no passenger.
    The Prius Horizontal Net in the hatch area.
    Dine in.
  4. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    maybe put it behind the rear seat.............. or eat it quick
  5. bathala
    bathala Member
    128
    30
    Area 52
    I use a cargo net that hooks on the 4 corners of the trunk then put the pizza box under it.
    JMD likes this.
