The Volt: GM is, slowly but surely, screwing it up...
Discussion in 'Chevrolet Volt' started by efusco, Apr 18, 2008.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I just want to add a note that in Volt, combustion engine and electric motor does not have synergy. They are mutually exclusive because Volt use the ICE when the battery pack is run down.
    There are tasks that combustion engine do better than the electric motor w/ battery and vice versa. Heating cabin is something the combustion engine clearly do better than the battery pack! Use the ICE to heat up the cabin! Charge the battery if there are excess energy. Hybrid 101 man!
    I can give Volt's powertrain this name: Dual Engine Asynergy Drive
  2. Tideland Prius
    16,549
    I was under the impression Li-Ion was denser to the point that it's a LOT more powerful than the NiMH hybrid of the same size. I guess given that density = m/v and v stays the same, then m has to increase because rho increased. Is that why it's 400lbs?
    or do you have a better explanation? How heavy were the EV1 NiMH batteries?
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Prius' NiMH pack has 1.31 kWh of energy and weights 99 lbs.
    Volt has 16 kWh Lithium pack that is expected to weight about 400 lbs. That is more than 12x energy but it only weights 4x more.
    You can say Volt' pack has 3x more energy for the same weight as Prius' pack. Even with that Lithium advantage, a lot of compromises has to be made to run the car for 30 miles in real world with creature comfort.
    That's why Toyota has been saying we need a break-thru in battery technology. Toyota has li-ion tech that double the energy compare to a typical li-ion. The price also has to come down as well to become suitable for mass market.
  4. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Another point that was pointedly pointed out to me was that the ICE requires a fuel source which will be sitting in some tank for some length of time. The hope that the Volt with a 40 mi range will eliminate the need for petro-fuel is very pie in the sky. The fuel would soon go stale and gum up the ICE if it was never used.
    Thus this counter-efficient situation will likely have to occur. The driver will have to find a route or trip which is longer than 40 miles...significantly longer.... in order to deplete the fuel in the tank so that it can be replaced with fresh fuel.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    The Prius has a battery only range of 2 miles or maybe 5 miles if you put a quails egg on the accelerator and the Volt is aiming for a electric only range of 30 miles or there abouts so how small did you expect the battery pack to be?
  6. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    Couldn't one just put a product like Sta-Bil in the tank. It should allow the fuel to last for 12 months. Replacing the fuel once a year is no worse than changing the oil every 6 months.
    But heck, if you're the type that hasn't used any gasoline in 2-3 months, it might be best to drain the tank and only put fuel in for longer trips. ;)
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    *yawn*... it almost seems like everyone here is surprised that gm isnt putting up what they promised. when the volt was announced, about 90% immediately dismissed it as complete hype or total BS.
    the other 10% expressed cautious optimism. iow... no one really believed the volt would happen... so what has changed to make anyone think differently?
    to be honest with ya. i was in the "10%" crowd and i still am. a 4 seater would be a bummer, but i would still be happy with it. i could make do if everything else was as advertised.
    but couple that with a $40,000 price tag, dropping stats, gm's legendary ability to take a good thing and destroy it and to be honest with ya...
    i'm still in the "10%" category... but i am not (and didnt) hold my breath for anything that has to do with gm.
  8. rpiereck
    rpiereck Regenerator
    289
    I was in Japan recently and I saw a Toyota Estima Hybrid, which is a full size minivan, same size as a Previa, so Toyota does make Hybrid minivans, they just need to bring it to the US...
    Toyota Estima Hybrid 2008 new model in Japan
  9. hill
    8,794
    Most recent screw up:
    They're hinting that the limited first run may require them to only lease them . . . at least in the beginning . . . de ja vu
  10. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    If the terms of the lease require the car to be returned (no purchase option), then guess what? It is the EV2!
  11. fan-atic
    fan-atic New Member
    59
    Holliston, MA
    The battery on the Prius weighs 117 lbs. I think it holds 1.3kwh. The Volt battery was supposed to be 16kwh and weight less than 400 lbs. However, the only contract GM has signed so far is with a Japanese supplier. If you do the math, it has to weigh at least 700lbs (before armoring) to get the 16kwh.
  12. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    If I'm not mistaken, that exceeds the Prius hauling capacity: something like 650 pounds. :eek:
  13. daniel
    14,487
    1,519
    Spokane, WA
    The Prius battery is NiMH. The battery for the mythical Volt is supposed to be lithium. Lithium has a much greater energy-to-weight ratio.
    There's no problem with the Volt battery except that it doesn't have a car to go into. The EV-1 went 120 miles on a charge and the Tesla Roadster goes 245.
  14. Jimmie84
    Jimmie84 New Member
    1,074
    77
    Minnesnowta
    You do have to step back and take a look at what GM is doing. Hopefully this car will bring them many rewards in the future. If gas keeps going up at the rate it does people will be buying these types of vehicles left and right.
    But, Heres the kicker. The vehicles of the future will soon be here. Most electric vehicles that will require an overnight charge. Now electricity will be in high demand.
    Does it matter what we do? It seems were screwed in the long run.
  15. darelldd
    6,059
    389
    Northern CA
    The NIMH EV1 went better than 120 miles. I could go well over 100 miles in the lead car. I only drove a NiMH car for four days, and my best was 165 miles on a charge. My best in the lead car was 113. These were real-live freeway miles, not back-road hypermiles.
    While I understand the frustration with the Volt (and it doesn't surprise me a bit to hear of the proposed changes to spec) I don't understand the concern of a 400 pound battery. If you want to drive highway speeds for 40 miles, you need a bunch of battery. The complaint should be with the several hundreds of pounds of ICE and fuel system! We just take that for granted as being needed, and complain about the battery for the EV side? I don't get it. My Rav has 1100 pounds of NIMH batteries in it that allow me to go about 100 miles on a charge. Yes, Li-Ion is more energy dense - but it also will require liquid cooling and all kinds of pumps, plumbing and radiators. 400 pounds sounds reasonable to me! Let's leave the weight of the batteries and try to take the weight off the passengers. :)
  16. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Just for the record, according to the DOE the 2004 Prius Payload capacity is 905 lbs. Not stellar, but about typical for a small to mid-sized car these days.
    Rob
  17. Sitting Duc
    Sitting Duc Feathered Member
    61
    Hamilton, New Zealand
    So, GM has noticed the "real world" and started to make some engineering compromises...
    These will make the car less popular...
    Which gives GM an excuse when they don't sell as many as expected...
    So GM can start the recall even earlier, all the while protesting that "People just don't want Electric Cars".
    Deja Vu * 2
    I for one would love a purely electric car for my all-of 7 miles round-trip daily commute; not that the Volt will ever make it this far south and since this isn't the Pancake forum, I can't say what I think of the electricity supply down here anyways. :rolleyes:
  18. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    I don't believe that we're all that surprised. Perhaps disappointed but not surprised. It's what GM gets for reacting to being caught with their pants down after they pooh-poohed the Prius and dealing with it by making up a really cool design first before bothering to find out if the insides would work. Did Toyota come up with the Prius exterior and have the designers make a hybrid system fit inside of it? Of course not. It's part of the overall reason why GM loses market share every year and blames it on everything and everyone but themselves. They don't need new cars, they need to change their way of thinking and that's about as likely as the Volt coming to market as promised.
  19. Tideland Prius
    16,549
    Well we know how much power is needed to criuse on the highway so I would think that'll extend the charge range too.
    Good point on that (esp. with the hybrid haters complaining about x lbs of extra weight)
  20. darelldd
    6,059
    389
    Northern CA
    In the biking crowd I hang with, people fret over accessories that add grams to their rides. My standard response is: Have a salad for lunch and save even more weight than the expensive Ti widget that you're lusting after.
