1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
The white wire that clips under last Module is separated from clip.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BrokenWrench, Sep 20, 2021.
  1. BrokenWrench
    BrokenWrench Junior Member
    55
    Tampa, FL
    The white wire that clips under last Module is separated from clip. Is this an issue or can I just attach it to the clip any way possible. (I don't know if it's supposed to make a connection to the other wire.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    5,737
    5,570
    Columbia, SC
    Yes, that's a problem. That is one of three thermistors that the ecu uses to sense battery module temperatures.
  3. BrokenWrench
    55
    Tampa, FL
    Does anyone know what the solution is?
    Thanks in advance
  4. TMR-JWAP
    5,737
    5,570
    Columbia, SC
    Raytheeagle and SFO like this.
  5. BrokenWrench
    55
    Tampa, FL
    Thanks for the info and link. I did order the amazon sensor.
    #5 BrokenWrench, Sep 20, 2021
Loading...
