The word, "PROBLEM" displayed
Discussion in 'Gen 2 Prius Main Forum' started by MrK(2), Apr 25, 2016.
  1. MrK(2)
    MrK(2) Junior Member
    38
    southern Illinois, near St. Louis
    Yesterday, my display beeped and the word, "PROBLEM" was displayed. There was no explanation as to what the PROBLEM might be, and the word went away after a few seconds. A short while later, this happened again, and this time, the Red Triangle of Death came on, but only for a few seconds. I decided to take the car home.
    This morning, I hooked up TechStream to the Prius, and could find absolutely nothing abnormal. No codes were displayed, and everything looked to be in order. I especially looked at the HV battery, but all cells were within spec. (all within 0.7 volts and .001 ohms of each other).
    I've owned this Prius since it was new (10 years ago), and it has 167,000 miles on it. I did have the HV battery replaced about 2½ years ago, but again, the battery is fine. So is the 12- volt battery.
    Has anyone experienced this PROBLEM before? What does it mean??
    Dale
  2. JC91006
    16,463
    8,377
    probably means you have no oil in your engine
    Mavi likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Like JC said, check the oil level in the ICE.
  4. MrK(2)
    38
    Wow, I think you guys hit the nail on the head! I checked, and the oil was just touching the stick. Shame on me for not keeping a better eye on it.
    Since there was no message other than 'PROBLEM', how did you know it was the oil level?
  5. JC91006
    16,463
    8,377
    The intermittent problem usually is oil pressure going up and down into the danger zone and back again
    SM-N900P ?
  6. dorunron
    3,318
    1,103
    Houston, TX
    It's the nature of the beast. Keep an eye on your oil level. You don't want to burn up the engine. Best of luck to you!
  7. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Sometimes that can display of you are in gear with a door open or a misadjusted door switch. Did it come up with a PS or Bat box on the MFdisplay?
    XT1585 ?
  8. MrK(2)
    38
    I didn't see anything light up, just the word, PROBLEM. Since the PROBLEM message disappeared within a few seconds, something else could have been on and my wife and I simply didn't see it. I really don't think anything else was lit though.
    I changed oil and filter today. I don't think I drained much more than a quart of old oil out of the engine. I've driven the car for about 50 miles, with no recurrence of the 'problem', so I'm going to assume it was "lack of oil" related.
  9. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Uh oh. Nothing like putting thousands of miles on your engine in a few seconds...
    XT1585 ?
