There was something to the BT Plate after all!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by windstrings, Feb 13, 2009.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    I guess I am the exception. I have one installed, I have driven it for a year and a half, I read all umpteen pages of the thread, and I am still unconvinced that it does anything.
    Skeptically yours,
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Some ideas where I could agree.
    1. Do you feel your an aggressive driver?... or a "take it easy" driver?
    2. Also, do you live anywhere where there are strong cross winds as in crossing bridges?
    3. Are your roads pretty much straight with the exception of cross roads where you are forced to slow down anyway before encountering them due to stop signs and/or red lights?
    4. Is your area Mountainous or hilly causing many roads to have dips at the bottom of long high speed hills and/or turns at the bottom of those hills as they negotiate down the mountain?
    The brace is appreciated most by those who are either aggressive drivers or live in areas where negotiating turns and steep hills etc are regular occurrences.
    Many hard core Prius drivers have trained themselves to be very gracious so as to improve gas mileage while with some other folks, its simply not their style to want to drive aggressive.
    Doc,... it looks like you pretty much do most of your driving in outer-space so you don't qualify! :)
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Remember that the buyers are essentially a self-selected group. The expectations of the buyers and their perceived need makes this anything but a scientific study.
    Non buyers, on the other hand, are not involved and therefor have no first hand knowledge. All non buyers can do is analyze the mechanics of the brace and mounting, which, incidentally, points to the brace doing little more than the original member.
    The best way to scientifically answer this question is to do stress analysis on the original brace and the replacement brace. Strain gauges would answer all questions very quickly.
    Alternately you could do a double blind study. This wouldn't get at the casual effects of the brace, but would at least eliminate the major sources of subjective error.
    Lacking either of these, we might as well argue about how many angels can dance on the head of a pin. Of course it all becomes history with the 2010.
    Tom
  4. windstrings
    6,280
    378
    Central Texas
    Agreed, for future models, its a non issue.
    No one that we know of has ever seemed to figure out a way to develop a fullproof way of physically testing. Maybe Toyota did?
    Otherwise, did they do it just to appease the few of us that think there was a deficit there?
    Thats a very costly appeasement... so I think not.
    Seems there are too many variables that aren't worth the effort for such a test when Brians plate cost so little in the first place.
    Brian has expressed the cost to do such a foolproof test would be astronomical and even then.. people would not believe due to issues of credibility and bias being questioned, not to mention picking apart the lab variables of temperature, humidity, road surface issues, etc etc.. "as already hashed many times in previous threads".
    Barring it being fact or illusion... Toyota and their engineers has thought it best to appease us by putting some seriously beefy braces underneath "where the normal driver never sees", to make us feel better if nothing else.
    I'm just saying I tend to doubt the issue was ever infamous enough for the cost on Toyotas part to ever be justified from the few of us that just "feels better" knowing its there.
    Toyota paid the price to fix the issue... whether it was an illusion or not, Toyota still paid a pretty penny to address the issue... I tend to think it was for a legitimate reason, whether some of us could appreciate it or not.
    Get this!..... if Toyota is so broken up about the weight of LED light assembly verses Halogen in combination with the solar sunroof... I doubt they would have added the extra weight of those two bars without due justification!
  5. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    My favorite fool-proof test involved the tester's wife jumping up and down in the front seat ... that was good for about 50 - 100 posts in the stiffening plate thread. ;)
  6. qbee42
    18,058
    3,082
    Northern Michigan
    If it was as simple as replacing the plate with a sturdier one, Toyota could have done that for a lot less money. Instead they redesigned the entire back end of the car, featuring a much stiffer system.
    My contention all along was that the OEM plate is only loaded in tension. It is already plenty strong for that application. The mounting bracket and spacing of the mounts fails to allow for much torsional resistance. Using a stiffer plate to resist torsional loading doesn't help if it can't transfer loads from the chassis.
    When this subject comes up, people get the causes and effects all mixed up into some sort of froth. For example, when one of us states that the replacement brace does little to help, it does not necessarily follow that we also find the rear of the Prius sufficiently stiff. The two assertions are not logically linked.
    Likewise, demonstrating that the replacement brace is stronger than the OEM brace does not necessarily prove that using the replacement brace stiffens the rear end of the car.
    It is probably fair to assume that Toyota felt that the back end of the Prius could be improved with further stiffening, and it is very obvious that the new system is much stiffer.
    Tom
  7. QuiGonJohn
    QuiGonJohn Junior Member
    79
    Davie, FL
    Well I installed mine on 2/13/09, just before driving to Tampa for the weekend. I had owned my Prius for almost 2 months prior. It seemed to help a little with wandering & winds.
  8. windstrings
    6,280
    378
    Central Texas
    I'm excited at the prospect of how well the new braces will work....
    I agree that movements "inward and outward" would be the same with either plate "stock verses BT" but I think the flex is the matter that the BT plate helped correct.
    One side of the car could flex upward while the other went downward, whereas the plate help keep them together helping to eliminate that swishy feel in the back.
    Since the plate is only as good as whats its mounted to... I'm excited about the new bars as they run from one complete side of the chassis to the other.
    A correction that would have been much more expensive than what the BT plate did alone.
  9. BT Tech
    BT Tech New Member
    885
    South Florida
    My favorite fool-proof test involved the tester's wife jumping up and down in the front seat ... that was good for about 50 - 100 posts in the stiffening plate thread. [​IMG]
    __________________
    Best regards, Tom
    I must agree..... That was a funny one!! :) :)
  10. patsparks
    10,664
    569
    Adelaide South Australia
    I don't think the 2004 to 2009 Prius is really going the vaporise Tom, I think they will be around for a few years yet.
  11. windstrings
    6,280
    378
    Central Texas
    Pat, you should have some real roads to test where you live based on the pics I saw!...
    But I don' think the prius can negotiate 2 feet deep of mud, but I'm sure you have many less than perfect surfaces where you go!
  12. patsparks
    10,664
    569
    The roads here are crap mostly. We have some great driving roads though and compared to the roads I saw in Northern USA the roads here are mostly deserted. Peak hour last just an hour or 2 and highway speeds can in fact be high.
    Snow? no snow so ice occures only rarely and only in little patches. I've never had a problem with ice. Of course you need water to make ice, we have bugger all of that.
    And that brings us to mud, you need water to make mud too, so it's very rare. Most of the roads around are sealed though, although there is a dirt road just 500 metres from here. I have spent some hours going sideways on the Strezlecki Track in mud, fun to remember but hard work at the time.
    I find my Prius is slightly more confident around high speed bends since fitting the BT plate. With 195mm Michelin tyres I have no more an issue with cross winds in my Prius than I have in my Holden Commodore (Pontiac G8 with a 6 cylinder engine) patrol car I spend 7 hours a day in 5 days a week.
    I have done some bloody long drives in some strong winds in the Prius, I did my last 10,000km service 4 weeks after the previous one and it was late. I love driving it!
    I'll comment on the seat. I find the seat isn't the most comfortable on a short drive but on a long drive compared to other cars I have driven on long drives the Prius is great. I don't know why it is but although I never feel really comfortable, when I arrive I always feel refreshed and in good shape.
  13. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Hey Doc, there's an easy test you can do if you need some butt-dyno
    convincing about the plate. Now that all the roads are beat
    to crap by the cold weather, take the plate *off* and go for a
    drive down your favorite chuckholed washboard.
    _H*
