Thermometer
Discussion in 'Gen 2 Prius Main Forum' started by cobaka, Apr 10, 2013.
  1. cobaka
    cobaka Junior Member
    pennsylvannia
    The outside thermometer started reading incorrectly....saying it was 60 when all my other thermometers said 82. Help!
  2. nh7o
    nh7o Off grid since 1980
    1,686
    329
    Hawaii
    The ambient air sensor is located in front of the radiators, at the center of the air openings. It is just a small blob on a connector. If the thermistor goes bad then the readings can change. First would be to locate the sensor and unplug and replug it a few times, in case the contacts are dirty. Increasing resistance would result in lower temp readings. Otherwise, I can't say what the resistance should be for a given temp, so as to check the unit. It should be possible to get a cheap junk yard unit and try a swap.
  3. maestro8
    maestro8 Nouveau Member
    471
    108
    nor cal
    Stick your head out the window?
  4. skruse
    skruse Senior Member
    1,454
    96
    Coloma CA - Sierra Nevada
    The Prius thermometer needs an update to include Celsius.
Loading...
