Thermostat (3rd gen) answers !
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Mar 7, 2019.
  1. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    One thing I noticed is that before the water pump/thermostat replacement, temperature stayed normal(180-190 ish) during light driving, but when throttle was pushed say around 60-75%, temp tended to spike to 200 ish, depending on throttle position. This tells me that it's important to monitor the temp often, whether you have a OBD live data or Scangauge etc. to prevent premature headgasket failures. OBD live readers are quite cheap these days, around $20-$35 at Amazon. I would recommend everyone to get one, but please do be careful as the OBD readers have very small font so can be dangerous to monitor while driving.
  2. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    250k miles.
  3. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    It has 250k miles. I just bought it from the original owners in nearly new condition with only 1 small ding, perfect paint/interior, oil change/maintenace records every 5k miles from dealer, and very clean engine area EGR pipe from the outside seems almost new and replaced. My previous Toyotas went 400k, 300k without engine/tranny rebuilds, so I thought why not. I'm ready to replace hybrid battery cells and do a headgasket job when needed though.
  4. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Oh and yes thanks for the EGR link Mendel.
  5. Mendel Leisk
    42,293
    250k is well past the typical EGR sell-by date; either it’s charmed, or previous owners were on it. Yeah check the EGR pipe at least, ASAP.
    drjohnsontulsa and AmazingFacts like this.
  6. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Yes, I'm hoping previous owners were on the maintenance or replaced it. I'll report back what I find after it's unbolted.
  7. ChapmanF
    18,974
    One way to start is by getting the current overall EGR flow test result from the ECM (easy), followed by taking out the intake manifold and checking/cleaning its small EGR ports and gallery (almost as easy, much easier than the stem-to-stern EGR exercise).
    The manifold check/clean will give you confidence about what the overall flow test can't tell you (because it can't see differences at the four individual ports), and then based on what you've seen you can gauge the urgency of doing the rest.
    AmazingFacts likes this.
  8. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Great perfect, thanks Chapman. This will certainly same me time. I'll report back my findings.
  9. Mendel Leisk
    42,293
    Checking the condition of this pipe:
    is the easiest to get to. Good for getting your feet wet.
    Video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    And it covers the removal needed for intake manifold access as well.
    A prep work step (for removal of the EGR cooler/valve assembly) would be to remove the nut on the stud on the underside of EGR cooler bracket. Sooner or later you need to do that, and with the nut removed it's not in any way destabilized, so just remove it and leave it off. It's a pain to access, best to get it out of the way at the outside, rather than be hung up on it later.
    If you have an E8 torx socket and are ambitious, remove that stud as well. I did this not too long ago, and found it very tough to turn. You don't want to strip the head so go slow and careful. With the stud off I THINK it makes EGR cooler removal easier; you then maybe DON'T have to remove the rear studs, between cooler and exhaust manifold. You still have to remove the front/top stud holding the cooler, but that one's easy to access.
    #29 Mendel Leisk, Aug 25, 2021
    xliderider and AmazingFacts like this.
  10. ChapmanF
    18,974
    It seemed to me the studs on the rear were easier to take out—access is better—and with them out there wasn't any need to fuss with the stud in the evil bottom location. I just scooted the cooler off it sideways. It also made a convenient locating peg when I was putting the cooler back in position.
    As a bonus, if any damage happens taking those rear studs out, that's only the EGR cooler. Any damage taking out the evil bottom stud is to the cylinder head.
  11. Mendel Leisk
    42,293
    Mines out, and staying out. :)
  12. Mendel Leisk
    42,293
    Just musing: at those stud-plus-nut locations you could sub a bolt, of appropriate diameter/thread/length. With a washer behind the head, since it’s the driven component. Make for easier removal. Especially with the bottom-of-cooler nut/stud combo just ditched.
