Thermozite vs. Dynamat Xtreme
Discussion in 'Gen 3 Prius Audio and Electronics' started by haowu80s, Apr 11, 2013.
  1. haowu80s
    haowu80s New Member
    When doing sound-proofing on Prius, most people in this forum use Dynamat Xtreme, which is aluminum foil + butyl rubber, with a ridiculous price tag. After some googling, I found an alternative sound and heat isolation material called "Thermozite", which is made up of recycled PET, so called eco-fi (ecospun), and foil.
    Thermozite is way cheaper than Dynamat Xtreme, and its noise reduction coefficient(0.30) is very comparable to Dynamat Xtreme(0.417). And if thermo isolation is not of your priority, there is an eco-fi carpet padding that is even less expensive with even higher NRC (0.66).
    I am not from the acoustic industry and I might be very wrong. Is there any specific reason why Dynamat Xtreme is so popular?
    Auto Carpet Felt Padding
    Thermozite Thermal-Acoustic Insulation - Heat & Sound Shield
    http://dynamat.com/download/specs/2204_Spec_Sheet_Dynamat_Xtreme.pdf
    EdyJun likes this.
  2. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    What part of the Prius are looking to use this stuff on ?
  3. haowu80s
    haowu80s New Member
