These are the codes from code reader
Discussion in 'Gen 2 Prius Technical Discussion' started by jgfinley, Feb 5, 2018.
  1. jgfinley
    jgfinley New Member
    US
    P0A80
    Mil off monitors 3 inc catalyst evap 02 snsr 3 ready misfire fuel comp
    I know the P0A80 is bad hybrid battery
    But when I put a volt meter on the leads from the hv battery I get 188.9 volts fully charged is 201. Volts correct? But I don't get any volts on the car leads side of the system and display screen shows no charge all the check engine light on in dash. Can some one tell me what's up with this system?
  2. Prodigyplace
    12,715
    11,848
    Central Virginia
    The Hybrid Battery check looks at the voltage differences at the module level, not toe total voltage. If there is too great a difference (1 volt?) the code is thrown because one or more modules are detected as failing. The freeze frame data gives codes identifying the modules, IIRC.
    There could be other issues triggering that code though.
    How many miles on the car?
    @TMR-JWAP @2k1Toaster and @Raytheeagle have worked quite a bit with the batteries. In fact. 2k1Toaster sells a replacement detailed in my signature. It is $1600 delivered to continental US, but I think it is currently backordered.
    What is the voltage of the 12 volt battery after it has been sitting for a while? It can cause the computers to get confused and throw random trouble codes.
    Raytheeagle likes this.
  3. jgfinley
    jgfinley New Member
    US
  4. jgfinley
    jgfinley New Member
    US
    Poaa4 u0111 and the rest of the codes are still the same with the hybrid disconnected from the car
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Bisco.......take note of this.:whistle:
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    11.9 is a tad bit more than half discharged.
    Charge or replace the 12 V battery first.
    Other stuff might be wrong too.......but you can't trust "trouble codes" with a weak 12 V battery.
  7. jgfinley
    jgfinley New Member
    US
    Ok put 12 battery on a charger an then re check the codes?
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    Disconnect the battery, at least one side, then charge thoroughly.
    Then let it sit still disconnected for a few hours; overnight is better.
    IF.....the voltage then is not 12.6 or more, it isn't able to hold a change anymore and needs to be replaced.
    Having it disconnected will reset the codes. Charging in place without disconnecting will not reset/clear the codes.
  9. Prodigyplace
    12,715
    11,848
    Central Virginia
    Sometimes disconnecting the 12 volt battery resets the codes. Usually, once a 12 volt battery requires recharging it is failing and due for replacement. If this is the original 12 volt battery it is long overdue for replacement anyway.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    What device are you using to read the codes, and what are the codes offered?
  11. Prodigyplace
    12,715
    11,848
    Central Virginia
    codes listed in the first post
  12. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Pretty sure we're still missing some. But if you have others please share.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,838
    Clearwater, Florida
    There's a battery side of the contactor and a car side of the contactor. Battery side will always be hot the car side is only hot when the contactor closes and connects the hybrid battery to the car/inverter.
    I do not mean to be rude or demeaning but this is very basic electronics so you don't have alot of experience with this so be very careful around a hot hybrid battery without the safety plug removed. It can turn your hat around as electricians like to say.
    And it doesn't really matter what the total output of the battery measures in your case it was 188 volts. That's a little low but what does matter is the battery ecu monitors every one of the battery modules and if one falls below minimum voltage compared to the others it will throw a nag. The reason its below voltage is the module is old and not able to hold a charge. Its failing. The ecu knows what it should be and its not where it should be so it throws a nag.
    The difference in voltage between a good module and a bad module is typically referred to as Delta.
    Prodigyplace likes this.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Each module has 6 cells and each cell is 1.2 volts. Each block has 2 modules and there are 14 blocks in the battery pack.
    188 volts seems low (lower than I have read).
    Can you give us a bit of history with your Prius:
    • Did the car sit for awhile?
    • Has the battery ever been depleted severely (like ran out of gas)?
    • What are the Hybrid specific codes (if you are getting P0A80 that is the generic and you should have something more specific to point you in the right direction)?
    • Where in the great US are you located?
    Keep us posted (y).
    SFO and Prodigyplace like this.
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    These are the things we need to know. 189 volts is not just a little low, it's completely jacked. 189 volts and 28 modules means you're averaging only 6.75 volts per module. I'll go with the guess that this has been sitting a LONG time. You're going nowhere until you get the HV voltage up.
    The 201.6 volt rating is merely 7.2v nominal x 28, but 7.2 is not the normal voltage. Normal is usually in the 7.7+v range
  16. jgfinley
    jgfinley New Member
    US
  17. jgfinley
    jgfinley New Member
    US
  18. jgfinley
    jgfinley New Member
    US
  19. jgfinley
    jgfinley New Member
    US
  20. jgfinley
    jgfinley New Member
    US
