These are the codes from code reader
Discussion in 'Gen 2 Prius Technical Discussion' started by jgfinley, Feb 5, 2018.
  1. jgfinley
    jgfinley New Member
    US
    And yes I under stand that the charge will turn your hat around I work on atnt LTE which is a 48 volt dc system and that will turn your hat also an very careful when working on the hv battery
    edthefox5 likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    jg,
    Although I have no firsthand experience, I would avoid the towing method of charging. With just a small amount of pondering, you would need to tow the car while it was in "drive" in order to even have a chance of charging the HV battery. The car will not charge the battery if in neutral. The car must be in "Ready" state in order to be shifted out of neutral. But, the car will not go into "ready" state in it's current condition due to the low HV battery charge (assuming no other issues). Plus, there are too many expensive parts for me to consider that as a viable option.
    Your easiest option would be to obtain a high voltage charger like the Prolong unit (or any grid charger for a 202v HV battery), connect the harness and let it charge. Next option would be to charge each module individually using smaller hobby chargers. Decent one can be had for about 150-200 $$ and can do 4 at a time.
    SFO and Raytheeagle like this.
  3. jgfinley
    jgfinley New Member
    US
  4. jgfinley
    jgfinley New Member
    US
  5. Prodigyplace
    12,715
    11,848
    Central Virginia
    How would towing even charge unless you were also using the regenerative braking? :eek:
    The only 2 ways to charge are the engine using MG1 or regenerative braking using MG2.
  6. jgfinley
    jgfinley New Member
    US
    So I took a part the battery and checked the cells individually most are in the 6.5 volt range. So let me ask to.clarify I can use a hobby 1 amp charger on the cells individually?
    Raytheeagle likes this.
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    @jgfinley since you like to play with voltage and still have a DIY streak, you might find this thread of interest:
    P1080, P3022 | Page 2 | PriusChat
    And others have also built HV chargers out of LED power supplies for cheap, if you want to try that path.
    edthefox5 and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You can but it will take awhile to charge all of the modules individually.
    SFO likes this.
  9. jgfinley
    jgfinley New Member
    US
    Yes I am finding that out but I don't have much else to do atm so charge away lol.
  10. jgfinley
    jgfinley New Member
    US
  11. jgfinley
    jgfinley New Member
    US
    Mean while I have found that I must let the charger with the built in volt meter charge .25 over what the volts are supposed to be at to achieve a full7.75 volt charge on each cell.
  12. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Be very careful with your amperage when charging the modules. Do not use greater than 350 mA once you go outside the 40% - 80% SoC range. I believe this equates to ~1.28 - 1.36 V/cell or 7.68 V - 8.16 V per module.
    You want to charge the modules until it stops rising (at around 8.44 V) and then continue the charge for 4-6 hours to top balance each module properly.
    SFO likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    OK, it's easy to check/verify the 12v health so it's not bad advice but it really has nothing to do with a P0A80 code.
    We know 12v lead acid batts typically have a 3-6 year lifespan so every gen 2 on the planet went through a weak/failed 12v battery years ago (and maybe even a 2nd or 3rd time). Most of those 12v issues reported here were evident from the SKS getting flaky, no starts, completely dead car, etc. What we didn't see was a rash of P0A80 codes, trouble lights, etc during those early years because the HV batts were still quite healthy.
  14. dolj
    dolj Senior Member
    8,646
    4,398
    188 volts is too low for the car to start and is way outside the 40%- 80% range the ca uses. 201.6 V is the nominal voltage of the pack but is also at the low end. The pack is used in the 215 V - 235 V range, but can go higher in use.
    11.9 is a hairs breadth of totally flat, so the advice the advice to charge up is solid advice. A full Prius (AGM) battery should be in the region of 12.-13.2 V.
    Good solid general battery housekeeping advice.
    It is time for this oft repeated urban legend to be consign to the annuls of history. Just because it is repeated (often) does not make it true.
    The 12 V bus voltage needs to drop below 10.5 V before it becomes a problem in some of the computers and south of 9 V in others. Therefore 11.9 V is not going to have any detrimental effect. Yes, it is flat and needs to be charged up, but that is a side issue.
  15. ChapmanF
    19,033
    This. In general, as in any other car, the 12 volt battery can cause you all the usual kinds of headaches, if it is so low that it's obvious without arguing about multimeter readings. You know, locks-won't-unlock low. Lights-glow-feeble-orange low. That kind of low.
    The idea that a 12 volt battery at a volt or two below nominal invalidates your trouble codes by making the ECUs "confused" and their diagnostic reports "random" is one of those odd notions that circulates so vigorously on PriusChat that you'd assume there must be plenty of substantiated examples ... until you start searching the forums looking for them, and notice that there aren't.
    -Chap
    strawbrad and dolj like this.
  16. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    It is NOT an urban legend because............
    From just reading text messages in a place like this, we don't KNOW under what conditions the battery voltage is being checked.......and in some cases, the OP doesn't seem capable of actually doing a check at all.
    If a reading of 11.9 is seen under no load conditions, when subjected to any load at all it may not be able to supply the current necessary current and drop even farther.
    This is not just speculation. I've been doing this electronics thing for a bit over 50 years now........and trying to "fix" a problem reported by an on-board computer without first being positively sure that the power supply is healthy and stable......is just a fools errand.
    But you are certainly welcome to be foolish if you want. Sometimes it works out just fine. Other times not.
  17. jgfinley
    jgfinley New Member
    US
    Well got the batteries charged all seemed good car took off engine started but it drained the battery so fast and died again
  18. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Doesn't sound like the engine actually started to keep the HV battery charged.. any codes thrown? o_O
  19. dolj
    dolj Senior Member
    8,646
    4,398
    No one is disputing that if a no/low load voltage is 11.9 V then when then car has load applied will drag the voltage lower. What is speculation is how low the voltage goes and then the leap that that voltage is the cause of the problems. In your 50 years of doing the electronics thing, how many years do you have with Gen 2 Prius ECUs? What are the voltage thresholds where there will be problems? Just answering these question would add value to the discussion. Unless you can answer these with any accuracy, you ARE speculating and therefore perpetuating the urban legend.
    Again, no one is saying otherwise. What we are trying to highlight that in a lot of cases the 12 V is proved to be healthy (enough to do the job) and stable, yet people will not let it go and move on.
  20. ChapmanF
    19,033
    I did notice also that was the second "50 years" reference in a single week. There's certainly nothing wrong with experience. Indeed, one of the coolest things about PriusChat (maybe even among other car enthusiast forums) is the sheer concentration of members here with similar qualifications.
    That makes it a pretty good crowd to have for an audience, in a way; it means as long as you're bringing sources and data and participating respectfully in reasoning things out, people tend to recognize your chops and credibility in the natural course of things, with not a lot of need for drum banging.
    -Chap
    m.wynn, dolj and Prodigyplace like this.
