They reduced the EV mode top speed to 53mph?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jordanzelda23, Sep 14, 2011.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I still don't know what you're referring to. Are you talking battery life over the life of the vehicle, or range per charge longevity? How is it you see limiting top speed improving "longevity" however you're defining it.
    Frankly, I don't see reducing top speed having any impact on battery life, but certainly it would be a factor in average range.
  2. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Evan, top EV speed being lower would reduce the rate of draw from the pack, potentially making life easier (longer) for the battery. I have no clue whether that is the case, but that is my interpretation of john's reference.
  3. efusco
    19,891
    1,196
    Nixa, MO
    I don't think we know the precise answer to that question yet. My assumption would be that yes, it will continue to use some of the traction battery power in addition to power from the ICE. Essentially it would operate (my guess only here) similar to the current Prius in that when the battery SOC is high that the HSD will use more of the energy buffered in the battery in order to maintain a lower ICE demand/RPM.
    What I observe in normal driving is that with a 58-60% SOC on a random flat acceleration from a stop is that my ICE RPM might be 2300 while there is little or no net charge gain or loss from the battery. If the SOC is 65% for the same rate of acceleration the ICE RPM would only be about 1850 RPM since there is additional power being applied toward acceleration from the battery. Likewise, if the SOC is 52% that same rate of acceleration might require 2800-3000 RPM from the ICE while the ice is adding charge back to the battery while it simultaneously accelerates the car.
  4. ksstathead
    1,244
    245
    Kansas
    You can choose to preserve SoC for local short trips at the end of an HV highway segment. If you do not choose to do that, the SoC will be used in conjunction with the ICE power, like when the current gen2/gen3 Prii get 7 or 8 green bars: it likes to use them.
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    53mph is an improvement from 45mph so it'll definitely be helpful, but it means no true glides on 55mph roads. However, I hope at least that the higher speed limit means it can save charge by not spinning the engine as much.
  6. ksstathead
    1,244
    245
    Kansas
    53 in a 55 sounds ok to me, most of the time.
  7. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I'm thinking the US versions may not have the EV-city function. Sounds like something they had to do to get into European city centers where ICE has been outlawed, gives up efficiency to force the ICE off.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I read that Eco mode can be applied to both the EV<->HV and EV-City modes.
  9. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yea, we should get the Power button instead. :D
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    While we are discussing top speed for EV in this particular car;
    Does anybody know what maybe the ideal mph speed for maximum efficiency of both sources of energy to switch from EV to HV.
  11. lensovet
    2,615
    496
    Burlington, NJ
    People are reading way too much into this. It just says you will get x miles at up to y speed. It doesn't say anything about what happens when you go about y speed. Most likely your range drops significantly, but that's about it.
  12. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I'd guess right around 53mph....
  13. Flaninacupboard
    1,297
    213
    Midlands - UK
    If you leave the car in EV mode and go over the speed threshold (be that 53 or 62) the engine will come on to assist, but still use large amounts of battery power. I drove the PHV prototype around Rockingham Speedway last week, and observed at 65mph the car was returning 100mpg. the engine was running, but lots of battery assist was still happening. If you choose to press the EV/HV button you'll force it into HV mode, and the battery assist stops. you will save your EV range for use later.
    On your 18 miles you will probably use all of your "EV miles". this still works out to 14 "EV" miles and 4 "gas" miles, so you'll use ~0.08 gallons of fuel and get ~225"MPG".
    My guess on the 53mph thing is that toyota determined a best efficiency threshold (in terms of energy used by the drivetrain) similar to the threshold in the centre of the HSI. The threshold will also move dependant on load, temperature, SOC etc etc.
  14. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Let's not forget about the way EV for Prius has been depicted in the past.
    24 mph has been the official threshold noted, but we all know the engine RPM will remain at 0 all the way up to 46 mph.
    In other words, that mode we call *STEALTH* could still be alive and well in the plug-in model too. So for PHV operation during depletion, it would be from 54 to 62 mph.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Fixed.
  16. jordanzelda23
    jordanzelda23 New Member
    Republic, MO
    Awesome, that answered my question perfectly. This is good to hear that it will continue to mostly use the battery if it is in EV mode and you go above the mph threshold.
  17. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Then EV city should have a higher ev top speed.
  18. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    It sounds like EV driving is a high priority with you. Why aren't you considering a Leaf?
  19. jordanzelda23
    Republic, MO
    I don't like the look of the Leaf, some of its features, or price. I am considering the Ford Focus Electric depending on what price it is launching at. I think I have come to a decision that the Prius plug-in would be the best due to 4 things:
    1. Price <$30,000
    2. Can do electric for majority of driving, but can also run on gas for extended range, thus no range anxiety.
    3. When it does switch fully (or mostly considering it is still a hybrid) over to gas on a long drive I will still be getting 50+ mpg.
    4. It charges fast due to the smaller battery.
  20. john1701a
    12,840
    5,312
    58
    Actually, I did mean 24. It was with respect to the "EV" button.
    On the Energy Display for the cordless model, we can see that "EV" really means being able to supply electric-only propulson into the WHITE & RED zones. But that has been limited to speeds up to 24. There still is electric-only available in the GREEN zone, by that means "EV" is longer engaged... despite the fact that the engine is at 0 RPM still... hence STEALTH.
    That's my guess as to how 53 to 62 electric-only travel will behave. It won't be called "EV". It will still act like it though, but with a lower power threshold. In other words, you'll be able to cruise along a 55 mph highway with the engine motionless in the PHV very much like you can on 40 mph road now in the cordless.
