Thieves stealing Hybrid Batteries in SF !!?
Discussion in 'Gen 3 Prius Main Forum' started by 3prongpaul, Jan 28, 2015.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    That would be satisfying but I'm sure the thief's family would then sue Toyota for millions of dollars....and probably win.
    Lino likes this.
  2. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    Title names the culprits - I guess it was the Steelers (or is it stealers?) Superbowl week yunno.
    Bet these are headed for a Gen2 with a dead batt...lesson to Toyoya...make the nextgen batts incompatible with prior Gen
    But believe I am safe...nobody wants my Gen 2 batt
    #22 wjtracy, Jan 28, 2015
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,438
    3,306
    Madison, Wisconsin
    Sorry. Hard to count post #11. It is from person that only ever had one post on here. He never came back to elaborate. So as far as I am concerned that would be unsubstantiated.
    As for the Sacramento one. No pictures or actual video footage ever showed up online.
    Carolyn's is the first one I have seen with actual footage of a car with a stolen pack.
    ftl likes this.
  4. fuzzy1
    10,444
    It appears to be de-contented now. It did have content when I posted it last May.
    I'll have to track down the several other threads I mentioned last May:
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The Sacramento news story has video, but the video doesn't show the gaping hole in the back of the car.
  6. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Was reading through the YouTube comments from the video. Carolyn mentioned using a GPS locator attached to the battery to thwart theft. I wonder if there is a way to stealthily attach a Tile (TM) to the battery. That might supply a measure of relocatability not unlike LoJack.
  7. 3prongpaul
    956
    730
    You could get some kind of GPS device (motorcycle locator that sends you a text when battery moves) and use the hybrid battery itself to power the device. Pull power from 1/2 the pack using a small 120V to 12V power supply so it wouldn't affect performance of the car, and would still work with the orange plug removed...I'd add a relay so the GPS wouldn't work if the car was READY, this way it would not interfere with the car but when car off you'd have battery tracking enabled. Man it would be fun to catch the buggers.
    RAM v likes this.
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I'm not going to get too worked up over it. When an entire Prius is stolen, is that more or less news worthy?
  9. JonWaters
    JonWaters Junior Member
    I really like the idea of replacing the factory bolts with locking bolts on the battery. Simple, cheap and effective. When can I get some on the Prius Chat store?
    heyjack70 likes this.
  10. Former Member 68813
    3,524
    983
    US
    LOL!
    BTW, security nut is a good idea.
    #30 Former Member 68813, Jan 29, 2015
    cycledrum likes this.
  11. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    Shocking. Looks like a case of assault and battery. Revolting.
  12. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    Calm down, you're getting too amped up about this.
    Rae Vynn and Yakoma like this.
  13. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    How about to assign an unique MACID to the battery ECU, and register it to the ROM of the main power control ECU which only Toyota can update. If the battery ECU MACID does not match with power control ECU's registration, nothing happens.
    I doubt it will happen though, the problem is not big enough yet.
  14. fuzzy1
    10,444
    ^^ And block do-it-yourself and independent battery repairs and replacements?
    This cure would be worse than the disease.
  15. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    How much of this would typically be covered by comprehensive insurance?
    Edit: I just checked my policy (Progressive).
    My comprehensive coverage includes:
    malicious mischief and vandalism.
    theft or larceny.
    breakage of glass not caused by collision
    How much of that would cover damage due to theft of battery, only the insurance company can answer.
    #35 co_prius_3, Jan 31, 2015
  16. A617
    A617 Member
    213
    95
    OKC, OK
    Wear a pair of electrical glove, and a rubber insulated wire cutter, no problem
  17. frodoz737
    frodoz737 Top Wrench
    4,698
    2,496
    33
    For return on time/investment...sure beats tires and stereos.
  18. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I'm currently hoping the perpetrator is caught shortly and gets charged with wire fraud.
    #38 co_prius_3, Jan 31, 2015
    Rae Vynn likes this.
  19. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Tried getting into my car back in September using the b pillar as a pry point. Window cracked but tint held it together. Unfortunately another resident wasn't lucky and they boosted the battery.
  20. sdtundra
    1,314
    193
    Sacramento, CA
    What was strange was both times rear side windows were used for access
