Things I've learned to live with (or found workarounds)
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Feb 19, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    This is just a summary, Each issue would require a separate posting:
    1. Ergonomics.
    2. Fob remote range.
    3. Remote start from app.
    4. Driving assistant.
    5. Door locks.
    6. Audio system
    7. Temperature control.
    8. EV range.
    9. Driving performance.
    10. Mechanical drive issues.
  2. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    How about just write an introductory sentence to each of the 10 listed to get feedback on which ones would be worthy of a separate post?
    dolphinsil and Prodigyplace like this.
  3. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Each issue by request.
  4. Mendel Leisk
    42,263
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    #4
    Also interested in #10
    daisy555 likes this.
  6. bisco
    52,774
    I suppose all cars have their positives and negatives.
    Choosing is a compromise
    daisy555 and Prodigyplace like this.
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    I guess a steam powered one would not have electrical positives & negatives :D
    Isn't the English language fun?
    #7 Prodigyplace, Feb 19, 2025
    dolphinsil likes this.
  8. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Very well. Temperature control.
    First of all, my Gen 5 takes a lot longer to warm up than my Gen 3. I'm halfway to town before I can take off my gloves.
    The heat pump was pretty useless in our -20, -30C winters. My workaround was to install a cardboard ahead of the radiator. I left it in all year around with no ill effects.
  9. Prodigyplace
    12,710
    11,848
    Central Virginia
    Are you sure the automatic grille shutters are working properly?
    I have a 2025 Camry and I dislike that the fan speed & air direction are not shown when in Auto mode like they were on my Gen 4 201 Prius.
  10. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    That's a bit of a catch-all category. I should have called it "mechanical issues."
    It won't remote start without having some plug-in charge. It says, "30% minimum" but it's actually more like 50%.
    But who knows anyway, because it only shows you EV range. I used the CHG feature to keep at least 30 kms in reserve, but lately it's kicking out at about 22 kms. Plugging it in seems to be getting it a bit higher. I don't know what's causing the decrease.
    The remote start from the app is difficult to use. It says you get 2 starts, but it's only 1. It also fails the first time unless you remotely lock the doors, even if they are already locked.
    Door locks seem to fail to unlock quite often, except of course when I'm trying to show it to the dealer.
    Too many more to mention here. I'll try to address them as they come up.
  11. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I've heard about those grill shutters, but I don't think I have them.
  12. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Definitely #4
    If you’re talking about the Remote Connect subset.
  13. Prodigyplace
    12,710
    11,848
    Central Virginia
    They introduced them in the Gen 4 Prius & Prime. I really doubt they quit using them.
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    i assumed #4 related to the PDA (Proactive Driving Assistance) feature.
  15. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Well, I had it apart to install the cardboard, and I didn't see anything.
  16. Prodigyplace
    12,710
    11,848
    Central Virginia
    They would be part of the lower grille assembly. i had them on my 2017 Prius Two, the base trim, to speed up engine heating.
    @Tideland Prius were the active grille shutters removed for Gen 5 Prime?
  17. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Well, in any case, I had trouble maintaining adequate heat to the interior until I installed the cardboard.
    I know that my Gen 3 had a heat exchanger in the exhaust to warm up the engine faster, but I doubt my Gen 5 has it. The Gen 3 warmed up in about 5 minutes, but my Gen 5 takes much longer.
    Prodigyplace likes this.
  18. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Yes. I haven’t found any documentation of substance and I have a one year trial.
  19. Prodigyplace
    12,710
    11,848
    Central Virginia
    PDA is one of the safety features that cannot be turned off. if equipped. It has no subscription.
    Proactive Driving Assist | Toyota PDA
  20. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    And I’m thinking of something different. It’s something that’s part of remote connect and one of the things that can do is have a I believe a live person give you turn by turn instructions to your destination. It may be invoked with the SOS button, but I have found absolutely no substantive documentation.
