Things that start to fail on an 8 year old Prius...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HTMLSpinnr, Oct 27, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Just turned 150k. So far so good. My only broken part is my driver's side seat belt. The shoulder strap will not click into the receptacle unless I push down the release button while inserting the tab. It's kind of annoying but it's hard to be upset as this is my first broken part. :)
  2. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    Have you tried a dry lube? Hopefully it's just sticking.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Nope and I never even considered it. I'll try it out. Thanks. :)
  4. rwyckoff
    rwyckoff Phev's Plus Home Solar power1
    82
    Green Valley AZ.
    2004 with 235K miles, both sets of struts, pumps replaced. The inverter pump just recently in the recall, it was still good.
    What about the hoses? how long are they supposed to last?
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Did you do the serpentine belt with the engine water pump?
    Hoses generally last a very long time. Something to think about replacing if you have to drop the engine+transmission sometime in the next 10 years.
  6. rwyckoff
    82
    Green Valley AZ.
    Yes, belt has been replaced.
    Thanks
    Just had the transmission fluid changed for first time (235k miles), had some saved. anybody interrested in an analysis. Had it checked at 104K, after four years in SF Bay area, mechanic said that it looked like new. Did another four years near Tucson, mechanic said it was dark and grainy. Their Prius expert at Dessert Toyota recommends replacement every 60k miles.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Out here, I'd agree. At 60k, it was rather dark. I'm leaning toward doing it again now that it's at 125k.
    Analysis may prove or disprove your expert's theory. If Bob Wilson were hanging around, he'd be interested for sure. :rolleyes:
