Think the Gen 4 is Ugly? Look at this!
Discussion in 'Gen 4 Prius Main Forum' started by William Redoubt, Sep 29, 2016.
  1. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I'm sure it has a rev limiter, but that doesn't protect against an accidental downshift into 2nd gear at over 60 mph. This is the most typical way of blowing up the engine.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Or like a young chap I knew, had a relatively meagre Mazda - I think you called it the GLC in USA - worked out that he could spin the tyres by starting off in a pile of loose gravel and when it hit the bitumen "SCREECH" till it ran out of power and took off. He did it for a few weeks to impress his mates till the time it went "BBANGGGGG" instead - the gearbox/transaxle case split.
  3. TriniTT
    TriniTT New Member
    Birmingham, AL
    2012 Nissan LEAF
    Bleh. I wish automakers would return to smooth lines again. All those aggressive angles aren't going to withstand the test of time.
    Felt and Mendel Leisk like this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    What does, other than taxes?
    Mendel Leisk and alanclarkeau like this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Now that time has passed, I have to admit I think Toyota did a great job making the Gen 4 look great.
    I like it, from the front, sides, all the way until you reach the accordion fireplace bellows scrunched back.
    Except for that singular design element.....ignore-able....I think the Gen 4 is great.
    RCO and krmcg like this.
  6. eman08
    eman08 Active Member
    360
    192
    US
    Probably can out run the cockroach cops while they call for more back up crew while they all start running out of gas in a hot pursuit. Just crawl all day until they give up unless your tires get shot. You done
  7. MagyarPrius
    MagyarPrius Member
    33
    28
    Lakeland, FL
    2019 Prius
    The Honda Si appears that everything is an afterthought. Pain in the butt to wax.
  8. orenji
    orenji Senior Member
    5,887
    3,488
    Type R is able to reach 200 MPH, not to shabby for a Civic! Who cares what it looks like with a top speed like this! :) BTW I like the looks!
  9. Archenemy
    Archenemy Junior Member
    24
    Singapore
    Honda type R engines are truly a work of art. The screaming of a vtec engine is music to a petrolhead's ears..
    Driving a Accord CL7R now (known as Acrua TSX over in the US)..
    The previous FK2R costs about US$125,000 where i come from and you can only drive it for 10 years..
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sounds more like Formula 1.
  11. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The 10th-gen Civic is really a styling mess in all trim levels, not just the Type R.
    However, I do suspect that the aerodynamics actually do work - there's also a big front splitter, which will give it front downforce. And, even though it's FWD, aerodynamics on both ends of the car actually do help - downforce improves cornering grip at speed, and the back end of the car needs to have grip too, even if it's not as heavily loaded due to the lack of drive forces.
    Note that plenty of FWD cars in the various touring car racing series have big rear wings, too - that's because they need them. Edit: And their goal isn't fuel efficiency, it's minimum laptime. Even though the high drag reduces their top speed, being able to take the corners faster helps the laptime.
    #51 bhtooefr, Feb 7, 2017
    RCO and alanclarkeau like this.
  12. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Can't be that bad since it has no problem keeping up with the new M3 and some serous sports cars around the track. The spoilers might look silly but they are 100% functional. The Gen4 is considered ugly but also functional in aerodynamics. That TypeR Civic is very impressive around a racetrack.
    RCO likes this.
  13. Prodigyplace
    12,548
    11,772
    Central Virginia
    That is not where most automobile users spend their driving time.
  14. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    However, the Civic Type R is intended to be capable of that - sure, nobody's going to track it every day, but a lot of performance cars are meant to be usable on the street in your daily driving, but also intended for high performance driving.
    Bashing it because it's optimized for high performance driving is misguided - that's the entire reason it exists. If it weren't optimized for high performance driving, it would be the regular Civic, which also exists.
    RCO likes this.
  15. KennyGS
    1,243
    1,044
    Keystone State
    I used to track a modified 2007 Si. It was very capable - no doubt. If you've ever driven a civic near its limits, you'd understand my comment on the understeer. Just watch some of the videos of drivers negotiating one around a track.
    I wasn't knocking its capability, just commenting on the driving characteristics.
  16. Alpine Hiker
    Alpine Hiker New Member
    I really find the interior of the gen 4 prius a downgrade from the gen 3. And why did they delete the second glovebox?
  17. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I believe the consensus is that the second glovebox was deleted for safety reasons, to allow a better deployment path for the airbag.
  18. Tideland Prius
    16,554
    Really? I assumed it was a design thing (low cowl = lower dashboard = less space for a glovebox)
    RCO likes this.
  19. Mendel Leisk
    41,402
    I'm pretty sure somewhere in this Interior walk-through Danny did with US Toyota rep he says something to that effect, that the upper glove box would disturb the sculptured line, something like that. But danged if it I can find it. Anyway:
  20. Tideland Prius
    16,554
    Starts at 11:08.
    RCO and Mendel Leisk like this.
