Thinking about doing my own maintenence
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, Jul 19, 2017.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    Nice! I also see your hydraulic lift has a different kind of grip (seems like a fork grip) , verses the circular one I attached. Would that still work as intended or should I get different style of hydraulic lift?
    #21 Berch1943, Jul 24, 2017
  2. Berch1943
    Berch1943 Member
    146
    Arizona
    Yes but I can't change tires with them.
  3. Mendel Leisk
    42,345
    Are you addressing me, regarding the pic in post #13? That's definitely not my setup, just a good pic of underside someone posted a few years back, taken at a professional garage I'd assume. I'm just using run of the mill 3 ton floor jack, albeit with good range.
    Another front jackstand pic, maybe clearer:
    (passenger side, looking rearward)
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Given the difficulty that repair shops have in finding folks with two functional brain cells to work for minimum wage AND give a damn about someone ELSES car, reason #1 is good enough. But hey, reason #2 is even better :)
    Start with Craigslist, there are always good deals on good tool sets, over 50% of the mechanics currently employed will be able to retire within the next 5 years!!!! I have already sold off a good portion of my duplicate tools, but am not that close to retirement. GOOD wrenches, used in decent shape, will cost an average of $2-$3/each, but last a lifetime or two ;)
    I would start with wheel chocks, drive-on ramps, a box of rags, 8mm-18mm hand tools (combination wrench set), a good (Snap-On) 3/8" drive metric set 8mm-17mm with a couple extensions and an oil filter wrench.
    However, the TWO most important tools you will NEED are:
    1) Common Sense
    2) A GOOD (Factory) Service Manual
    Berch1943 likes this.
