Thinking about jumping ship to a used Prius (from a sporty car)
Discussion in 'Gen 2 Prius Main Forum' started by CptChnk, Oct 3, 2011.
  1. a_gray_prius
    2,927
    782
    IL
    I've driven all kinds of sports (oriented) cars, including the GTI and the R32. I have an Evo IX with some suspension upgrades along with my Gen2 Prius Touring. I've upgraded the Gen2 with ADVAN AD08 tires on Volk CE28n Eco Drive wheels. I honestly have to say that the Prius is really not that bad handling-wise. The tire upgrade made the steering quite a bit heavier (more like a 3 series) and the car holds on far beyond anyone's (including my own) expectations in corners. No, it doesn't accelerate like a 911 Turbo or a GT-R, but maintaining speed in corners is kind of part of the fun of driving the car (ever driven a miata on a tight road course?).
  2. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    CptChnk - Just to add my 2-cents. I went from a VW to my Prius - I had an 02 Passat. I have said before that VW's are great cars to drive but lousy cars to own and this one fit the bill. I was lucky, I had a couple of small annoying problems, but not anything major. At the time I was living in Philly, but working in Providence RI during the week. I started off flying, but quickly just found it easier to drive so I was putting about 1,100 miles a week on the car. The gas savings for me at the time more than outweighed the loss of comfort.
    In your case I'd actually argue that you just hold onto your GTI. It is a great car to drive and one of the more reliable VW's (just my gut feeling, perhaps I'm wrong). At 58k miles you have already had your big depreciation hit and you are not going to have another one until you are closing in on 100K - with the limited driving that you do that will not be for a few years. At least with my Passat the timing belt had to be replaced at 90k and that was a huge expense - in typical German fashion they did not design it in such a way that this was easy - they need to just about take off the front of the car to change the belt. If it is the same with the GTI I would think of selling it 5-10k before the belt needed to be replaced.
  3. wef
    wef New Member
    Glendale, AZ
    What size tires and wheels are you running? I feel the suspension of the Touring Prius is really tuned in well so the limitation of the car now is the tires. Did you notice a fuel economy hit when you switched off the stock rims/tires? I have seen a Miata pass a Corvette on a road course. It wasn't a spec Miata, but it was pretty close. And it was on road tires...:) The course had a long straight as well, but the Corvette just lost too much time in the corners. Just comes down to the driver and car setup...I saw a Z06 on slicks running circles around the same Miata later in the day.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Even with short trips, Prius should double the MPG you are getting with your GTI. Get a used Prius and put 2DIN navigation head unit. Get Kiwi bluetooth and run Torque with custom PIDs on your Andriod phone. You'll have fun with the efficiency and high tech hybrid premium features.
    If you think about it, all the traditional performance / fun features use more gas. Prius has a different kind of fun that uses less gas.
  5. CptChnk
    CptChnk New Member
    Tempe, AZ
    I feel about the same way. I actually stumbled across an older thread I decided to post to, and there, I briefly chronicle my experience of VW ownership. I'm on my 3rd one...well, 2nd one, if you count out air-cooled.
    Yeah, I've been told that a few times before, because of the depreciation bubble I'm currently in. Even so, certain aspects of owning this car are still scaring me a bit, given my present financial situation...
    First off, the maintenance is expensive. My GTI has the sequential manual (DSG) transmission and requires $300-400 worth of service every 40k miles. This has already been done once. Like any sporty car on large wheels, the tires are expensive (I'm due for my 3rd set already) and a set of new tires for this car is right around $900 after the mount/balance and new TPMS sensors. And even on all-seasons, I can only expect about 25-30k miles out of a set before they're completely bald.
    Secondly, while it's been said that German-built VWs (like this GTI) tend to be more reliable than the Mexican-built ones (like my old Golf), I still question the validity in that. The GTI has been to dealer on a few occasions for various annoyances (airbag light FOUR times, blown diverter valve, etc.) but those repairs were all under warranty. Now, the car is 6k miles out of warranty, and judging by what my old VW cost me in repairs over the years, I'm still a bit worried.
    According to the maintenance schedule for this car, the timing belt should be checked at 80k miles and replaced at 120k miles. So that's pretty far off from where I'm at now. In my old '97 Golf, I replaced the timing belt at about 95-100k, IIRC. But again, judging from the nightmare I had with the old Golf outside of normal maintenance, keeping the GTI for that long will certainly be a gamble in my eyes.
  6. a_gray_prius
    2,927
    782
    IL
    The rims are exactly the same as stock size: 16x6JJ +35 5x100. The tires are size 205/55/16 (very slightly wider than stock). There is a very significant F/E hit, I'm seeing 43mpg averages in comparison to the 46-47 I was seeing with the stock tires (and wheels). However, I think the slight F/E tradeoff is worth it since the car seems much more stable at speed and turns (holds corners) much harder. Tire wear is nontrivial: these are 160 treadwear. I've put close to 30k miles on them and it's going to be time to replace them soon. I think I might try the Dunlop Direzza D1 Star Spec for the next set (they're a bit cheaper).
    I WISH my tires were $900 installed - a set of 4 ADVAN A046 tires for an Evo is $1200 before installation.
    I'd like to remind you though: the best car is one that's paid off (unless your operating costs are high enough to offset the switching costs, like if you drove 100 miles per day).
  7. CptChnk
    CptChnk New Member
    Tempe, AZ
    I feel you, man. But an Evo is really in a different class than a GTI, even the R32. About the closest thing I test drove to an Evo when car shopping was a WRX STi. I wasn't particularly interested in spending nearly $40k on a car, but I had to see what it was like. It was by far the fastest (and best handling) car I've ever gotten behind the wheel in, but it was brash and punishing to drive. Not really a daily driver, IMHO. I would suspect the Evo is similar in that regard, given all its muscle.
    Yeah, I paid off the GTI in late 2009. And trust me, I totally get what you're saying. It'll probably be a couple of months before I make the final decision whether to keep the GTI or dump it. There's a lot of things I really LOVE about this car, but I lot of things I'm just afraid of from past experiences. Plus, something I haven't even mentioned yet: the fate of my younger brother's 2006 Jetta...
    To be as brief as possible, he bought it as a certified pre-owned in 2008 (he traded in a Tacoma 4x4). It had around 39k miles when he got it, with the remainder of the factory warranty (4/50k) still intact, plus an additional 2/25k thereafter. Now, my younger brother drives a lot more than I do (probably 18k or so miles per year).
    Earlier this year, he was 2k miles out of warranty and his auto transmission started acting up. When warm, the car would jerk (rather prominently) while shifting between 1st/2nd and 2nd/3rd gears. At this point, he felt that he was screwed.
    But then, wouldn't you know, VWoA sent him a warranty extension letter describing a problematic component (in this case, the valve body) in the transmission that was prone to cause EXACTLY what he was experiencing. So, he marched into the dealer with the letter in hand, only to be soul crushed later after they passed the problem off as "non-related" by only inspecting the transmission fluid (which had been previously changed by THEM months ago). I've been to several VW dealers in 3 different cities, and this is generally what you get to deal with: rude service writers and technicians that don't want to help you.
    So, we escalated this to VWoA and after a few days of back and forth between them and the dealer, VWoA chose to side with them: "Nothing we can do sir, you're out of warranty." It took some legal action on our part, along with some Internet consumer advocacy drama before the dealer finally agreed to properly diagnose for a possible valve body failure (as in, actually dropping the necessary components to actually INSPECT its condition).
    Well, the dealer came back and said that wasn't the problem, but rather, something in the transmission itself that would require a complete teardown and rebuild (which they won't do). The solution? $6,000 in parts and labor to replace the entire transmission - on a car my brother spent $13k on. My brother ended selling the Jetta to a mechanic at a pretty big loss and he'll never buy a VW again.
    So, it's pretty mind boggling weighing out my options. :p
  8. a_gray_prius
    2,927
    782
    IL
    Given that you don't drive a whole lot, what about just picking up an old Honda Fit? It's not necessarily exciting, but it'll be reasonable up front, reliable, and cheap to run. The suspension on the first gen Fit Sport is really good too (I remember reading that at the time it had the highest speed ever recorded for some car magazine's lane change test).
  9. CptChnk
    CptChnk New Member
    Tempe, AZ
    Yeah, I was just looking at the Fit. I suppose I'd have to drive one to get a feel for it.
    I was reading though that the 2nd-gen model is better in regards to driver seating position (the steering wheel is adjustable, whereas it's not in the 1st-gen). I tend to like the steering wheel positioned lower than most people do - I'm not a very big person.
    I was also reading that because of the small engine, the manual is the all around better choice. I actually prefer sticks over autos (my last two VWs were sticks). VW's DSG transmission on the GTI made me a believer in getting an auto because it feels nothing like a typical slush box. I've found that manuals are relatively hard to find on the Fit Sport models (the Sport would be my preference because of the tighter suspension).
    I actually got an opportunity to drive a friend's 2nd-gen Prius (2006, I think) the other day. Unsurprisingly, it's no equal to my GTI in handling and steering feel. I've found that you also have to make several adjustments to your driving style to truly maximize the gas mileage (but I came in expecting this). I was told by my friend that when he lead-foots his Prius, it gets around 35 but it'll manage close to 50 when he drives "ideally". I'd be interested to know though how different the Touring model feels. Supposedly, it has stiffer suspension (aside from larger wheels) at the expense of a couple mpg.
  10. rbtsack
    rbtsack New Member
    Pennsylvania
    CptChnk- my wife and I recently sold our 2006 Audi A3 for a Gen II Prius (2005). As you know, the A3 is quite similar to the GTI, with larger wheels, DSG transmission, etc. But we had about 75k on the Audi, it was out of warranty, and repairs were pricey. We are both in grad school and it just seemed silly to pay the premium to maintain the Audi (not to mention the 93 oct fuel). So we decided to sell it for something more reliable and fuel-efficient as a long-term savings move.
    So far we have been in love with the Prius. What I miss in power and handling I gain in the little quirks that make the Prius unique. Driving can become a "game" to get the highest MPGs possible. The utility of the hatchback is amazing. The A3 is also a hatch, but the Prius seems to have a much larger interior compartment and more trunk clearance for large items. It's fun to maintain the Prius. It's dorky, but we embrace that. We save money on gas, repairs, general maintenance, and we even saved money on the transaction (selling the Audi and buying the Prius). I also feel totally comfortable with the long term reliability of the Toyota engine.
    And in case you haven't figured this out yet, PriusChat is a wonderful resource. In fact, one of the things I love most about the Prius is the active online community. There is some pretty amazing research going on out there.
    Let me know if you have questions...good luck!
  11. CptChnk
    CptChnk New Member
    Tempe, AZ
    Thanks man!
    Yeah, the GTI and the A3 are practically the same cars under the hood. The Audi is just a bit nicer.
    Like you were, I'm just concerned about the future of this car. Not my first VW but probably (and finally) my last. This month, I'm getting new tires put on the GTI and I'm taking it in for maintenance and checkup. But shortly after, I think I'm pretty convinced it will go up for sale.
