thinking ahead to winter (wheels and tires)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cutter44, Jun 10, 2015.
  1. cutter44
    cutter44 Member
    213
    MA
    I'm in MA, and after last winter, I need to give serious thought to how this C will handle my daily (long) commute. I've read though most of the threads here regarding snow tires, and here are my questions.
    My C 4 has 16" wheels with 195-50-16 tires. When I start looking for cheap-ish steelies and decent snow tires for the winter, should I stick with 16" or would I be better off going with 15"? If I do go to 15", is that likely to screw up my odometer and speedometer?
    As for wheels, will any 4 lug 15" (or 16") steel wheel work or do I have to look for wheels that actually came off a Prius? Likewise tires. Once I decide on 15" or 16", should I try to stick with the same 195-50 width and aspect ratio? Anything else I have to be really concerned with?
    Thanks for any input. I'd rather not wait until November to think about all this.
  2. Mendel Leisk
    42,364
    Aren't there some Prius c with steel 15" rims and all-seasons, at one of the levels? Just get four of those rims, and snow tires in the OE size? Then the odometer should stay (roughly) the same, accurate. See if you can skip the TPMS and wheel covers, and you'll have a kosher snow tire setup. :)
  3. cutter44
    cutter44 Member
    213
    MA
    Y'know, now that you mention it,I think all trim levels except the Four have 15". And yeah, I forgot about the TPMS, but I'm hoping I can ignore that.
    BTW, when I'm searching for compatibility with parts, what does it mean when the give a reference as VIN B3 (7 and 8 digit)?
  4. cutter44
    cutter44 Member
    213
    MA
    And the more I think about it, I'm strongly considering just taking my chances and not even getting snow tires. If I'm careful, am I still asking for trouble? I'd just as soon save the $$, but I don't want every drive to turn into an amusement park ride, either.
  5. Mendel Leisk
    42,364
    It's a toss-up. I actually wonder why I've got snow tires sometimes, it's starting feel like a California suburb here, of late, global warming I guess.
    Still, if you're getting temperatures below 7C (45F), traction will be better, even on bare roads, with snow tires, due to their softer and better gripping rubber. And with snow/ice, the aggressive tread and dense siping makes all the difference.
    If you've got the storage space and wherewithal to swap the tires yourself, it affords you an opportunity to detail your nice alloy rims while they're off the car, and keeps them of the road in winter. And as long as your mileage is not so low that you need to replace tires due to age, they're not that much of an expense, you've got more tread depth to go through.
    If you DON'T get TPMS, it's a lot less hassle. You can get the electronics to re-introduce the sensors with each swap, but the price is not trivial. It just get's my back up when the cost of a solution seems to outweigh the problem, I gave them a pass when getting snows.
    The main downsides are extra rim expense, storage, and hassle.
  6. cutter44
    cutter44 Member
    213
    MA
    Thanks for your thoughts. It definitely gets below freezing often during the winter here. If I were to do it, I would definitely get wheels (steelies) and tires for the easier swap. I guess it's just a matter of finding wheels without TPMS? Then it gets into the whole compatible wheels thing. Oy.
  7. Mendel Leisk
    42,364
    Just put in your car info, On Costco or tirerack, it'll show what's available.
    I went with Michelin X-Ice, very happy with them, mpg not bad either. They spend the vast majority of time on bare roads, work out fine.
    One time I put them on, then about a week later asked my wife how they were doing: she'd forgotten the snows were on, lol.
  8. cutter44
    cutter44 Member
    213
    MA
    Just so I understand, let me try a hypothetical.
    Let's say I find another 2012 Prius C whose owner decided to upgrade, and now has a set of OEM wheels and tires for sale. I assume they have TPMS. I buy the set and then buy a set of snow tires and have a shop dismount the OEM tires and mount the snows on the OEM wheels. Then I bring them home and put the new set on my car. In the "olden days", that was it. Is that still the case?
    BTW, Costco and TireRack are just showing fancy wheels when I search and I just want your basic cheap steel wheels.
  9. Mendel Leisk
    42,364
    Two problems:
    1. It's very rare for seller to part with TPMS. They're easily transferable to whatever new rims he's getting, and his car "recognises" them. If he get's new TPMS, they will have to be initialized. And their cost rivals aftermarket alloy rims. Each. So, very rare event.
    2. If you were to get TPMS from seller, your car won't recognize them. You'll need to get them initialized, which is somewhere between $50 and $100 through the dealership. Or you can read up, get the electronic equipment required, start doing it yourself. And the process needs to be repeated every time you swap between tire sets.
    I think it's now legislated in the States, you're supposed to maintain TPMS all the time, regardless of what's on there. I don't believe it's the law in Canada as yet. I'd think you should be able to skirt the regulation for snow tires. Well, I'd hope so. If not it's going to cause an underground install business and/or a reluctance to get snow tires. The current Toyota iteration of TPMS is, in a word: onerous.
    What I did was get four steel rims, with regular (non TPMS) valves. No level of Prius Hatchback has a steel rim: it was explained to me at one dealership that it's a "flagship" vehicle. I phoned a few more and one suggested a Corolla rim. They also suggested plain, open-ended galvanized lug nuts. That's the route I went, I think the rims through them were $70 apiece.
    #9 Mendel Leisk, Jun 11, 2015
  10. cutter44
    cutter44 Member
    213
    MA
    Thanks. I did see you mention that fact in my previous searches here. I'd be fine with plain steel Corolla rims. For that matter, will any 15" 4 lug steel wheel fit my C? or are there other things I need to be specific about? Well, besides making sure they don't have TPMS sensors? And if they do, can the sensors be removed easily (by me)
  11. Mendel Leisk
    42,364
    Rims don't come with TPMS sensors. Also, for fit I think your best bet is the Prius c steel rims. The only reason I mentioned Corolla rims is there's no steel rim option for the regular Prius.
    It's a little presumptuous of me to keep suggesting steel rims; some go with aftermarket alloys. Still, steel rims, preferably stock Toyota rims, will be cheap, compatible, and have the snow tire "look". :)
  12. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    Living in MI I absolutely believe in snow tires. I grew up in the Boston area some 50 years ago and also used snow tires then, I'm sold on them. My C2 came equipped with steel rims. I was able to obtain new snows mounted on new Scion steel rims on Ebay at a reasonable cost. I had my local tire dealer install TPM's. I wish I hadn't done that. Apparently the Toyota TPM system can only accept so many codes. Every changeover requires resetting the TPM system. Although done at no cost to me, the resetting usually has to be done several times to take, a pain in the rear. My advice get snows on steel rims and forget TPM sensors. I should add, however, that I worked as a semi-truck driver my whole 50 year working career. Even with working TPM's I check the air pressure in my tires weekly. If a person is unwilling to check his/her tire pressure on a fairly regular basis TPM's are a good idea. I've driven my C2 through 2 MI winters and have never even come close to getting stranded.
  13. bill03060
    bill03060 Junior Member
    Nashua, NH USA
    2022 Prius
    XLE AWD-e
    This was my first winter with my Prius v. I went to a local tire store and bought 4 steel rims, about $65/each. I took them to Costco, during their Michelin sale and bought 4 new Michelin X-Ice 3 tires and had them mounted, without TPMS. You'll just have to put up with the little annoying indicator on the dashboard for the few months you run without TPMS. When I swapped back to original tires, the TPMS light went out. My partner put the similar tires on his Prius C last winter. He had to go to work (41 miles each way) during one of the blizzards and didn't have any problems with the snow.
  14. cutter44
    cutter44 Member
    213
    MA
    Thanks, all. That's what I'm looking for; cheap steel rims that I can mount snow tires on without TPMS. My concern is how specific I might have to be regarding other dimensions of the wheels/tires. Apparently all 4 lug 15" steel wheels aren't the same. 15x5, 15x5.5, 15x6, 4x100 bolt pattern, etc. And that's just the wheels. It's enough to make one crazy. :)
  15. Mendel Leisk
    42,364
    Check the price of the proper Toyota steel rims, you might be surprised.
  16. cutter44
    cutter44 Member
    213
    MA
    In doing more research, I happened upon this gem of an article. I don't know when it was written or if things have changed since it was written, but it was rather enlightening. TIA and NHTSA Discuss Tire Pressure Monitoring Systems
    I found item #2 particularly interesting in light of this thread.
  17. Mendel Leisk
    42,364
    Very good find, thanks! I've bookmarked this. In Canada I don't believe it's advance to this point. When I got my snows on rims, through a dealership in late 2010: the service writer quite humorously asked if I wanted TPMS sensors on the new rims, while not too subtly shaking his head. :whistle:
    One thing I can see this doing is advancing sales of "4 season tires", as replacement on the OEM rims (with the original TPMS sensors), as it becomes increasingly onerous to have snow tires on rims. The various scenarios put owners AND shops in a frustrating place.
    Maybe there could be a legal argument in the courts: that the need for safety of decent snow tires at reasonable expense, without onerous and ongoing TPMS related expenses/hassles, outweighs the need to monitor tire pressures.
    Or, that Toyota is responsible to design a system that does not have the current $ and hassle factor.
    I like the latter, I'm not a luddite, like the safety factor of TPMS, but...
    #17 Mendel Leisk, Jun 14, 2015
  18. Mendel Leisk
    42,364
  19. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    for Mas I'd consider getting Nokians. They are all-season low rolling resistance tires which do well in snow. eNTYRE comes in 195/50R16. WRG3 unfortunately doesn't but 205/50R16 is +1.7% to Four stock and +0.4% to all other trim stock 175/65R15, close enough should not be a problem if you replace all 4.
  20. Mendel Leisk
    42,364
    That's the thing: mandatory TPMS, in particular implementations with high inititial and ongoing expenses, are discouraging sales of dedicated snow tires.
