Thinking of joining the club need advice.
Discussion in 'Gen 2 Prius Main Forum' started by Jellyman, Feb 28, 2012.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    As "The Critic" rightly pointed out, it could work out cheaper in the long run, even if you just threw those tires away. Those tires could be costing you more 10% in FE and well more than $500 over the life of the tires.
    In my opinion it's silly to use non-LRR tires on a Prius.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Of course, it's also possible that he removed the good LRR tires for his own use and put cheap ones on. ;)
    As others have said, LRR tires pay for themselves in the long run. It's not just the mileage, but they're likely better quality tires. For high mileage many swear by Goodyear Assurance FuelMax: not a winter tire, but as long as you take care you can get through winter. And they have max sidewall of 51psi so you can comfortably inflate them to high pressures. You might be able to sell the Kendas to someone with low miles for whom cheap is best.
