Thinking of trying a 5w40 Oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cooker, May 25, 2012.
  1. Cooker
    Cooker Junior Member
    34
    Grand Rapids, MI
    On my 2005 with 234k miles on it the engine has a bit of a piston slap. Its not severe but the noise is there and I have been trying a few different 5w30 oils to try and quiet the noise a bit. I have found some better than others but since its time for an oil change again I am considering bumping up in viscosity and giving a 40 weight oil a try to see if a little heavier oil might help it out a bit.
    I would like some opinions on running a heavier oil in the Prius. It seems like if the climate is warmer a heavier oil is approved in the Prius (like a 15w40 or a 20w50). I dont know why I would have any issues with a 5w40 and they are generally a very robust oil with a great additive package.
    I appreciate your comments.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Outside the US this isn't the case though. One of the members from Ireland stated that his Toyota dealer had always used 10W40 in their Prius and there were no adverse effects (the user however is now doing his own oil changes and uses 5W30).
    My 2005 Prius handbook specifies a range of oil viscosities depending on the minimum temperatures encountered. However 5W30 covers the widest temperature range.
    I don't see any harm in the OP trying a 5W40 (or even a 10W40) over summer, especially on an engine with so many miles on it. Cooker, if you do give this a try could you please try to document any MPG changes that you observe. I'm sure several people would be interested in the results.
    Data Daedalus likes this.
  4. cnschult
    cnschult Active Member
    772
    97
    Michigan
    I think the only downside will be a slight decrease in FE.
    why do some on here say 5w30 is the only choice, I just put in 0w20 in my 2004, did I make a mistake?? I'm in Michigan so no hot dessert driving.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I did not say it was the only choice. I started by saying it was his car. I showed that it is the only grade mentioned in the 2005 manual, which Uart pointed out was the US manual. Other manuals my list other grades.
    It is a 2005, it is not like you can use the 'what about the warranty?' card, he has no warranty. 5w-40 will be cheaper than an engine rebuild, which is the 'right' answer.
  6. Cooker
    34
    Grand Rapids, MI
    Yes it seems in other countries the manual for the Prius list acceptable oils as 15w40 and 20w50 depending on ambient operational temps so I see no reason why the 5w40 would not be a perfectly acceptable oil for the car. Again, other than the "possible" (Im not quite convinced I will see much) loss in MPG.
    In regards to 0w20. I think Toyota USA has a TSB about back spec'ing the approved/recommend oil for the 2005 to their 0w20.
  7. Patrick Wong
    18,210
    6,526
    If you have such a document, please post it.
    There is a TMS USA TSB which allows use of 5W-20 in certain Toyota engines previously spec'd for 5W-30 but Prius was specifically excluded from that list. As far as I know, 5W-30 remains the only viscosity approved by TMS USA for Classic and 2G Prius engines. It is true that other Toyota distributors elsewhere in the world may have approved a wider oil viscosity range.
    Use of 5W-40 in the summer should be OK but you may notice reduced fuel economy. That heavier viscosity in the winter may cause engine no-start issues.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Some people have had good luck on the oil consumption side with an additive like Lucasoils HD or Synthetic Oil Stabilizers. You can get the same effect by adding that to 5W30, plus get whatever magic they have added to the container.
    How much time do you spend at 1 bar on the battery gauge? If the engine is weak, SoC can fall all the way to 30% under certain conditions. That will kill it quick.
  9. Cooker
    34
    Grand Rapids, MI
    I have never seen 1 bar on the battery gauge. Oddly enough I dont think I can ever remember seeing less than half.
    I am confused how a 5w40 could possibly cause a no start issue when a 15w40, and even 20w50, is approved for the same engine for vehicles being sold in other countries. They are both 40 weight at operating temp and the 5w resolves any cold weather starting issues the 15w, or 20w, might have possibly had.
    And no, I do not have such a document. I said I think Toyota USA has produced such a document. Apparenly is was not Toyota USA but Toyota in other regions of the world.
  10. northwichita
    481
    102
    29
    Wichita KS
    Are you sure about your diagnosis? Piston slap or possibly lifter ticking? Have you done a valve clearance check?
    I did one on my engine, found slight over clearanced exhaust valves, and after rounding the allen head plug which accesses the cam chain tensioner, decided to just leave it unchanged for a while. Just throwing an alternative out here , am still curious what other high mileage prius valve clearances are.
  11. Cooker
    34
    Grand Rapids, MI
    That's a good thought on the valves and I guess I should at least check the clearaces. From my past experience with automobiles, I do not feel that it is a lifter noise that I am noticing but I think I might consider checking the valve clearance non the less.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    The way I've heard it explained is that the Prius will detect slow cranking and throw a code (and fail to start). It does this to protect itself, since the "starter motor" in the prius is about 10 times more powerful than that of an ordinary car. So it's to protect itself if something is seized.
    It wont happen unless you combine both an overly thick oil AND extremely low temperatures. At summer temperatures it's not going to happen, not even with 20W50 oil (not that I recommend this btw).
    For example, at 50F a 5W40 oil is VERY much thinner than is a 0W20 oil at 20F.
  13. Cooker
    34
    Grand Rapids, MI
    Thank you for the comments and I can completely undertand that could happen with a 15w or a 20w in the colder winter months but the 5W is unchanged from a 5W30 to a 5W40 so when cold the oil meets the same requirements as set forth by Toyota for cold weather operation.
    When warn the oil would be thicker given its higher grade, but this is when the oil is warm. So at operating temp the oil is the same grade of oil as 15w40 oil that is approved for use in other countries.
  14. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Save stop-leak (and even this is debatable), there is NOTHING you can pour into a car to fix a mechanical problem. You're only masking a problem until it becomes bigger.
    If you're hearing a metal-on-metal noise, you better fix whatever's clanging together, until you experience catastrophic failure. Your choice, small repair now, or major replacement later.
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
  16. Cooker
    34
    Grand Rapids, MI
    Well I went with 0w40 Mobil 1. I have only put 60 miles on the car since the change but so far fuel economy seems to have remained unaffected. I will wait until I put some more miles on the car before I compltely pass judgement on the MPGs.
    In regards to the noise, it may be slightly quieter but again I only drove the car on a 60 mile trip so I dont have too much time assessing any possible change. Tomorrow should be more stop and go so I will be able to get more of an idea if it helped.
  17. BillyLhr
    BillyLhr Junior Member
    I live in Lahore- Pakistan, and drive a 2007 Gen 2 with 200,000 KM( 124 K Miles) on the clock, where the summers are long and hot. The temps here peak at100 F for months. In winters the temps rarely fall to the freezing point. I have recently switched to 20 w 50 (Zic Hiflo) from 10 W 40 Mobil- Driven 3000 KM with no issues so far and with a bit of carefully driving I am getting 50+ miles to a US gallon ( yes I did my math right :) one reason for getting good mileage could be the temps that now a days are moderate I'm neither using Aircon nor heating
  18. MidnightSun
    MidnightSun Junior Member
    NorCal
    Any updates on 0w40?
  19. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Thanks for the input on your engine oil choice switch. You appear to be operating your Gen 2 in a hot climate zone. I would suggest using your AC regularly in hot weather, as this will be directly contributing to the cooling of your HV battery and will prolong its operational life.
    Gen 2 Prii operating in very hot conditions have been known to suffer premature traction battery failure. Using your AC more regularly will reduce this factor. Also, unlike ordinarily ICE vehicles, the AC on a Prius will not cost you as many MPGs, especially if prudently configured to run.
    The correspondingly MPG trade off is worth the long term extra cooling protection of the HV traction battery, methinks.
    iPhone ?
    MidnightSun likes this.
