Third day with new car, dead 12V battery, second day in a row :(
Discussion in 'Gen 5 Prius Main Forum' started by mountaineer, Jul 30, 2023.
Tags:
  1. soft_r
    soft_r Active Member
    180
    146
    Beverly Hills
    2024 Prius
    Ok, but at no point did I say to put the car in the accessory OR the ready state. Either of which may trip that 8A limit.
    The negative side is the simpler side to go inline with since the positive side has that distribution block on it.
    All you're doing is putting the multimeter in line then closing the hatch/doors and locking the car then walk away. Might even be a good idea to just lock the doors manually. My 10A fused meter handled my old junk car just fine. Though I also didn't throw it into accessory or ignition while it was hooked up. Cause that would've been silly.
  2. midcow2
    midcow2 2023 Prius LE Supersonic Red
    Houston
    2023 Prius
    A lot of people on the Lexus NX forum are having 12 volt battery problems mainly due to two things: leaving ACC on too long and 2. Digital Keys parasite battery drain.. There are some band aid fixes, trickle charger or bigger 12 v battery. Don't count on Toyota/Lexus to come up with a fix anytime soon going on 2 years with NX problem.
    douglasjre likes this.
  3. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    It seems that the charging regimen of the Prime is quite different from that of the regular hybrid. Have you asked Toyota if the pattern you're seeing is normal? Perhaps they can explain the "logic" behind it.
    I have a voltmeter plugged into my accessory socket and also have a similar bluetooth monitor. When I'm driving my LE the voltage increases to well over 14v while the battery is charging. I mostly do short trips (generally total of ~15 miles or so) with several stops along the way. So it's almost always in charge mode unless I take a longer drive. When I get home the voltage is usually in the range of 12.5 to 12.6v.
    I recently didn't drive the car for 5 days. When I drove it again the monitor reading was ~12.08v. That's sitting in the carport before I unlocked and opened the door. It started right up. During colder weather (cold for Florida) I went 6 days without driving and voltage was about 11.95v. Started right up.
    Can you switch your monitor to display voltage instead of state of charge (SOC)? I wonder if the pattern will be the same. My monitor only graphs the voltage. It shows SOC but the % shown doesn't coincide with a table someone posted a while back so I don't really trust the SOC%. The voltage readings on both devices are accurate though and agree with a multimeter.
    I only do spot checks and only rarely at this point since I've never had a problem. Just checked and it says 12.15v, "battery normal", "electricity 92%".
    From what I keep seeing here, the Primes are much more likely to have 12v battery issues. What is it about the Prime that would require the 12v charging regime to be different than the regular hybrid?
  4. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    “My monitor only graphs the voltage. It shows SOC but the % shown doesn't coincide with a table someone posted a while back so I don't really trust the SOC%.“
    So how do you figure soc by the charts when the voltage is 14.5? I am sure the monitor isn’t just taking voltage, then calculating soc. We use soc all over the place, phones, cordless power tools, etc, and accept the magic inside. When I manually charge it goes to 100% soc. It doesn’t stop at 99, and doesn’t go over 100.
  5. 23PriLE
    23PriLE Member
    95
    67
    2023 Prius
    I totally ignore SOC for the 12v. All I care about is whether or not it has enough voltage to start the car.
    Monitoring SOC makes sense with devices like phones, iPads and laptops. That's because they are expected to be able to operate all the way down to 1% SOC, after which you recharge them. Their usable range is extremely wide. And, unless you keep them plugged in, they are not designed to recharge while in use.
    A 12v car battery is not expected to drop down anywhere close to 0% SOC. I assume that the bluetooth monitors use some sort of software calculation to extrapolate a SOC figure. Apparently different software comes up with different figures.
    That's why I asked if @onthesalt 's monitor could also display voltage. Voltage is voltage, it's not a calculated figure that's linked to the specific needs of a particular device. Two devices might both say they are at 1% SOC yet the voltages might be quite different depending on the device. Or, to look at it another way, a certain voltage might equate to a 10% SOC on one device and 25% on a different device.
    A complicating factor is that the 12v in a Prius doesn't start the car the same way as a 12v used in a normal ICE car. The ICE car requires a certain amount of amperage / "cranking power" to run the starter motor. The 12v in the Prius just needs to have enough voltage to power up the car's computer. This doesn't require much amperage, which is why their 12v batteries are much smaller. As far as I know, the BT monitors are not specifically designed for hybrids so it's likely that their SOC figures reflect battery conditions that are required to start ICE vehicles, which make up the vast majority of cars on the road.
    Here's the chart that someone posted elsewhere. My monitor says 12.15v is "electricity 92%" but the chart indicates it would be ~55% SOC. Whatever the SOC is, I've had no issues even with a voltage as low as ~11.95v.
    When I first got the car I found a post (not sure which forum) by an owner who said that they only had issues when the voltage dropped to ~ 11.7v on their earlier generation hybrid Prius. The car's computer started exhibiting odd behavior and would not go into Ready mode so they replaced the battery, which was about 10 years old at that point.
    I'm not sure what the minimum voltage threshold might be for the Gen 5 hybrid. Apparently, the Prime is less forgiving.
    Regardless of what the car is doing during 12v charging - driving, sitting in Ready mode or plugged into the wall - the battery should measure higher than the nominal 12v while it's charging. As the battery is charged, the voltage will drop down to nominal voltage. On a longer trip, my voltage will eventually drop to the 12.5 to 12.6v range after it's charged.
    GcinFl likes this.
  6. Gokhan
    Gokhan Senior Member
    6,242
    2,476
    Paramount CA
    The voltage listed in the table is the open-circuit voltage, which means that the battery must be disconnected to measure it. If that's not practical, then you need to make sure that everything is off so that the current drain from the battery is minimal. Otherwise, there will be a significant voltage drop across the internal resistance of the battery due to Ohm's law, subtracting from the open-circuit voltage.
  7. 23PriLE
    23PriLE Member
    95
    67
    2023 Prius
    I just reposted the chart since I mentioned seeing it previously. I don't consider it particularly useful.
    The bluetooth monitors seem to be the most practical method of regularly measuring the battery with "everything off" as their current draw is minimal.
    How much voltage is required to put the car in Ready mode? That's what really matters. I know that 11.95v is sufficient for my LE but I don't know how much lower the actual threshold is. It may be different for the Prime. Hopefully some Prime owners will report their voltages after the car fails to start.
  8. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    I probably have seen those charts for 40 years. Soc viewing is the same for anything. I charged my Prime 12 v overnight last night because it was at 70 % soc. I charged my phone because I saw 38%.
    My gen 2 was not good to the 12 v battery either. I never used anything but a volt meter to check it, or the dash display, Don’t need to play around with that now.
    The sensor on the battery is the same for prime or hybrid and some other toyotas. Im thinking they need to revise the ecm program, but so would many other makes of hybrid and electric cars. It’s actually sort of strange why this is so common a problem.
  9. Yvrdriver
    Yvrdriver Member
    47
    42
    Vancouver
    Was reading the reddit Prius board and saw this comment:
    So Toyota has updated charging ECUs for the prime? I assume this is some kind of software update?
  10. KMO
    KMO Senior Member
    1,963
    687
    Finland
    2023 Prius Prime
    There have been complete replacement charging units for early cars - there's a replacement part number for the whole assembly.
    That's not related to any 12V battery issue though - some sort of fan or fan sensor problem. That could be what he's getting - he's got it fixed in his mind that his 12V battery issue is a charger problem, and the dealership may have checked that his vehicle is eligible for that replacement.
    But apparently there is a TSB for a batch of bad 12V batteries (both Prius and other models).
    Yvrdriver likes this.
  11. Yvrdriver
    Yvrdriver Member
    47
    42
    Vancouver
    Yeah, I heard about the TSB. Hopefully it is available online at some point. I’m curious as to what it says…
  12. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Well, I posted in March in this thread that my 12V died and tested as defective and was replaced under warranty, and all was fine until this weekend when it needed a boost again.
    However, it was different this time, starting with the battery was not completely dead, it had some charge, not enough to power the car up, which was odd. It started when I was sitting in my car testing if my old dash cam was still working, using the 12V accessory, and the car was in “On” mode, not Ready (which I realize was my mistake, but I figured for the 3-4 minutes I needed it would be fine). I struggled a bit with getting the camera to work, so it was perhaps 12-15 minutes I sat in the passenger seat in Accessory Mode, with all windows lowered for air.
    All of sudden “parking brake unavailable” popped up on the display, then the screen starting blinking on and off. Very alarming experience. I reached over to press the brake and power, but wouldn’t start. I went around and sat in the seat and it would not start either. Turned off, waited a few minutes, no change. Someone on Facebook actually posted a video exactly like what I experienced:
    https://www.facebook.com/share/v/trJdPKAJC6u9k9Xq/?
    Other strange behaviours I noticed during this time:
    - The radio had shut off by itself when the parking brake message appeared (presumably to save power)
    - I could roll up the rear windows, but the front windows would only go up 1/4” at a time. I had to repeatedly click the switch many times to inch them back up.
    - The exterior piano chime stopped (would only hear the click of the door locks)
    - I could open/close the rear power hatch, but the movement was noticeably slower - which made me more confident it was a low 12V
    When this happened, it was alarming, as I never saw a “low battery” message like last time, I was starting to become concerned something more serious was wrong, even if the hatch seemed to suggest it was just a battery.
    I put a call into Toyota Roadside and a guy came with a booster pack, and it boosted and started up pretty much immediately, so that was a relief. Went for a drive to recharge and all seems well.
    Interestingly, the car did “forget” some random things - driver profiles, DriveConnect wouldn’t connect on the first drive (until I rebooted), and some of the driver safety settings and camera settings reset to default. No big deal.
    I will probably have it tested again at some point, but thought I would share the experience here in case others encounter this…. Don’t be stressed. :)
    Moral of the story: Do NOT use Accessory/On mode in this car, even for a few minutes. o_O
    chris johnson 2 and Gokhan like this.
  13. Gokhan
    6,242
    2,476
    Paramount CA
    Was the first replacement battery a Toyota TrueStart?
    Sarge likes this.
  14. BiomedO1
    BiomedO1 Senior Member
    3,655
    1,890
    SacTown, Ca
    If you have a DVM, I'd be interested in the current voltage reading on your battery. I'd bet it's right around of just below 12 VDC.
    Weird things happening is normal when electronically controlled ECU's are subjected to low voltages. It's like low blood pressure in a human body, stand up too fast - you can end up falling over...
  15. Gokhan
    6,242
    2,476
    Paramount CA
    Probably not. It is probably almost empty. Give it another day, and everything will go dark.
    And once this happens, the battery loses half its capacity due to sulfation, and recharging won't help it, and you need a replacement.
    RandyPete likes this.
  16. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    I’m not up to date on this. What 12 volt charger is being discussed? The car has a dc to dc converter and I thought the battery sensor on the negative terminal regulates charging, but I don’t know how.
  17. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    (y) I strongly support the moral of the story ......they left the Accessory/On mode ...I really don't know why ? .........must be a legal thing ...or an obession to keep this fonction alive as a legacy.:confused:
    Sarge likes this.
  18. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Is there any way you could post that TSB ?
  19. Gokhan
    6,242
    2,476
    Paramount CA
    GS Yuasa = bad battery. ;)
  20. RandyPete
    403
    167
    2024 Prius Prime
    XSE
    My experience with 12v battery in '24 PP XSE has tought me that.
    But is there Toyota TSB that indicates the same ?
    Gokhan likes this.
