Third gen engine coolant bleed bolt or coolant temp sensor??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kobear18, Nov 11, 2021.
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
    I'm still trying to fix my prius over heating / blown heat gasket problems. I replaced radiator, water pump and thermostat. Yesterday, I drove it for 6 hours freeway uphill, down hill and some local roads and finally it leaked coolant and over heated. I will need to find out where the leak is. Maybe water pump or radiator. I used a non-brand water pump. The coolant leak only happened after 199 F. Or maybe over heating blown the head gasket again LOL!! But anyways, I may need to use bar's leak again but I will pour it in from the heater hose and only let it run until temp reach 170. I also want to bleed air out too. I saw another post about removing coolant temp sensor mentioned by Mendel and Sergey K. I think Mendel called it "engine coolant bleed bolt". I took some photos. Should I just turn the white cap to release air or that sensor on the left is the coolant temp sensor?
    I read that Sergey solved his over heating problem by removing that thing while bleed air. So which thing? Turn white cap / blot or that thing on the left ?
    Photos
  2. Mendel Leisk
    42,362
    Thing on the right is the bleed bolt. Unscrew it (counterclockwise) a few turns and it's open at that spigot on the right side. You can push a tube onto that, keeps from spilling coolant, and also makes it more visible when it starts to flow out.
    You're still running with an ailing head gasket right?
    From the Repair Manual, very sketchy illustration:
    Excerpt attached:
    ThePrius11 and DruidArena like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Your root cause is the blown head gasket since July 2020 which was bad enough to cause white smoke. And the loosened radiator cap which lowers the boiling point of your coolant. Plus four cans of leak sealer when the instructions say use 1/2 a can for this size engine. You need to fix the engine.
  4. Mendel Leisk
    42,362
    Dutch Uncle intervention time :)
    ThePrius11 and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    If you can see their comments;).
    Our usual suspect in this category I have on "ignore user" functionality:).
    Saves some time and angst(y).
  6. kobear18
    92
    23
    san francisco
    i will provide update later but I think the best bet is only drive it for 1 hour MAX and needs to stop for 30min before it drives again. This is what needs to be followed after blown head gasket even after using head sealant. It is a temp fix not a long term perm fix. It only works under certain condition. Pouring the sealant from the heater hose seem to work better because it doesn't go to radiator under 172 F. I will rinse the heater hose after sealant application too.
  7. kobear18
    92
    23
    san francisco
    updates: Head Gasket has been sealed but water pump stopped working a few days ago. I saw temp went to to 240 for a few seconds and then dropped back down to 230, 220 and then 200, 195. It should be this high. However the car still runs and no engine codes. Today I put it on maintenance mode and temp also went up rather quickly but no white smoke, no codes and everything seems normal. I put my hands on the heater hoses, they are all cool not even warm and felt like nothing running in it too. So now I know the water pump maybe the cause. I bought those non ASIN brand from eBay for cheap and thinking that this should give me 6 months to get through the chip shortage LOL!!! NO.
    I think it was all my mistakes anyways. The eBay water pump was running fine and I put everything back together and test drove it on local roads for almost 2 weeks already before I got on a 200 miles road trip on freeway a few days ago. It over heated and I immediately exited and inspected it. The lower hose of the coolant expansion tank below off and all coolant leaked out. WHY? It was my mistake. I did NOT clamp those hoses back up. The upper hose of the exp tank was not clamped either. But I clamp it all back up and then bought another gal of coolant from O' reilly and put it in. I was able to finish that 200 miles trip and back. However, it over heated again for about 1 min when I was only 15 miles away from home. It dropped back down to 230 and I exited the freeway and drove local roads and it stayed around 195 until I got home. Yesterday I only drove locals too but it also over heated so I know something is wrong but I eliminated the head gasket problem because no white smoke and no coolant loss and no codes. I have seen some youtube vids showing that there is no water pump code if the center pole is spinning but the propeller is not. The computer thinks its still running so NO codes. I think that is what happened to mine and both heater hoses are cool so now I know the coolant is not flowing. I will get a new ASIN pump then.
  8. ChapmanF
    19,041
    They added a "spins too fast" code for that, P148F, for 2011, but if you have a 2010, no code for you.
  9. DruidArena
    DruidArena New Member
    Houston, TX
    So what is the item circled? I've gotten mixed information between that being the ECT sensor, vs it ECT sensor being under the EGR cooler.
  10. DruidArena
    Houston, TX
    Also, my 2012 V's bleed bolt looks a little different - is that normal (since it's also 3rd gen)
  11. Mendel Leisk
    42,362
    Red circled “I believe” is a coolant temp sensor. There’s maybe two?
    your 2012 may not have the bleed function, Toyota nixed it, maybe after 2011
    DruidArena likes this.
  12. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  13. ChapmanF
    19,041
    Right, the one that mounts in the cylinder head is the temperature sensor for the engine, and the circled on on the hose there is the sensor for the coolant coming back from the exhaust heat recirculation system under the car.
    Yeah, it seems they dropped that extra valve pretty early in Gen 3. They also didn't change or add any new instruction steps in the manual for filling coolant (other than to remove any mention of fussing with that valve). They just keep the original instruction to fill to the B line, put the cap on, run the engine long enough, let everything cool, and confirm the level went down to the FULL line.
