This Doesn't Seem Right: Replace Wheel Bearing?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Captain Caseous, Oct 12, 2021.
  1. Captain Caseous
    Captain Caseous Junior Member
    Hello, Everyone. Like others, my Gen 3, 2012 Prius IV with 110,000 miles showed the ABS, Brake & Traction indicator lights. Went to an auto parts store and their code reader said it was a rear speed sensor. Took it in and was told it was both rear speed sensors and that the only way to replace them was to totally replace both bearings for $1,550 (with labor). I couldn't wait for various reasons, but:
    A) were the speed sensors designed in such a way that, if they go, the entire bearing needs to be replaced?
    B) $1,500 seems crazy expensive for all of this. Was I ripped off?
    Thanks for any advice?
    CC
    52,863
    idk about 1, but it is certainly worth getting a few quotes if you can
    Captain Caseous likes this.
  3. amarino
    amarino Active Member
    145
    107
    99
    Took it in where? The dealer? Post your receipt with part numbers, how much for each part, and labor?
    A) Yes according to the TIS (factory manual, see attached)
    • If the sensor rotor needs to be replaced, replace it together with the rear axle hub and bearing assembly.
    • The rear speed sensor is a component of the rear axle hub and bearing assembly. If the sensor malfunctions, replace the rear axle hub and bearing assembly.
    B) Checking just the part prices
    Each hub/bearing is ~$300:
    REAR AXLE SHAFT & HUB. 2012 Toyota Prius | Toyota
    I can't find the rear sensors but the fronts are ~$200 each:
    ABS & VSC. 2012 Toyota Prius | Toyota
    That would be at least $1000 in parts.
    Captain Caseous and dig4dirt like this.
  4. ChapmanF
    19,033
    You don't pay extra for the sensors. When you buy the Toyota rear hubs, they have the sensors.
    The sensors are press-fit into the hubs. Toyota doesn't sell the sensors separately.
    You might be able to find some aftermarket brand that sells hubs and sensors a la carte.
    But if you remove the hub so you can take it to a press and change just the sensor, you will probably trash the bearings in the course of getting the hub out of the car (at least in a region that salts any roads).
    Then you need the hub anyway. Probably why Toyota doesn't sell the pieces separately.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    I recently changed my two rear hubs. Bought Timkens which look identical down to the serial number. About $200 each which includes the non-replaceable speed sensors. My issue was a howling rear bearing. About an hour and half of work, primarily because one was rust welded and required a slide hammer, rented free at the local O'Reillys. Even if you pay a mechanic two hours you might be out $600. Half if you do just one. There are far less expensive hubs but most are likely to fail in a year. A 2012 Prius rear is Timken HA590373. I would verify.
    A comparison of my Prius v parts
    #5 rjparker, Oct 12, 2021
  6. Captain Caseous
    Thanks, everyone. Looks like it was how it was designed, though strange, and the numbers are in the ball park. Appreciate the commentary and examples.
    amarino likes this.
  7. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Here n NC the just fall off after smack w hammer . I bought similar to above . Complete 147 for pair . It’s ok if they fail n 5 yrs I’ve front and rear susp components loaded ready to go as we hav 3 gen 3 now and 2 gen 2. So it’s easier to keep things ready to install. As the cars are making 75 to 260 miles per day
