This had been KILLING my mpg!
Discussion in 'Gen 3 Prius Fuel Economy' started by dhendriksen, Jan 2, 2013.
  1. Ragin Cajun
    Ragin Cajun Junior Member
    52
    16
    The other morning at the Grand Canyon.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    now we are talking... another 10 off that and that is what we had for three weeks ending a week ago. got 34.9 mpg for period.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ouch
  4. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    No, I'll show you what hurts your mileage... House thermometer said -29 C (-20 F), car said -26 C (-14 F) but it has a very blocked grille (100% lower, 50% upper). :p ;)
    Notice the defroster fan is cranked at heat set to 25C in an attempt to be able to drive safely LOL
  5. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    If it is (- O) F, or colder; block everything; 100% lower and 100% upper, even the side of the hood, where some warm engine heat can get out. Keep engine oil at low mark level, to help keep engine a little warmer.
  6. MattPersman
    MattPersman Member
    110
    33
    Indiana
    Crap this is cold. Coldest I have seen this winter is 9 F and that was yesterday morning. You guys got it bad
  7. dhendriksen
    dhendriksen Junior Member
    57
    I need to look in to blocking my grill. Does it really make a difference?
    Droid RAZR HD MAXX
  8. smurs
    smurs Junior Member
    43
    Iowa
    Oh wow. I was wondering if the cold could be killing my MPG. This sucks! I experimented with putting the heat on AUTO the manually turning of the AC. I thought that helped a little but I'm told the AC doesn't actually run when it's cold (? why does it turn on then?). I'm now averaging a mere 39-40mpg.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Remember the days before having a display on your dashboard, when you were blissfully oblivious to the affects of Winter?
    Engine warm-up, winter-formula fuel, reduced combustion, increased rolling-resistance, heavier traffic... factors of efficiency influence for all vehicles that new owners of Prius become painfully aware of as the temperature plummets. With a hybrid, you also get the influence from heater use and a decrease of available battery capacity.
    Every year, it's the same discoveries made by newbies. They eventually figure out, then give thanks when the warmth of spring arrives. The emotion they experience is actually a building-block for the passion often associated with Prius ownership. You feel empowered after learning so much about what had always been affecting vehicle efficiency.
    Those who have firsthand experience with multiple Winters behind the wheel of a Prius appreciate when you experiment and share your finding. Eventually, you will become the teachers of new owners with the very same concerns about suddenly MPG dropping, informing them of the circumstances.
    It would be nice to set expectations sooner. But often, new owners join forum discussions as a result of Winter discoveries... then continue to participate later. So, it works out nice anyway.
    Braddles.au and OceanEyes like this.
  10. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    What is the Penguin Plunge (and are you going to share the photo?)
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    :ROFLMAO:
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    The cold is even hitting the PIP... the cold temps reduce battery efficiency and make the ICE start up to protect the battery from (possible) brake re-gen overcharge when the batts are cold. Fuel economy tanks at that point because the ICE is running (with no contribution to car locomotion) and you pushing the car on electric too till you burn off some EV power and the ICE has completed it's warm-up cycle. To quote Sylvester Stallone it's the old "double whammy"!
  13. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    "Our" Penguin Plunge benefits a local homeless shelter in RI... (I work in RI and can hit RI with a rock from my backyard) with a many Polar Plunges benefit some cause like the Special Olympics or homelessness. Teams and individuals raise money which is a plus but the mob mentality of people of all ages getting ready to rush the season and rush into the water was priceless. A good running start is all it takes - and while some folks considered themselves "plungers" by going in, I took it to the top and dove underwater twice. I was not going to wimp out by just splashing in cold water. Go big or go home. ;)
    Pictures are online... but I am so not sharing them willingly - I do not photograph well but I was told the expression on my face was sheer joy. I survived the year from Hell - a dive in the winter ocean was a cake walk.
  14. Simsonic
    Simsonic Junior Member
    It's 71 here in San Diego. That's bad weather for MPG here. Wish it was 75. ;)
  15. walter Lee
    1,126
    376
    Maryland
    Last Friday, around 6:30pm-8:30pm, my Prius' MPG dropped like a rock (low 20s) when I got stuck in a (+1 hour) traffic jam on I-495 (It was caused by a traffic accident at the spur of I-270. The traffic jam was along the inner loop of I-495 between the I-270 spur/exit and Tyson's Corner,VA Exit 46 ).
  16. Much More Better
    Much More Better Active Member
    655
    163
    IMG_1116.JPG This is during my ride home tonight. We are in for a cold week. I finally got off my butt to grill block 100% after hitting an all-time low of 35.8mpg on my last tank.
  17. MattPersman
    MattPersman Member
    110
    33
    Indiana
    Woah that's cold I saw 5 degrees F a week or 2 ago one morning
  18. OceanEyes
    527
    424
    38.5 mpg today... worst tank ever. :(
  19. john1701a
    12,840
    5,312
    58
    Carry 2 kayaks on top across the state... 36 mpg... which is actually still better than many vehicles even at their best.
  20. pichner
    pichner Metallic Maniac #001
    66
    Minneapolis, MN
    My average seems to be close to that here in frosty MN. Oh well, my Subaru Forester gets 18mpg this time of year.
