This is driving me crazy...
Discussion in 'Gen 3 Prius Main Forum' started by surfdog5, Mar 2, 2012.
  1. surfdog5
    surfdog5 Junior Member
    39
    SoCal
    On my 2012 Prius 2, I can not figure out where to find my total MPG????
    On "trip A" and "B" it's listed, but I can't find where it has my total MPG? Help!
  2. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    Doesn't exist. I use trip A for total and trip B for 'trips'.
  3. surfdog5
    39
    SoCal
    Bummer!
    As far as I'm concerned, that was a bit of an oversight on their part. On my wife's V, you can see total miles and MPG at the same time.
  4. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Ummm, the on-line manual, page 229, indicates you may be wrong. At least as far as the 2012s are concerned. I didn't check the manual for 2011.
    You should be able to cycle through ODO, TRIP A, TRIP B.
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    When you say "total MPG" do you mean "Lifetime MPG"? As in if you've driven 5000 miles, what your displayed MPG is for the 5000 miles?
    Or do you mean when you show the odometer on the display 5000 miles, that you don't see the MPG for the current tank?
  6. surfdog5
    39
    SoCal
  7. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    True, but ODO doesn't have MPG, at least on my 2010 II it doesn't.
    REV
  8. surfdog5
    39
    SoCal
    I have a 2012 and when I cycle through to the ODO screen, the MPG disappears.
  9. volt_killa
    volt_killa volt_killa #ItsATealPrius OPTLMUS
    44
    16
    SoCal/SGV/626
    hit the Trip button to enter each trip mode, then try fiddling with the Display button in each mode to see what you get...
  10. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Lifetime mpg isn't useful information anyway after enough distance.
  11. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    There is no lifetime mpg on our cars.
  12. rsg
    rsg Member
    64
    Harrisburg, NC
    And even if there was, it's still not perfectly accurate anyway. I find that tank-to-tank, the calculated MPG is usually 3 or 4 MPG less than what the computer says.
  13. Codyroo
    1,826
    515
    Pleasanton, Ca
  14. AZGeek
    627
    144
    63
    Arizona
    And it would be cool if you could update and view your Fuelly info via Entune. :cool:
