Those fog light covers
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Frederickdawg, Apr 28, 2016.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Anyone know the correct method in removing the fog light blanking plates on the front bumper?
    Thinking about color coding them to the body color on my wife's "base" looking Prius 4 . thanks.
    LG-H901 ?
  2. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    I don't own a Gen 4, but if it's like other cars you'll have to remove the bumper cover and there should be some tabs holding the inserts on which you can depress and pop them off.
  3. Frederickdawg
    596
    335
    Thanks was hoping that they were just clipped in and be able to remove it with a credit card or something. Oh well.. Perhaps access might be gained when removing under tray. Wish we had access to a workshop manual.
    LG-H901 ?
    ETP likes this.
  4. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Wondered what those were for. Do other models use hose holes for something?
  5. randomwalk101
    randomwalk101 DYI'er
    532
    270
    texas
    You need to take off the inner wheel well to have access to them from the back (unless you want to take off the whole front bumper). Those cover are held in place by a few screws.
    Should wait a bit for the aftermarket to come out...or just get OEM replacement (better quality).
    Luis Jes and Frederickdawg like this.
  6. Frederickdawg
    596
    335
    Was hoping they were just clipped into place.
    Would like to at least get then painted same color as the bumper. Some sanding, priming and paint then clear coat. Duplicolor. Looks so "lame" with black blanking plates like that. In my opinion obviously. Lol.
    LG-H901 ?
    ETP likes this.
  7. ETP
    2,802
    1,170
    Auburdale FL
    I have the fog lights but they do not use those holes.
  8. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    That's a great idea though. I hate those black hole fillers.
  9. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I wonder what they are for?
    Another pedestrian safety device? Perhaps without them the front end of the car would be so pretty that pedestrians would be awestruck and unable to move out of the way. So Toyota dialed the pretty back a notch by adding those ugly plates. There, I've figured it out!
    ETP, Frederickdawg and Mendel Leisk like this.
  10. randomwalk101
    532
    270
    texas
    What holes are you talking about?
    ETP and Frederickdawg like this.
  11. Mendel Leisk
    38,875
    I'm pretty sure this:
    It might be possible to pop them out from the front, using a knife blade. Push on one side, see if that opens up the gap on the opposite edge. That's how I've popped out the tow hook covers on our 2010.
    And if that proves difficult, look underneath, see how the underbody and fender liner is secured. Likely with a few fasteners removed you'd be able to reach in and release clips from behind.
  12. vince22
    vince22 Active Member
    205
    249
    califorinia
    Here's what I did on mine while installing angel eyes, remove 2 bolts from i piece only undercover panel right underneath fog lights.
    Fog light covers was only held by 2 philips screws (top and bottom) a slot clip, there's plenty of room, unfortunately my Eco wasn't pre-wired for fog lights.
  13. Frederickdawg
    596
    335
    Right oh, so they are held in with two screws, thanks.
    I'm assuming to check for pre wired would be seeing if there is a harness plug tied back their ?
    Did you do you write up on the angel eye install? I'd like to get the boomerang DRL similar to some fat Eastern Prius gen 4 models. Also change the front DRL turn signals to switchbacks LEDs.
    LG-H901 ?
    ETP likes this.
  14. vince22
    205
    249
    califorinia
    yes two philip screws and a slot clip, no write up needed, pretty easy straightforward, angel eyes for now ti'll i decide to put OEM boomerang fog lights later.
  15. ETP
    2,802
    1,170
    Auburdale FL
    What hump?:LOL:
    See the color matching decorative plates on pics above. What are those for?
  16. ETP
    2,802
    1,170
    Auburdale FL
    Over to the right 8" where the covers are located. But do have a question about those holes now.
  17. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    Vince those circles look great, especially with your metallic grey color. They really set it off.
  18. Frederickdawg
    596
    335
    On further inspection of the headlights. It appears that the boomerang area above the projector headlights look like a hollow tubing to accommodate light. Toyota probably used different headlights for the far Eastern models that have the white light emitting in those boomerang area of the headlights. Doubt I'll know until headlights removed. At my age I know longer have the patience ( lazy ) anymore. Lol.
    LG-H901 ?
  19. vince22
    205
    249
    califorinia
    thanks Jim.
  20. Frederickdawg
    596
    335
    Right, I had a look underneath the vehicle. Which two screws did you undo to access the back bolts of the fog light covers.
    There is one main cover in the middle area of the front bumper and also one cover on each corner of the front bumper.
    Which one ? Thanks.
    LG-H901 ?
