Those small LED looking lights in the middle of the headlamp??
Discussion in 'Gen 2 Prius Accessories & Modifications' started by macmaster05, Sep 29, 2009.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I just bought a new 2009 Prius!! Although it's used (purchased Feb 09), to me it's only 6 hours old! Here is the first mod I'd like to make:
    You know that middle row of what looks like LEDs on the headlights, how the heck do you make those light up??? I think it would look cool with my OEM foglights and HID headlamps (I got the Touring). What kit do I need to get? Who installs it? How much?
    And most importantly, will that void the warranty for the headlamp fixture/electrical? Thanks.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    most likely the warranty would be voided. opening that casing and drilling the spots out... then replacing and wiring-in LED's is the only way... first you have to bake the casing to open it. there is a mod that 1 person has done themselves. if you search you may be able to find it. there's a lot of LED forums out there...
    congrats on the purchase :)
  3. macmaster05
    4,050
    729
    Thanks Cobrakid, I was looking at the blinglights.com website and thought they would have it, but I didn't see it. I did notice this picture, however, advertising for the fog lamps.
    http://s.ecrater.com/stores/83546/4a0e44a0bd164_83546n.jpg
    This is exactly what I want and what I'm talking about...
  4. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Those are not LED's in the headlight, just a row of of jeweled transparent bumps that may look like LED's. Don't take the blinglights photo as gospel, they know what photoshop is for.
    Wayne
  5. macmaster05
    4,050
    729
    So is this mode even possible?? You think it'd be an easy, or at least common, mod.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's possible, but not common. I don't recall anyone going to the trouble of doing it, although it has been discussed on more than one thread.
    Tom
  8. a_gray_prius
    2,927
    782
    IL
    Some japanese guys have done it. It looks amazing. It's in an older thread in this section. The car has paint from an Infiniti FX.
  9. qmtran
    qmtran Junior Member
    87
    Seattle, WA
    It is possible. And you do not need to bake the headlight. I never did, I have a gas oven and I get scared that I will mess my headlights up.
    If you have a heat gun or a hair dryer that you do not use anymore, all you have to do is slowly heat up each section of the headlight and use a nice flat thin screwdriver or what have you and slowly pry.
    When apart, just drill, add led's w/ a nice epoxy, do your wiring and what not. When putting the headlight back together, you can purchase extra adhesive from a Nissan dealer, I honestly forgot what it was called, but it started with a B. B___ gum?
    But heat up the adhesive until it is nice and warm, and press the 2 pieces back together. Presto... If you opt out of buying extra adhesive, you can always add clear silicone around the edges of the headlight to prevent fogging.
    I will be doing this mod next year. This year all my money went to my racer.
  10. macmaster05
    4,050
    729
    Hey thanks qmtran and everyone else. But I'm going to be honest - I'm scared stiff about baking. I don't even bake cookies.
    Is this a mod that you can pay someplace else to do, including the baking part? How much would it likely be?
  11. qmtran
    87
    Seattle, WA
    If you are afraid of baking, use a heat gun like I mentioned. If you are scared, go on a forum like honda-tech or vwvortex and ask someone to help you. The aftermarket tuner crowd does this all the time. It is alot easier then what you think. Just gotta take that first step and everything will be fine if you are slow and steady. Normally I only work on one headlight per day. Less stress.
  12. selisimo
    selisimo New Member
    Lithuania
    Heating with hair dryer worked perfect for my mazda 3 headlamp :)
    Quite easy job but needs some patience with heating.
    Anyway maybe next week i am planing take apart my prius headlamps ant put some LED into middle of the headlamp :)
    I am planing to use some flexible LED strips for that ( i dont want drill holes)
    When i finish my first prius project i will put some photos.
  13. macmaster05
    4,050
    729
    I would love to see it selisimo!
  14. reagd
    reagd New Member
    Fargo
    I first thought that those brightlights are LEDs. Photochop huh Lolz
  15. sunstarfire
    sunstarfire New Member
    34
    Munich, Germany
    Again, read the posts. The mod is real, a Japanese guy has done it. It's just a heck of a lot of work. Not (!!!) photoshopped.
    Look here.
  16. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    macmaster05:
    They don't.
    I agree.
    Try this guy
    Probably.
  17. kenmce
    1,530
    507
    NY
    macmaster05:
    Yes.
    I would imagine people don't want to take their perfectly good HID headlight housing and stick it in the oven 'cause some guy on the internetz said he did it and it worked out fine. (meaning no disrespect to the my fellow posters in this thread)
    A reasonable compromise might be to buy an extra set of housings, bake them, then swap after you're 100% sure the mod worked.
  18. jonvo
    jonvo New Member
    34
    SoCal
    Baking in the oven is the easiest way to do it. The heat is distributed evenly making disassembling a breeze. Make sure you shut off the heat when placing the headlight in the oven. Additionally, the Prius's headlights are surprisingly on the large side. Make sure your oven is adequate to house such a monstrosity (till this day, Prius reign in this department .... even the 18 wheeler's headlight does not compare!). If it's a tight fit, make sure none of the headlight is touching the oven.
    Prying the lens off is a fast pace ordeal. Before sticking it into the oven, remove the screws ( I think around 2-3) that are holding the headlight lens to the headlight housing.
    Just my two cent.
    Jon
