Those with LED headlights- Would you leave them on to act as DRL's?
Discussion in 'Prius v Technical Discussion' started by TPBC, Feb 5, 2012.
  1. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    I was wondering if anyone was going to mention this.
    I was pretty astounded at how slow the electrons drift around in a conductor. Imagine how many days it would take one electron to leave the battery and run through your motor and back to the battery. heck, just turning on your head lights would take an electron a couple of days to get there and back again.
    Fortunately the electrons don't run out the end of the wire when disconnected.
  2. JStrenk
    203
    101
    Ravenna
    Does anyone know if the LED headlights are modulated like the tail lights in many cars? This is done to get brighter light with less heating.
  3. Air_Boss
    Air_Boss Senior Member
    4,199
    1,184
    New Yawk
    I have the 2012 v Five, as well as the AUTO stalk, and am told by the dealer that despite representations in the owners manual, the car does not come with, has never come with, and has no factory option for DRLs... Hmmmmmm.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Maybe the owners manual is including info for the Canadian Prius v?
  5. fuzzy1
    10,454
    Back in the 20th Century, LEDs were often pulsed to get better energy efficiency. But the loss mechanism that caused lower efficiency at lower current was found and fixed. Today's high brightness LEDs are far more efficient than those old designs, and don't need pulsing for maximum efficiency.
  6. syscon
    syscon Member
    329
    43
    Edm. Alberta
    On Canadian model they used High beam at reduce intensity, the bulbs are Sylvania HB3-9005
    Here is a picture on my after about 10-months of usage; it shows brown deposit discoloration on the corners.
    I hardly have any need of bright High beam headlights so I replace them with 20W CREE LED's to save on energy.
    Instead of waisting the energy on headlights I would rather forward that energy to battery.
    MJFrog likes this.
  7. Tom_consulting
    Tom_consulting Junior Member
    I drive with the headlights on, because the tail lights are on as well. DRL design missed the boat when they did not require tail lights to be on at the same time. I don't know how many times I've come up on a car in low visibility (snow or fog or rain) that had DRLS on, but no tail lights, and they were a danger to everyone behind them! You can fix this fairly easily with a wire and a diode to connect the DRLs to the tail lights. Have not done that yet but if I do I'll post it here.
  8. Air_Boss
    4,199
    1,184
    New Yawk
    In that case you'll only want to drive the driver's side tail light as a fog/position light.
  9. Tom_consulting
    I assume that's because it feeds the passenger side from there?
  10. Air_Boss
    4,199
    1,184
    New Yawk
    No, because a rear-facing red fog/rain/positioning lamp should appear only on the driver's side. It is usually also a separate red segment, so as to differentiate it from a tail/brake/turn lamp.
  11. schinia
    schinia Member
    162
    25
    cape carteret,nc
    until toyota gets their head out of their %^& i will use my led headlights when i feel the conditions call for it, and i won't worry about blowing a bulb.
  12. Tom_consulting
    Well I don't understand that at all. Both rear "marker" lights come on when the headlights come on. That's what I want to come on when the DRLs are on. So wiring the DRLs to the taillight feed should do that.
  13. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    It also doesn't melt snow that collects and covers the light. Though this could be solved by adding some sort of heating element into the lights, but that may negate the power savings and labor costs of the LED's in the first place.
  14. Air_Boss
    4,199
    1,184
    New Yawk
    For that we have gloves, mittens and snow brushes...
  15. Air_Boss
    4,199
    1,184
    New Yawk
    Clearly, as far as rear-facing red fog/rain/positioning lights go, you "don't understand that at all"...
  16. Soylent
    443
    2013 Prius v wagon
    You scrape the snow off traffic lights yourself? What a good samaritan ;)
  17. Air_Boss
    4,199
    1,184
    New Yawk
    Headlights; hoods and the wind take care of snow on traffic lights.
  18. Soylent
    443
    2013 Prius v wagon
    Not necessarily. However, this problem usually only appears in municipalities that did not want to spend the extra money for heated traffic lights.
  19. Air_Boss
    4,199
    1,184
    New Yawk
    That's news.
  20. vcvtrading
    53
    22
    Arkansas
    I have a 2008 Prius, with of course the HID headlights. We have driven with the headlights on for all of the 128k miles we have put on the car. I refuse to drive without DTRL's. We have had both right and left headlights replaced (one each side) over life of car. One at about 60k and the other around 90k. Both replaced by dealer. Also we consistently maintain 50 + mpg, so power drain does not seem to be an issue. We will continue to always run with the headlights on for safety.
