Thoughts? Loose Calipers
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jon_lin, Jul 24, 2011.
  1. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Thanks for the update Jon. Maybe the service tech was just careless because he was leaving in a few days. Who knows really, they should give you some coupons or something of value besides just fixing your vehicle. That's my 2 cents anyway. Glad to hear you're getting it sorted out step by step. No worries!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Wow, it makes one wonder if it was deliberate.
  3. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    The condition he left your brakes in is inexcusable for a "tech" and almost criminal in my opinion. Hang on to that video...
  4. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Doesn't someone check the tech's work? I guess not.
  5. Mendel Leisk
    42,343
    Not that uncommon: I left just a lower bolt off once. Lucky no harm, and spotted it soon thereafter: I'd just pulled the pads to check thickness, and about a month later was there with replacement pads when I noticed. The caliper was at least was held in by the upper bolt, and gravity.
    In your case it looks like both were removed, judging from the motion. It seems to me your caliper was mostly being restrained by the brake fluid hose.
    Did you get a loaner?
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I realize mistakes can happen.
    But IMO that's a shameful bit of incompentency that crosses the line into dangerous negligence.
    At this point I suppose you should be glad nobody was hurt and there probably wasn't any long term damage to human lives or property including but not limited to you and your Prius.
    When you're dealing with brakes....things like that simply cannot be allowed to happen.
  7. jon_lin
    jon_lin New Member
    25
    Calgary
    Sorry for late reply Mendel - no loaner was given (was offered for Wednesday, since the cars weren't available until then), but I guess no need.
    Happy update!
    Car was just brought back to my parents (who will use the car until they visit Calgary the following weekend). Per the foreman in the Edmonton shop, no damage to the wheels or brakes. Parents will go give the Prius a spin tonight, so we'll see how it goes.
    The Service Manager asked if there is anything else he can do to help reestablish the goodwill. I opened with a fairly reasonable offer, along the lines of Service credit and/or coupons. He said he'll have to go chat with his manager (apparently he is only an assistant service manager, but he is, imo, good enough to be the lead manager), so we'll wait to see what materializes. Unfortunately I'm out of the country for the next little while, but I am optimistic we will arrive at a good outcome. Keep you posted as to the outcome.
  8. Mendel Leisk
    42,343
    We had a '91 Accord that started making a really sick noise everytime the brakes were depressed. Got home, pull the wheel that it seemed to be coming from, and saw a crack in the rotor. You cold catch a fingernail on it.
    Phoned the dealer, described the issue, brought it in. About an hour later the service writer phoned back with "good news": no problems with the brakes, it was ready to be picked up.
    For about 2 seconds I was actually relieved, then reality kicked in, and I politely told him to check it again, and hung up. Maybe 5 minutes later I decided to email the service manager.
    About an hour later he phoned me back, apologised, said he had the rotor on his desk, and so on.
    It makes me think of when I was detailing steel, for various fabricators. A shop would call, say there was a problem, say: the drawing were asking for something to be welded on beyond the end of the beam, or similar.
    I wised up real fast: when some one comes to you with a very specific, observed problem, double check before you tell them they're dreaming, LOL.
  9. jon_lin
    jon_lin New Member
    25
    Calgary
    Final update: I received this offer from the dealership, which was reasonable given the situation. Two maintenance services (including two oil changes and one brake service), so approximately $600 worth of service.
    Now as a benchmark, you should know what to expect from the dealership when this situation arises! Thanks for all your help.
  10. Mendel Leisk
    42,343
    Good to hear it worked out!
    Have you got a block heater yet? Doesn't hurt to ask them ;)
    The part retails for about $80, but $300~400 with labour to install...
