Thoughts on 2020 prime from Canada
Discussion in 'Prime Main Forum (2017-2022)' started by dexterwang, Aug 17, 2019.
  1. dexterwang
    dexterwang Junior Member
    Vancouver Canada
    2023 Prius Prime
    ----Canada----
    Just for the brand new fully loaded prime I. Canada a couple of weeks ago. Great car so far! Here are some quick thoughts for potential Canadian buyers. *upgraded from 2016 Prius.
    Pros:
    -2020 additions are awesome
    5 seater makes it much more versatile. The extending sun visor is great. Finally apple carplay (main reason why I waited)
    -electric engine very zippy.
    -range roughly 50km with conservative driving.
    -with mixed hybrid driving, I can probably get 100km with 1L gas and full charge.
    -less road noise compared to previous Prius
    Cons:
    -large center screen has terrible resolution. Can barely read the road names for apple car play and apps. Clearly not optimized. Considering how cheap lcd screens are nowadays, Toyota really should have stepped it up.
    -key range is short. Don’t know if it’s just my keys but I have to be maybe 5m away before I can lock/unlock it.
    -hard to customize central screen. -I want CarPlay on with driving trip info on bottom, But I can only get the ac control stuff.
    All in all. Loving the car. Look wise is a big upgrade from 2016 Prius as well.
    MichinZen, GTprii and bisco like this.
  2. Tideland Prius
    16,127
    Congrats! We have questions about the 2020 Prime - Canadian spec lol. I guess the main one is CarPlay - only climate control is available on the bottom half, eh?
    Also, there's no Safety Connect or Entune Apps? (So no Predictive Efficient Drive or Charging Station POI? The latter is an option for me but of course doesn't show up because I don't have Entune. The former is only available in the US so it'll show up in the menu when you cross the border).
    The 11.6" screen is actually 1920x1080 resolution so it's clearly an optimisation issue with CarPlay. I don't know if iOS13 will make any difference to the interface resolution or whether it's baked into the headunit.
  3. dexterwang
    Vancouver Canada
    2023 Prius Prime
    ----Canada----
    I haven’t seen options for the predictive efficient drive or charge poi.
    I wish I could change the climate control on the bottom when CarPlay is on. If anyone knows how, please let me know.
  4. Tideland Prius
    16,127
    Maybe they removed the Charging Station POI option (which would make sense if it doesn't do anything...). It's under "Options" --> Map Information. Touch the screen one to remove the overlay of the 3 bubbles, then the "Options" button should appear on the top left.
    PED doesn't show up unless you're in the US so just check out that screen when you're in the US. It does take several repeated drives so unless you regularly drive through the same roads in the US, you probably won't see the leaf markers.
  5. dexterwang
    Vancouver Canada
    2023 Prius Prime
    ----Canada----
    Thanks for the info! I’ll check it out.
