Thoughts on engine shaking
Discussion in 'Gen 2 Prius Main Forum' started by floridarich, Oct 17, 2020.
Tags:
  1. floridarich
    floridarich New Member
    South Florida
    Hello all. Quick question for you. I'll leave the scenario below:
    While in Drive, if the ICE is on while my foot remains on the brake pedal at a stop light, in a parking space, etc., I notice there is a shuddering that the ICE seems to create which shudders the car a bit. It's a noticeable shaking feeling that goes away when the ICE turns itself off like it's supposed to during a lengthy idle or if I begin to accelerate. If I were in a normal non-Prius car, I'd associate the feeling with a bad transmission, maybe bad engine mounts, etc. If you've ever been in a manual transmission car when you're in gear but not giving it enough gas, you can feel the engine start to shudder, right? That's the sign to give it more gas so the car doesn't stall out. Well this shuddering feeling from my Prius reminds me of that same sensation.
    I'm a first time Prius owner and I am nervous this shuddering I am experiencing is not normal and is a serious problem. I do not have any CEL on and no other problems really. The car is new to me as of a few weeks ago. I replaced the spark plugs, air filter, and drive belt, but that's all. I have a 2007 Prius base with 113,000 miles which has been dealer serviced its whole life according to the Carfax.
    I'd appreciate any thoughts or help!
  2. PriusCamper
    PriusCamper Senior Member
    13,157
    5,322
    Pacific Northwest, USA
    In general shuddering when the engine is cold is a normal quirk of Prius engine design... Shuddering when the engine is at normal operating temperature could be a sign of a blown headgasket or some other engine problem. LEt us know more and we'll walk your through your options.
    #2 PriusCamper, Oct 18, 2020
  3. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Motor mounts?
  4. floridarich
    South Florida
    Gotcha. I don't see any smoke from the tailpipe and I've not noticed any coolant in my oil; I sure hope it's not a headgasket problem! I'll pay attention to how the shuddering is at normal operating temp after I've been driving a while.
    I've never had these go bad on a car; any special things to know about Prius motor mounts?
    #4 floridarich, Oct 18, 2020
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,100
    2,002
    NJ-USA
    Head gasket problems seem to be uncommon on the Gen2 1.5L. Keeping an eye on your fluid levels and conditions is always a good idea.
    Quick thought, does your CEL come on as a bulb test when you power the car up? I have seen some folks try to disable or cover up the CEL instead of fixing the problem that triggered it. If there is an engine misfire, it is often accompanied by a rattle or knocking sound under light ICE load as the uneven engine speed causes the dampener between the engine and trans to hit its full travel limits- hard.
    The engine mounts are fairly conventional, two up high, (one at either end of the engine and transmission), holding up all the weight, with a third "dogbone" underneath controlling torque wrap up. They can "collapse" some (compress) as they get older and transmit engine vibration through to the body. Not too often but sometimes. If I replace them I only use OE parts- the aftermarket stuff is garbage for this.
    #5 mr_guy_mann, Oct 18, 2020
  6. PriusCamper
    13,157
    5,322
    Yea motor mounts are an issue with big powerful engines... Not so much with these little guys...
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    On the Gen 2, there is a point in the warm up process where the ICE will give a little shudder off & on while stopped. To me, it felt like the car behind me had just barely bumped my bumper. This article explains the stages in a 2nd generation Prius.
    http://techno-fandom.org/~hobbit/cars/five-stages.txt
    SFO likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Cant be too bad if no dash lights. But Time to get involved.
    Your car is over due for new spark plugs probably needs a new air filter and the throttle body cleaned. The pcv valve could use a change and its 2 hoses may have cracked ends mine were cracked at 110,000.
    Def needs a new water pump belt.
    Then it could use a trans fluid change and an inverter coolant change and a ICE coolant change but for that I would just dump the rad a few times so as not to invoke the dreaded G2 airlock.
    Clean the front ac condenser and service the ac ecoil under the dash next time the front end of the car is in the air.
    Use a new factory oil filter and 3.8 quarts of Mobil One 5-30.
  9. floridarich
    South Florida
    Next time I start the car, I'll pay attention to which lights come on when the car is starting. Thank you so much for your thoughts.
  10. floridarich
    South Florida
    I did the plugs, drive belt, and air filter a week or so ago. My cousin mentioned to me about doing the PCV valve as well. I should probably do that. The other stuff...will have to wait, unfortunately. I had an unexpected dentist visit that kind of cleaned me out, monetarily speaking :/
  11. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Oh good got the belt done. That stupid design no temp sensor will ruin your day.
    Did the engine have this issue before you changed the plugs or it started after the plug change?
    Did you look in the plug well before pulling the plugs for an oil leak that’s really common on this car and most four bangers the gasket leaks around the plug wells eventually. To bad because valve cover gasket is easy if your doing the plugs as you are in that area.
    #11 edthefox5, Oct 19, 2020
  12. floridarich
    South Florida
    I did not look in the wells when I did the plugs. And yes, it was doing the shuddering thing before I put in new plugs.
  13. PriusCamper
    13,157
    5,322
    Easiest way to inspect the wells during spark plug changes is with your phone camera...
  14. edthefox5
    10,096
    4,834
    Clearwater, Florida
    I tried the phone but when you get close to the hole it was too dark. I didn't try much as I had my lighted bore-scope but it proabaly would work ok.
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    No cel so its strictly mechanical which is good. Your plugs and cops and injectors are ok or it would throw a misfire cel real fast otherwise.
    Seen a bunch of broken motor mounts lately on this site.
    Go on YouTube and search PRIUS INSPECTION.
    It will show you the chicken dance to put the engine in inspection mode and engine will idle continuously till you shut the car off. Give it a good looksee while its idling.
    Jack up the front a little and get under there while its running and listen to the engine and look closely at the front and back motor mounts for movement. You may see why its shuddering.
    Good Luck.
  16. PriusCamper
    13,157
    5,322
    if you put your camera in video mode it will turn the flash on so you can see...
  17. prius8654
    prius8654 Junior Member
    I had some engine shaking a few years ago and it was my ignition coils going out. I ended up needing to replace a couple of them and everything was back to normal.
    Ntelas, SFO and ColoradoCrow like this.
