Thoughts on Purchasing a 2007 Prius Please
Discussion in 'Gen 2 Prius Main Forum' started by CPost, Oct 27, 2017.
  1. CPost
    CPost Junior Member
    Raleigh NC
    Hey Guys,
    I am a Prius noob. I found a 2007 Prius with 56,000 miles for $6,000. I'm taking it to the dealer to get inspected tomorrow. I'm not sure if I should buy this based on the unknown life of the battery given the low miles. I don't want to buy this then have to drop another $3k for a new battery. I know its unpredictable when the battery can fail but it seems they have a higher probability on cars that are seldom driven. I test drove it last night and noticed this sign on the dash: (((i))). I'm not sure what that means. Any advice would be appreciated.
    Thanks,
    Chris
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    I am very leery of low mileage Prius.
    There is a chance it has been sitting for long periods of time.
    The battery is already 10 years old.
    There is a high likelihood that you will have to replace the battery in the next few years.
    But then again, that'd mean you have a $9,000 car, not a $6,000 car. You could look around and see what else is available for $9,000.
    Aaron Vitolins and kenoarto like this.
  3. CPost
    CPost Junior Member
    Raleigh NC
    Ok, thanks Eric for the advice.
    It has already been sitting for a month at the current owner's residence. She is an 81 year old woman who doesn't leave the house. She received it in a will from a professor she worked for when he passed away.
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    That is ultra low mileage. In general, $6000 is a high price for a used gen 2 Prius, but this one only has 50K miles. Almost unheard of.
    I would recommend buying it if everything checks out. Mine has 150K and I wouldn't take less than $5500!
    pilotgrrl likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Welcome!
    Looks like it has an issue with the brake system.
    If it's the accumulator pump, Toyota has extended the warranty till December of this year. Actually, I think it's through December. But it could be something else. When you get it checked out, hopefully they'll check the codes.
    I would be leery of a battery that old and driven so little. But, if the rest of it is good, I might think about buying it and setting aside money for HV battery replacement. It will happen sooner or later ... in this case, probably sooner. Otherwise, that looks like a great price for a car with so few miles. My wife's '07 has 120,000 on it.
  6. LEVE
    LEVE Member
    191
    97
    On the Willapa
    I'd buy it in a heartbeat. I've a 2005 with 287,000 miles on it. Total maintenence cost has beeen <$200. I'd think this car would be a good value even if you did have to do some HV battery work.
  7. bisco
    52,662
    welcome!
    if you only have $6,000. and no money for major repairs, i wouldn't buy a hybrid.
    all the best!(y)
  8. MilkyWay
    823
    359
    23
    MI
    Did it look like this:
    If so just means low tire pressure on one of the tires...Anything under 30psi I believe triggers the light. Or could be bad sensor.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The trigger for the tire pressure idiot light is 25% below the set pressure.
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Keep in mind on a Gen2 sitting around the small 12v discharges unless the smart key system is switched off, and yes the Tire Pressure light could be on as the transmitters in the tires have batteries that die around 9-10 years no biggie there.
  11. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Most Toyotas are 15%.
  12. 05PreeUs
    1,097
    565
    MSP
    Have $$$ set aside for a new HV battery, they DO NOT like sitting.
    That is well and far above market price unless the condition and maintenance records are above reproach.
  13. CPost
    CPost Junior Member
    Raleigh NC
    Everything checked out at the inspection yesterday. It needs a headlight restoration ($99) and 2 new tpms sensors for the front tires ($380). @MilkyWay - you were correct. All the maintenance records were on file at the dealership. The hybrid battery was replaced at the dealership on 6/10/17. The service manager was amazed and said it's in excellent condition. The VIN starts with a J and he said that was great since it was made in Japan.
    What are the best tires? I'm thinking about getting a set of Michelin's. Currently there are 2 Cooper brand tires on the front & rear driver side, a Goodyear on the front right passenger side and a dry rotted Michelin on the passenger rear.
    Thanks everyone for your help & advice.
    jerrymildred likes this.
  14. 05PreeUs
    1,097
    565
    MSP
    "Best Tires" is subjective, what one driver thinks are great the next hates. Climate is only one variable.
    In TX where we need not worry about snow or ice (DFW), our family is 100% Michelin Energy in whatever size for the vehicle in question. They are QUIET and ride well, but not *as well* as some other tires with softer sidewalls, we prize the following in order:
    -Wet Traction > there are BIG differences here between tires and we get a heavy rain frequently
    -Noise
    -Dry Traction
    -Ride Quality/crisp response
    These would not likely be appropriate choices for someone that lives in the "Snow Belt", or drives a lot of gravel/muddy roads.
  15. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    $6000 with a new hv battery and low miles.
    Sounds like a good deal.
    Just to be really sure, I'd get confirmation that it was a battery with NEW cells. Not rebuilt with USED cells.
    jerrymildred and Raytheeagle like this.
  16. Coopers ST
    Coopers ST Junior Member
    51
    Colorado
    Ouch DO NOT pay that much money. As a detailer that is robbery. If you have a drill you can buy everything you need for $20 at Walmart. The 3M kit is really nice and I think even has a coating to out on them after you finish them. I would charge $30-$40 depending on the severity of the oxidation. If you don't want to do it call some detailers, or let me know where you are, I will reach out in my network of detailer "friends" on a forum you are on and help you find one. Really a $100 is way too much.
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    You don't need to immediately pay for TPMS
    Best idea you should do the TPMS fix as a cheap fix when you replace tires.
    From Amazon I used (probably works for 2007) probably cheaper than your repair ahop can get the TPMS, just give em to the the tire guys before they give you new tires:
    Denso 550-0103 TPMS Sensor
