Thread repository for ALL non-PriusChat 2016 Prius reviews
Discussion in 'Gen 4 Prius Main Forum' started by priusfan500, Nov 17, 2015.
  1. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    A very neat new feature !
    Not only one can see which door is open,it also diplays if windows have not been closed after shutdown !
    51,908
    but spot on.
  3. Tideland Prius
    16,555
    The one thing that annoyed me with the Gen 3 was that it didn't display any messages on the MID other than "BRAKE!". Therefore, it's super easy to miss that your moonroof is opened (tilted up) because all it does is beep once when you turn off the car. It could've said "Moonroof Opened".
  4. bwilson4web
    16,208
    So how many inches of snow blew in?
  5. Tideland Prius
    16,555
    None :). I'm young enough to hear the beeps.
  6. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Looks like they forgot to clean the interior before putting it on display.
  7. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    2016 Toyota Prius: First Drive Review | Automotive Content Experience
  8. bisco
    51,908
    nice write up, thanks!
    'markets that cannot dispose of li-on batteries'. that's interesting, don't recall reading that before.
    'rear seat passengers have a surprising amount of legroom, even with the front seats adjusted to a comfortable position'. this is welcome news.
    #208 bisco, Dec 8, 2015
  9. civicdriver06
    797
    324
    Germany
    Did they change something since Las Vegas & Frankfurt ?
    Would be great if true !
    "Rear seats fold flat to handle larger cargo. With the battery pack below the rear seats, the seat backs and cargo floor don’t quite line up, but the floor can be raised to create a flat load space .
  10. bisco
    51,908
    i noticed that, i would like to know exactly what they meant.
  11. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    I'm guessing Styrofoam.
  12. RRxing
    2,546
    1,822
    NEPA
    Insert a pre-cut piece of 3/4" plywood and... TA-DA!!!
  13. Maxwell61
    Maxwell61 Active Member
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    The system has been created for the first time on the EU Auris HSD, that have already the HV under the rear seats. You're provided with two cargo floors, one very thin to cover the spare well, the other one 2/3 cm thick and rigid, that you can leave in the garage or seat on the thin one, or insert on the side plastic fitting that you can clearly see in the following pic at the right side; a slot is in there where you insert the hard cargo floor, so to get a flat loading space in line with the seat (folded).
    This is the hard plywood 2nd cargo floor, but not inserted to have a flush surface but just seating on the LPG tank, to have the max height available. Of course the floor this way is not in line with the seat:
  14. Sergiospl
    3,938
    1,351
    28
  15. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
  16. civicdriver06
    797
    324
    Germany
    The speedometer is not in the center !
    I have no idea why people complain about the way the instruments are lined up in the Prius !
    It's absolutely ideal,even without a HUD,everything is right in line of sight .
    Much easier and safer than having to look through a steering wheel .
    The eyes stay there where they should .
    On the road !
    I wish they would test the new headlights !
    That guy from cleanmpg.com drove the new Prius at night time,but unfortunately never shared his experience.
    #216 civicdriver06, Dec 9, 2015
    usbseawolf2000, tmacrp, giora and 3 others like this.
  17. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    They got several things wrong. She kept harping on "no lumbar" yet didn't realize that the prius 4 trim level (which she says she drove) includes lumbar in the power seat adjustments. And no there is no $22,000 version.
  18. Mendel Leisk
    41,435
    I'll continue to complain about the centre of dash instruments, Toyota continues to march to a different drummer on this.
  19. Netcub
    344
    170
    Kentucky
  20. bisco
    51,908
    i like it fine too, no complaints with that. the speedo is dead on.
    Felt and Netcub like this.
