Thread repository for ALL non-PriusChat 2016 Prius reviews
Discussion in 'Gen 4 Prius Main Forum' started by priusfan500, Nov 17, 2015.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    different performance... rides harder, etc. If my back camera worked, I would take a pic of my lexus and its several different recomendations on the car door :)
  3. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    I've always over inflated...
    51,908
    it's interesting. i suppose they figure people wanting the higher mpg's won't mind the ride difference.
  5. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    We do not have Toyota's correlation for weight vs. MPG, but I have posted GM's approximation equation, which I got from the Chevy Volt or Cruze boards I think. I agree +4 MPG is excessive for 70-lbs as we understand it.
    I assumed the 15-inch tires were part if it. Also note I believe these are not EPA numbers yet. Nor are they the real McCoy (Fuelly) numbers. I think somebody said the EPA technique is overly sensitive to vehicle weight, so that could explain something (as Toyota is attempting to predict EPA results).
  6. Mendel Leisk
    41,434
    Yes I think they did. It's mentioned in Danny's second (of 3) videos, discussing the car with the Toyota rep. They FINALLY pop the hood for a look, and as anticipated the 12 volt battery's in there, near left fender. The rep mentions something about the battery being bigger/more capacity, and it looks to have conventional posts.
    Video: 3 Part 2016 Toyota Prius Walkthrough with Toyota's Prius Product Educator | PriusChat
  7. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    2016 Toyota Prius Hybrid - Consumer Reports
    a couple quotes:
    Ride and noise improvements:
    Inside:
    Most interesting:
    And overall:
    Android merge. :)
    AND interesting comments:
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The comment in regards to Volt, 2016 Prius will be cleaner than the 2016 Volt using grid-mix electricity. You are also looking at a midsize and a compact. Volt doesn't have the rear independent suspension.
  9. Tideland Prius
    16,555
    Yeah the base has a normal silver wheel cover. Two Eco, Three and Four use the same design but blacked out parts of it to make it look like a 5-blade design.
    Well I was thinking of a Three, so you get a few more features with the Li-Ion.... like an Eco Plus or something haha.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That's a very good sign of improvement.
    The new Toyota Prius isn’t just a good hybrid, it’s a good car | The Verge
    Thank you, Akio.
    #90 usbseawolf2000, Nov 19, 2015
    Tideland Prius, Netcub and giora like this.
  11. Netcub
    344
    170
    Kentucky
  12. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    2.5 inch less leg room in the back ?
    Never ever !
    I wish these reviewers would learn how to do their job properly .
    If that would be true Priuschat Team would have noticed that or not ?
  13. bisco
    51,908
    i think someone did mention it.:(
  14. Netcub
    344
    170
    Kentucky
    Just ask cyclopathic, He has all the facts and figures.
  15. civicdriver06
    797
    324
    Germany
    The way I understood it so far,is that the front seats slide back way further then in previous gen 3. but that doesn't mean the leg room in the back has decreased and especially not by a enormous amount of 2 1/2 inches !
    That would be a huge decrease !
    Do you really think Toyota made the car longer and at the same time ruined the interior space ?
    Not by a long shot !
    As I said,these journalists and reviewers should learn to get their facts right before they put them out to the world !
  16. bisco
    51,908
    someone said they moved the rear seat forward because of the sloping roofline.
  17. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Yes, unfortunately that is true. One of the thread has all comparisons. Total outside Length is increased at the same time inside passenger size is decreased. The combined leg space is also less, so is head room in the back. Not only that, despite car is only 20mm lower than previous gen, the seat is lowered by 59mm(close 2 1/2 inch). But 20mm lower stance is coming from actual sacrifice in ground clearance.
    In effect, the increased the length and width of the car, but reduced the passenger space, and reduced the comfort of getting in and out of the car, increased the weight(however little may be), but kept talking about Toyota logo being as low as FR-S!!? Really?
    Real metrics,
    1. Actual comparative power to G3 ( in whatever standard they claimed, both in same standard)
    2. Weight distribution front to rear ( I bet new car is more front biased because, battery is moved to all the way front of the car, and traction battery is moved forward from being directly on rear wheels to in front of rear wheels).
    3. Actual CG change for whole car ( if not lowered where it would be compared to G3).
    4. Actual 0-60, and 50-70 timings... I read somewhere high end power is very weak potentially making this even dangerous for highway overtaking and merging.
    We asked Danny about this metrics, not sure what happened, none of that info is provided. As usual as Toyota keep hiding if information if not favorable (like combined HP).
  18. civicdriver06
    797
    324
    Germany
    The Prius allways has been known for it's good interior space and here goes Toyota and ruins their reputation in gen. 4 ?
    2.5 inches,that would mean more than 6 cm and that would mean there's hardly any leg room left !
    Never !!!
  19. bisco
    51,908
    agreed. i'm not sure it was 2.5 inches. there are too many threads here to find it.
  20. bisco
    51,908
    check the gen IV sticky '2016 prius product info', it has all the interior dimensions.
