Thread repository for ALL non-PriusChat 2016 Prius reviews
Discussion in 'Gen 4 Prius Main Forum' started by priusfan500, Nov 17, 2015.
  1. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    How many false conclusions did you make on this forum? Your posts are starting to get really annoying, just saying. I think I'm not the only one.
    Netcub, bisco, Navigare and 1 other person like this.
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    give me a list. If you accuse someone you'd better have facts to back it up.
    Gen3 has issues with long steep climbs and there is no evidence Gen4 had fixed it. And BTW asking doesn't amounts to conclusion at least in our free country maybe somewhere else.
  3. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Technically It was a question not accusation :whistle:
    It's the same NA 1.8 engine with marginally lower peak power but marginally higher torque curve, what do you think the performance will be like? The best you can expect on long steep climbs is 3,500 rpm instead of 4,000 and better sound proofing, not enough?
    Weight difference is minimal and no one will notice it.
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it is a lot faster than Prius c though, changes from G3 are tiny in overall acceleration. Not sure if you will notice it at all at speed.
    p.s. Eco model is actually lighter than G3, right? So if you want faster and more economical Prius, with SKS, LED headlights and 6.1" display, you can get Eco and not miss much.
  5. bisco
    51,908
    so what did they do with all the space where the battery used to be, suspension?
  6. Tideland Prius
    16,555
    Yes. A double wishbone suspension takes up more space than a torsion beam. It's also heavier. (So offsetting the weight reduction from TNGA)
  7. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    That's not so good !
    The current model allready has more than enough power in the 0-60 km/h range,it would have been wiser to give the new extra boost of the battery to the 80-120 km/h speed range .
    0-50 or 0-100 speed time isn't all that important,but if you misjudge a situation while overtaking somebody,a faster 80-120 acceleration time could be life saving !
    #127 civicdriver06, Nov 20, 2015
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    What is the 80-120 km/h time for the Gen 3?
    merged
    And, on top of this, trunk volume is larger.
    #128 giora, Nov 20, 2015
  9. civicdriver06
    797
    324
    Germany
    It was testet with 8.0 Seconds by one car magazine,but I guess it alll depends on the charge of the battery .
    All in all I guess its about the same !
    Didn't Toyota say the new batterys have up to 28 % more power output ?
    So where does that extra output come in to play ?
    I really don't need it to go from traffic light to traffic light as fast as I can and as I said,gen. 3 allready hat enough power in urban driving conditions !
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    They said 28% more regenerating power but I assume the delivery power is also enhanced. 0-30 MPH time is improved since battery can handle higher load demands.
  11. civicdriver06
    797
    324
    Germany
    Okay I probably got that wrong,but they did say the new batterys have more power !
  12. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Engine torque is not increased, but torque peak has been brought down to lower RPM(400 RPM down). So when engine RPM is brought down at a given vehicle speed, so is the HP output provided. Adding to that, the Motor HP as well Torque both were brought down.
    At low speed they were able to improve accelerating from 0-30 with some gearing, but as the speed increases, they would not able to keep up as power is reduced.
    Think about, 10.6 Sec 0-100kph as per Toyota, means it is already slower(vs 9.8-10.2 Gen 3), but as speed increases/load increases, it gets even worse. Even if 0-60 remains same, we know 0-30 is faster, means 30-60 is definitely slower. Think about what happens as speed increases, it becomes dog slow for acceleration.
    See Gen 3 http://media.caranddriver.com/ez/original/application/c4df488aab8502ae1efd564bc913ca03.pdf
    No wonder Cyclopathic so unhappy!!
    #132 chinna, Nov 20, 2015
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    To put the records straight:
    0-100 km/h time is about the same (10.6 vs. 10.4 sec. per Toyota EU).
    Overtaking 80-120 km/h time about the same (8.3sec. Gen 4 per Toyota vs. 8+ third parties Gen 3).
    0-30 MPH time improved (by Danny).
  14. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Any numbers you were able to gather regarding in gear acceleration, 50-70MPH for highway merging and overtaking? How does it compare to Gen 3.
    Local driving is not a problem with any generation as per my experience. It is the merges on to highway from short ramps, and merges into fast moving HOV lane, and of course overtaking.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I am not sure I understood your question.
    80-120 km/h is 50-75 MPH, do you insist on 70?
    #135 giora, Nov 20, 2015
  16. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Never mind, I got it(80-120)... Basically it means, it is slower than Gen 3 as expected.
    FYI, looking thru a Gen 3 Edmunds review compared to Insight, here is the quote
    There's also a big gap between the 0-60-mph times of these hybrid hatchbacks, as the Prius gets to 60 mph from a standstill in 10.1 seconds (or 9.7 seconds with 1 foot of rollout as on a drag strip), while the Insight needs 10.9 seconds (or 10.5 seconds with 1 foot of rollout).
    As evidence of the Honda's fighting spirit, though, it narrows the gap by the quarter-mile mark. The Prius goes through in 17.3 seconds at 79.7 mph, while the Insight is there in 17.9 seconds at 78.2 mph.
    Not sure Toyota number is with 1 foot rollout or not.
  17. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Don't overlook the fact that front legroom increased. So, overall is really 1.9".
  18. cyclopathic
    3,292
    547
    2014 Prius c
    It still puts it below Prius C, which isn't adequate for carrying 3 adults for anything over short trip distance.
  19. spwolf
    3,156
    440
    Eastern Europe
    I finally found some info thats relatable - official number for CT200h is 9.0s for 80-120kmh... so new Prius is nicely faster in overtaking speed.
  20. GasperG
    1,169
    601
    Slovenia
    2018 Prius
