Three Prius 2014 With 300K Miles Codes (Help)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DavidPrius2014, Jun 8, 2020.
  1. DavidPrius2014
    DavidPrius2014 New Member
    Waldorf MD
    6E4015FB-2DBC-48E4-BFCD-68CDD7A2FF64.jpeg 58179D79-9672-43D0-8679-AA8D3E930FC3.jpg 7A30C23E-3B92-4B49-9899-8AB99C76FEDC.jpg 2B50CA8D-B498-4828-BBFC-6715D3AE820B.jpg 4A3B8739-0700-477B-B8DE-ECAEC4BE2D91.jpg E37040BA-87B7-44D9-B7BE-FF807A282546.jpeg I have these codes for my 2014 Prius Three. I need some help on what to do. I’m using techstream. The car sat for a week and half. 12V Tested At 12.51 Thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Battery seems low
    DavidPrius2014 likes this.
  3. DavidPrius2014
    Waldorf MD
    What are my options if I’m out of warranty? I need regenerative breaking and a new hv battery! The car is only 6 years old! My 12V Tested At 12.51 If You Remember. I like to drive the car ev mode usually! Some reason my code scanner showed p0A7F but Yesterday but After I rested once the my techstream computer won’t pick up that code maybe it meant to show P0A80 bc I never got that on my code scanner CP9660 Actron!
    #3 DavidPrius2014, Jun 9, 2020
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Looking at the pics, it appears module group 8 is much lower than the rest of the pack, failing, and probably is the cause of the code.
    In simple terms, the cheapest fix, often called wak-a-mole, replaces that module group with another used module(s) in the same voltage range and continue on till the next one fails and the process starts again. When? Who knows..... Approx. $50 plus a whole lot of labor and the car being down for days or weeks each time this happens. A grid charger is used by shops and often individuals to balance and maintain the pack so all modules work better together. This can add days to the process too.
    Or you can get a new battery (Toyota or aftermarket) from about $1600 on up and get another reliable 300k miles.
    GOOD LUCK!
  5. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Is that the original 12-Volt battery? If so, don't trust it.
    If you do require a new hybrid battery, some dealers will sell these around $2200. Installation is the question. If done at a Toyota dealer, you'd get the best warranty, but pay the most. Would you consider installing one yourself? It almost looks like the HV has one bad cell; I'm sure you'll get advice on that.
    Your Prius isn't a plug-in, is it? Just asking because running in EV mode doesn't take the non-PiP very far, then the engine has to run to charge the HV battery and to propel the car.
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Running in EV more than the car thinks is necessary is just wearing out the battery prematurely. It only has so many cycles. And it's not surprising that it's the module in the center that reads bad since that runs warmest. So ... 300k miles is great. But seven years is not great.
    For sure verify that the 12V battery is OK as mentioned above and then read codes again. Chances are, it's not the 12V, but it's smart to make sure. Next, make sure that it's not just corrosion on a sensor wire giving a bogus reading. If the battery's wiring harness checks out, on a car that new, the right fix is a new traction battery from Toyota and then you can get probably 10 more years and another 400k+ miles if you let the car decide for itself on when to run in EV.
    pjksr02 likes this.
  7. Mendel Leisk
    41,926
    The car has 300K miles, which in and of itself is a minor miracle, for a 3rd gen. It's in need of a new hybrid battery, or refurb, module replacement or whatever.
    Have you had it since new? If the intake manifold and EGR have never been cleaned, I'd get on it right away, if you want to keep it that is.
    jerrymildred and pjksr02 like this.
  8. pjksr02
    534
    227
    Connecticut
    Good point, Mendel. If the EGR system has not been cleaned, the number of miles is phenomenal. A great case study!
  9. DavidPrius2014
    Waldorf MD
    Usually I Take ev mode on short trips my 12v is fine isn’t is the original 12V I have still in my Prius
  10. DavidPrius2014
    Waldorf MD
    My car isn’t a plug in sorry
  11. jerrymildred
    11,517
    14,158
    Tampa, FL
    So, for the sake of your tiny little traction battery, don't try to use it like one unless the trip is REALLY short, like backing it out of the garage so you can wash the car or sweep the floor. You not only shorten the life of your battery, you burn extra gas charging it back up.
    Time is generally accepted as the big enemy of the battery, along with heat. Miles are easy. Taxis rack up phenomenal miles on their traction batteries.
    scona likes this.
  12. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
