Three Red Seat Indicators and Beeps while driving
Discussion in 'Gen 4 Prius Technical Discussion' started by priusjedi, May 9, 2023.
  1. priusjedi
    priusjedi New Member
    Lake Placid NY
    2018 Prius
    I recently picked up a 2018 Prius. While driving down the road, all of the sudden the three red seat indicators on the far right of on the dash board light up. Right under the indicators there is are, which looks like a two triangles and a square. When these pop up, it beeps rapidly for what seems like 10 seconds.
    No other lights light up and no other beeps happen. Does anyone know what this represents?
  2. Tideland Prius
    16,650
    Did you have anything in the back seat?
  3. priusjedi
    Lake Placid NY
    2018 Prius
    Nothing was in the back seat.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    If you don't have an owners manual, then see a dealer.
  5. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    Wow, way to treat a new member. Simple question and maybe someone knows and will have a simple answer. I've always been curious myself about the same thing, but it is not important enough to look it up. If I saw an answer here, I would appreciate it.
    priusjedi likes this.
  6. Doug McC
    Doug McC Senior Member
    1,087
    427
    Midwest
    2022 Prius
    Those are the rear seat belt reminder lights and are activated by the system sensing weight on one or more of the 3 rear seat positions (the triangle and square symbols are indicating the different seat positions). If you have something in the back seat it can trigger them. If they light up right after starting to move the car it is normal. In the 2022 Owners Manual they are addressed on pages 109 and 591.
    If they are just lighting up intermittently with out weight in the rear seat it is probably a malfunction. Additionally, they can be disabled (if I remember right).
    Hope this helps.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    And I supplied a straight forward and simple answer.
    There was no "mis-treatment" until YOU showed up.
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    Have to ask. Is your 12 volt battery original? A weak battery can cause all sorts of electrical issues.
  9. sclevine
    170
    160
    Northeast Florida
    2024 Prius
    Well, then, we clearly agree to disagree. I stopped short of calling your behavior demeaning. I wonder what you would have said if I went there. Maybe I'll be lucky enough to find out. lol.
  10. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    On my 2017, IIRC, they light up if you merely open the rear doors as well.
  11. Tideland Prius
    16,650
    You had the option to not reply. No need to point out every single issue by everyone
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    Maybe it has something to do with one or both of the rear door switches. Switch not opening (or closing) properly. But then the rest of the behavior, partial illumination of other warning icons on the panel and beeping noises, sounds like electrical gremlins from an improperly booted ECU. OP says this happens at some point while driving, so all the ECU's should be booted and functioning by then. I'm familiar with the three seat belt warning icons but I don't know it they illuminate as a group or individually if one or more seats are occupied and the occupants are not belted. All three of them illuminating at the same time doesn't sound like seat sensors amiss. I see them light up every time I make my Prius ready as part of the POST (power on test). I would start with the easy stuff and have the battery load tested and + and - connections checked.
  13. priusjedi
    Lake Placid NY
    2018 Prius
    Thank you for your insight. I agree that it is not necessary a seat censor type issue. No other warning lights or beeps happen. I do notice it only seems to happen in the morning. It happened again this morning and I was able to take a picture of it.
  14. priusjedi
    Lake Placid NY
    2018 Prius
    Great question! I will take a look. I do remember on a previous prius I had, all of the sudden things would happen including the car not starting. Come to find out, the 12 volt battery was not properly tightened and secured. After I fixed those issues, all was well again. Thank you for mentioning the 12 volt battery.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    And so did YOU. :whistle:
    My teachers often said: "Look it up yourself. You will remember it longer."
    Then......asking a question in a "social media" forum like this often gets you
    some right answers and many WRONG ones and you end up looking it up yourself anyway.
    What I said was NOT rude, demeaning or unfriendly.
    It WAS a basic, simple answer.
    Some folks here need to lighten up a bit.
  16. Tideland Prius
    16,650
    Your reply was passive aggressive. It amounted to “read the manual”.
    Doug McC and Harters like this.
  17. Doug McC
    1,087
    427
    Midwest
    2022 Prius
    How long after starting out does it happen, or what other conditions are present (ie: passengers, packages, rear seats folded down, pets)? My wife tried sitting in the back yesterday for a brief ride to the store and left the belt unbuckled. All three lights and symbols stayed lit for a short time and then went out. I may have disabled the rear seat warning when we first got the car since we don’t usually have any passengers except our large shepherd and didn’t want to be buckling and unbuckling the seat belt every time we carried her with us.
  18. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    Wanted to correct this after seeing the display in my car for myself. The square, left, and right triangles below the seat belt icon identify the center, left, and right seats. This annunciator panel has static illuminated warning icons (so called idiot lights) and the LED clock. If the battery load-tests OK, I would then proceed to removing the lower portion of the rear seat and checking the positioning of the seated occupant detector if possible. You might have to find and download the instructions for this. The rear door switches if not properly operating would provide a "door open" warning on the dashboard, so unless that happens I wouldn't suspect a problem there.
  19. Doug McC
    1,087
    427
    Midwest
    2022 Prius
    What am I missing here? From the info the OP provided I’m still trying to determine if there is an actual problem, yet your advice is to start doing some major removal work? So I am assuming I didn’t pick up on something.
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    From what I read, the OP is reporting a random appearance of the rear seat seat belt power on test display which is all three icons (right seat, center, and left) illuminated at the same time. I would imagine in a properly functioning system if there were occupants in the back seat and one of them was not belted then only that seat position would illuminate. It is also probably true that a marginal charge capacity of the 12 volt battery, which might be six years old if OEM, or connection problems of the battery to ground could be causing a reboot of the ECU that monitors the seat belt system which could trigger that three icon display at times other than when first starting up. The easy check would be to have the battery tested first. The jazz about yanking the back seat out would probably be something I would do in a quest to discover quickly what might be causing this intermittent problem. Could be some shorting of signal or power wiring to the seat sensors. Could be a loose wiring harness connector from the sensors to the ECU. If I were really having this problem I would likely consult with my Toyota service department.
