Three warning lights come on when I go 70+ mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kvdsr, Sep 30, 2017.
  1. kvdsr
    kvdsr Junior Member
    The yellow Brake System Warning Light, the ABS light, and the VSC light all come on at the same time when I hit 70+ mph. When I slow down to a COMPLETE stop, they all go out. There is never any problem I can detect when it happens, and it usually happens on a smooth road. This started happening quite a few miles ago when I had one of my front CV joints replaced, and when I told the garage about it they said they couldn't test it because they'd have to be with me when the lights went on.
    When I test it on the road and all three lights are lit, it doesn't register any codes. I don't often exceed 70 mph because of where I live, and this has been going on for so long now that I've pretty much just ignored it.
    Any speculations as to what is happening, and is it really bad that I'm not doing anything about it?
  2. kvdsr
    kvdsr Junior Member
    It was a wheel bearing I had replaced, not a CV joint.
    ( Sorry, sometimes my CRS takes over.)
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That's a crock of BS.
    Likely that something was damaged with the wheel speed sensor near the replaced bearing.
    If the shop that did that was not a Toyota dealer, you might have to find one for a fix.
    Oh.....and it is likely that your basic brakes will still work like that but you really should get it fixed and you probably have a major safety system that won't work right when/if you ever need it.
  4. Moving Right Along
    Moving Right Along Senior Member
    735
    591
    The simplest explanation is usually the best. Most likely something got bent or skewed out of alignment when you had the wheel bearing replaced, and it's a small enough skew that it's not noticeable until the wheel is spinning fast enough. It's still something I'd get looked at, as brakes are very important when you are traveling at high speeds.
    Regarding your shop saying they can't diagnose the issue if they don't see it: I had an issue that only occurred at speed in a previous car, and one of the mechanics took a ride in the car with me to find out the problem. If the mechanics at your auto shop won't do that, then I'd suggest going to a different shop or a dealer.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Its likely to be the abs wheel speed sensor that has either gone bad, or one of the teeth on the driveshafts teeth has removed. Suffice to note that such problems occurs when the right driveshafts aren't replaced. In some cases, the ring groves on the driveshafts, could be bugged with dirt, and would send the wrong signals to the wheel speed sensors.
    Check if the sensors are are properly seated on the hub.
    Some other tines, if one of the sensors is failing or bad, you'd ha e such a problem
  6. kvdsr
    kvdsr Junior Member
    This started happening about 75K miles ago, and we have long since moved away from the original mechanic. There have been no problems with the vehicle since then, and I have tested the brakes and steering when the warning lights are on and they work well.
    I hate to bring it in to a dealer with no real reason to do so other than lights that come on occasionally and go off by themselves. Even when it's tested with the lights on, it gives no codes. I guess it's more an annoyance than anything else. I keep waiting for something else to go wrong so if I HAVE to bring it in I could have the lights checked out then. But it's a Prius, and nothing else goes wrong - so I guess that's a good problem to have - ?
  7. Moving Right Along
    735
    591
    You've had the same issue for 75,000 miles? Wow! Out of curiosity, since you've obviously had it for several years and haven't been bothered by it, why bring it up now?
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Can hardly believe there are no codes. How do you know this is true? Just know that while the lights are on, it most likely means your ABS and VSC are not functioning. Likely people don’t often need these systems, but.
    So they do not turn off until a complete stop, or turn off below 70 MPH? The prior being a much more important scenario. How’s the brake fluid level? (Kind of complicated how it is checked, with the accumulator sucking it down).
  9. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I think Toyota engineers would make sure anything that important would bring up a code, if it clears without action it is probably something minor just out of normal parameters, but me being me I would have to find out what
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Replacing a wheel bearing or wheel hub on a Gen 2 can be done without total disassembly of the knuckle. There's a dust shield covering the abs wheel that has to be popped loose and slid inward out of the way to access the hub bolts. There's a small cutout about 3/8 inch long and 1/4 inch wide on the dust shied that the abs sensor "looks through". Maybe they used this method, but didn't align the dust cover completely right during reassembly. Would only require a 10mm socket to remove the abs sensor and look down the hole to check for a clear view of the abs wheel.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Codes should stay in the history, unless there are a number of on off cycles when the code is no longer present, ie. Check engine light for gas cap accidentally left off. Since the OP notes hardly ever triggering the light by reaching 70+ MPH, I’m not surprised if the code disappears after a while. But it should be in the history until the requisite number of cycles without being triggered again are met.
    (At least I think that’s how it works...)
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    UNLESS you have tried a panic stop on wet pavement, you haven't really tested the part that is failing. IE the ABS system.
    We all drove cars for a LOT of years without ABS at all so you might be fine. Then again maybe not.
    It's your call......but I'd say you really have already made it by driving it in that condition for 75K miles.
  13. ELECTRON AUTOMOTIVE
    ELECTRON AUTOMOTIVE New Member
    Orange, Ca
    here is a possibility.
    mismatched tire sizes, under inflation, or significant differences in tire size can cause your issue. if tire #1 is larger than tire #2 (lets say it is 10% larger just to make the math simple) it will give different speed readings to the skid control unit. at 20mph tire 2 will say 20 mph and tire 1 will say 22 mph. it is not a large enough difference to meet the threshold (in reality that is a large difference but this is just for explanation) but when you are at 70 mph tire 2 will say 70 mph and tire 1 will say 77mph. the threshold happens to be 7mph difference and the skid control will try and compensate. when it does so it illuminates the traction lights until the speed difference falls below the threshold again.
    to confirm this you will need a computer that is capable of viewing live data from the ABS computer. you will just need to watch the individual tire speeds. you could also switch the front tires with the rear and see what happens. the rear tires have less of an impact on skid control computer than the front.
    this type of error usually does not set or store any error codes because the skid control interprets it as a loss of traction, not an error. I would still see if there are any codes because they can provide vital information.
    Hope this helps!
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Doesn't this tire size difference also overheat the differential?
  15. ChapmanF
    18,758
    Not really, no, because the Prius differential doesn't have any limited-slip features built in to heat up; it is essentially as frictionless as any of the other gear elements in the transaxle. And if the size difference happens to be between two rears, or a front and a rear, then not at all, zero.
    When the Prius traction control wants to limit slip, it can do so directly by using the ABS actuator to brake a slipping wheel.
    -Chap
  16. kvdsr
    kvdsr Junior Member
    It's actually closer to 85k miles now since this problem started, and I did post about it on this forum 'way back then. The general consensus then and it seems like now is that if it was REALLY a problem I'd be getting a solid code back out of the reading, and it wouldn't just clear itself. I have been intending to get it checked out when I had a recall or something else that I HAD to take it to a dealer for, but like I said, aside from changing oil on it, it just keeps humming along. And I HAVE been testing it out under all kinds of actual conditions.
    I just wanted to see if someone else out there had a similar problem and ended up with all kinds of trouble out of it. So far I haven't.
    Thanks to all for the replies ...
  17. ChapmanF
    18,758
    The likely-revealing test would be to plug in Techstream or a ScanGauge, Torque phone app, etc., and watch the four wheel speeds (ok, have a passenger watch them!) while zipping down the highway at 70+.
    Probably, as already suggested above, it will show a difference between the RPMs of the wheels.
    -Chap
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    I don't see that in the posts in this thread at all.
    Under "normal" conditions it might not be a serious problem......but it might be VERY serious if you need ABS sometime and it doesn't work right.
  19. Moving Right Along
    735
    591
    Off-topic, but does anyone actually teach proper use of ABS (crash-avoidance steering)? I certainly never learned anything about it when I was learning to drive, but it might not have been very widespread then.
  20. Sam Spade
    2,036
    1,024
    2017 Prius c
    Me neither. I suspect they do now.
    STOMP, STAY, STEER.
    It is pretty easy to test/practice in and empty parking lot when the pavement is a bit wet.
    I think everybody should do that at least once.
    I doubt they actually practice it in "driver's ed" because of liability concerns.
