Three warning lights come on when I go 70+ mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kvdsr, Sep 30, 2017.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    bad wheel speed sensor? I think they are built into the hubs
  2. ChapmanF
    19,033
    Don't forget, the title of the thread indicates a warning that only appears at 70+ mph.
    The car can detect a bad speed sensor at lower speeds. (The sensor test, which the repair manual has you do as the last step of replacing a bearing hub, only requires driving about 28 mph, and of course if whoever replaced the hub followed the procedure, that should have been done and passed.)
    The usual explanation has already been mentioned upthread: the tires have slightly different circumference, whether because some are newer than others, inflation pressures too different, whatever.
    Having somebody (other than the driver) watch the wheel rpm readings at 70+ mph would probably show which ones are spinning faster/slower and by how much.
    -Chap
  3. Ibrahim Mohammed
    Ibrahim Mohammed New Member
    Yemen
    Hi!
    Hi !
    I have the same problem
    And it's solved !!!
    The problem started after change the bering and CV
    Then when I drive above 70 mph the abs and 2 light runs on
    A few minutes and the abs light and the other 2 light runs off
    I go to my friend he has a device and can check my car the problem the wheel speed sensor
    I checked it and the wheel speed sensor is very good
    The problem is *tone ring* its damaged
    I pay new one and the problem goes.
