Three week ownership thoughts
Discussion in 'Prime Main Forum (2017-2022)' started by Amy In Wyoming, Oct 6, 2017.
  1. bwilson4web
    16,513
    There is an MPG graph. Truth be told, I found the instant MPG not to be so useful compared to averages over a 10 mile distance.
  2. bwilson4web
    16,513
    Dynamic cruise control handles the automatic braking and it is a good thing. You can adjust its distance sensitivity but I've never looked for a way to make cruise control fixed again.
    In contrast, the optical-only, BMW i3-REx has both dynamic and fixed modes. There are lighting conditions like driving into the sun where the optically based system won't work. It will kick out of dynamic as needed and then you change it to fixed speed mode. Keeps you on your toes.
  3. Tideland Prius
    16,670
    Taken from here: Prime Features Explained | PriusChat
    DRCC (full-speed or all-range) – Dynamic Radar Cruise Control
    When activated, it uses a forward facing radar to detect metallic objects (e.g. vehicles) ahead of the driver and maintain the preset distance (short, medium or long) that the driver has set. As the car approaches the vehicle ahead or a vehicle merges into your lane, your Prius Prime will adjust its speed to maintain the preset distance between you and the driver ahead. Once the vehicle ahead speeds up or moves out of your lane, your Prius will then accelerate back up to your preset cruising speed. To set the dynamic radar cruise control, turn on the cruise control via the on/off switch on the cruise control stalk. The multi-information display should now read “Radar Ready”. Set your cruising speed and the multi-information display should now display a Prius Prime and 3 bars or the "long" distance setting. If a second vehicle is shown near the top of the screen, it means that your Prius Prime has identified a vehicle ahead and has radar lock. To adjust the distance, press the DRCC distance button located on the right side of the steering wheel. By default, “long” is selected. At 50mph (80km/h), “long” is approximately 160ft (50m), “medium” is 130ft (40m) and “short” is 100ft (30m). The Prime is equipped with full-speed DRCC which allows the vehicle to follow another vehicle down to a complete stop. When the vehicle has come to a complete stop, the 4.2" MID will display "Waiting..." which means the Prime is waiting for your input and will not automatically move forward. When DRCC is activated at a complete stop, "Waiting..." may also be engaged. This allows the driver to release the brake pedal and allow DRCC to hold the brakes, similar to an "Auto Hold" braking function. Ensure that "Waiting..." is displayed before releasing the brake pedal. When the traffic clears or the vehicle ahead begins to move, either select "RES" by pushing up on the cruise control stalk or tap the accelerator to tell your Prius Prime to begin moving forward. The Prime's DRCC also allows a low-speed follow so the vehicle will maintain the distance as long as there is a vehicle in front of you.
    DRCC can be used when the vehicle speed is approximately above 30 mph (50km/h) although owners have been able to set the speed as low as 28mph (45km/h). Full-speed DRCC will follow a vehicle down to 0 mph. If your speed is below 25mph (40km/h) and the vehicle loses radar lock (e.g. the vehicle you're following changes lane), DRCC will cancel itself. In addition, if the vehicle has been stopped for more than 3 minutes or the seatbelt is unbuckled or the driver's door is opened, DRCC will cancel.
    Basically, it keeps both speed and distance to the vehicle ahead.
    If you want regular cruise control, just press and hold the cruise on/off button until regular cruise control (called "constant speed cruise control" in the owner's manual) is selected.
  4. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Don't worry about fuel getting stale. If that is a possibility, add some fuel stabilizer to the tank (Sta-Bil or equal). There are different formulations of gasoline for the seasons. Do run down the gas and get the winter version of 87 octane when that is available. In some cases the winter formulation is for reduced emissions, and in other cases it is for proper vaporization at the lower temperatures.
    Also keep a check on your tire pressures as the temperatures drop.
    Mark57 likes this.
  5. Mark57
    2,945
    2,740
    OK
    Good reminder.
    This is nothing to brush off either. Depending on the size of the tire, pressure can drop 1-2 PSI per every 10°F of temperature drop.
    We just had a 40°F drop in temps for two days and I've been outside airing up the tires on all three vehicles. They each needed about 4 PSI added.
    Under inflated tires get hot, and go bad quickly with bad results.
  6. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    What is the ideal tire pressure to keep the tires at?
    Salamander_King likes this.
  7. Mark57
    2,945
    2,740
    OK
    OMG, you didn't really ask that question on this site did you. . . . . Oh no the agony of 10,000 conflicting replies. :D
    On my 2010 I ran my PSI @ 42. It rode hard and everyone besides me hated it. Great mileage though and it probably was wearing out the struts early. On my Prime, I'm running 37 and it rides/handles wonderful and gets great mileage. Everyone else here will of course have a different opinion. :p
  8. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I tried my run flats at zero psi but the ride was all over the place
    iPhone ?
    Mark57 likes this.
  9. Mark57
    2,945
    2,740
    OK
    Really good in the sand though, eh? ;)
  10. Ferrarilover
    185
    168
    Manchester, UK
    But why call them run flats if they need air!?!
    iPhone ?
    Raytheeagle likes this.
  11. Mark57
    2,945
    2,740
    OK
    No, just "more" air than you had.
  12. ct89
    ct89 Active Member
    323
    266
    New England
    I don't feel constrained to just one opinion...Get me going and I'm sure I can passionately insist several different pressures are the best.
    My opinion...Above 40 = too harsh...Below 36 = too soft...37-39 = can't really tell the difference so I shoot for about that.
    #52 ct89, Oct 12, 2017
    Mark57 likes this.
  13. Prodigyplace
    12,710
    11,848
    Central Virginia
    Goldilocks, is that you? :D
    Raytheeagle, jerrymildred and huskers like this.
  14. huskers
    2,548
    2,488
    Nebraska
    So do any of you go 2 pounds one way or the other front/backs with the Prime?
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    You beat me to it! I was going to say:
    "You had to go and ask that one, didn't you." :ROFLMAO:
    Anyway, I run mine 42-44.
    Prodigyplace likes this.
  16. Prodigyplace
    12,710
    11,848
    Central Virginia
    Yours is only a Prime predecessor though.;)
    jerrymildred likes this.
  17. jerrymildred
    11,517
    14,164
    Tampa, FL
    Oops! I got so engrossed that I forgot which forum this is. :D
    alexcue and Prodigyplace like this.
  18. Mark57
    2,945
    2,740
    OK
    I did on the 2010, but I keep it the same on the Prime. It seems nicely balanced.
  19. Mark57
    2,945
    2,740
    OK
    Hmmmm, junk in the trunk eh?
    Tideland Prius likes this.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I've heard that advice as well. How valid it REALLY is? Who knows?
    For me? 600 miles is a pretty short duration. So right, wrong or indifferent, I can pass on using the cruise control for that period of time.
    I think I've followed similar advice...basically because while I was dubious it was necessary and valid, I also felt following the advice would do no harm, and was easy enough to do anyway.
