Throttle body doesn't work after cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OurEvolution, Aug 27, 2017.
  1. JC91006
    16,939
    8,647
    Glad to see Frodoz back.........
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    All were missing is Samwise gamgee :ROFLMAO:
  3. ChapmanF
    19,060
    Remember, it's throttle-by-wire, and the computer doesn't really see any point in revving if the power isn't needed for anything. It will increase rpms moderately if you hold the pedal down some, and even a bit more if you hold it further, just to humor you, more or less.
    -Chap
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    If you are referring to the solar roof option available on the gen 3, it does NOT charge the 12v and never has. It only runs the fan during daylight to help keep the interior cool (if activated).
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I'd like to see the source of where that information was taken from.
  6. OurEvolution
    OurEvolution Junior Member
    Eureka
    I guess this is another example of me assuming what I consider to be normal conditions, but other than grid tied PV I'm not aware of a lot of solar powered systems that don't use some sort of a battery as a storage and transfer medium between the source and the load. And I'm pretty sure the PV panel doesn't charge the HV battery so...are you saying the PV is directly tied to the fan motor with no battery in the circuit at all, or is there another auxiliary battery dedicated to that fan?
  7. fotomoto
    5,639
    3,815
    So. Texas
    Yup, just powers the fan and only if you have the dash switch for it in the on position. In quiet conditions, you can hear the whirr of the fan while standing near the right front A piller/windshield. It activates approx. 10 minutes after turning the car off.
    The nissan Leaf has an (optional?) small solar panel specifically for the 12v. RV and boat owners frequently use a similar setup for long term storage. You can find similar dash/windshield setups on ebay/amazon that utilized the cars' 12v power plug to maintain charge on the 12v battery.
    #27 fotomoto, Aug 29, 2017
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Comes from Toyota. When I got my 2014 I researched different options. The solar was one. I figured what a waste to just power fans to exit hot air. Plus you lost the glasses holder on the ceiling console to boot!! :eek: But I think car had remote A/C ability too.
  9. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Was wondering what code reader you are using? I thought I remember unless specific for the prius type hybrid system codes could be read and or displayed wrong. Techstream or torque pro with PIDs specific usually recommended.
