Throttle body plate- is not moving (car is off)
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Garry20-20, Aug 6, 2020.
  1. Garry20-20
    Garry20-20 Junior Member
    35
    2016 Prius v wagon
    Luxury
    Hi Guys,
    I started this thread to ask if someone had experience while Throttle body cleaning.
    I decided to clean the IM and EGR pipe (as dealership advised me to replace IM and EGr gasket due to P0304 code) as it was showing P0304 code.
    When I thought to clean the Throttle body plate, it was not moving (car was off and the MAF sensor power and Throttle body power was off/out).
    So I cleaned from the front and the back with the TB cleaner .
    Does TB plate should me moving freely irrespective of the power supply or it only moves when the power cable is attached ?
    Thanks for your suggestions.
  2. ttou68
    ttou68 Active Member
    340
    198
    You should be able to move it, it has a bit of resistance when pushing against it but it should move... Try spray some throttle body cleaner and then push on it..
  3. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi ttou68,
    Thanks for your reply.
    Should I keep the MAP sensor power off and Throttle body power off ?
    or
    It does not matter while moving with bit force.
    and or
    The car should be off or on?
    Thanks
  4. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    Turn Car OFF.....
  5. ChapmanF
    15,110
    In my Gen 3, car OFF is all you need. No fussing with anything else required.
    If the car is ON, it has an angle where it wants the throttle plate to be. If you try to move the plate then, the car will notice and push back.
  6. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi ChapmanF,
    Thanks for suggesting.
    It means, no need to push theTB plate with force to bring it's back side to the front while cleaning, irrespective of power supply??
    Did I get you right??
    Thanks
  7. ChapmanF
    15,110
    The car must be powered off.
    If the car is powered on, it will fight you moving the throttle plate, and you will not be able to move it.
    The car must be off.
  8. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi ChapmanF,
    Yes, the car is off, the Map sensor is disconnected, the TB power plug is disconnected. But the TB plate is not moving, kind of stuck.
    Is it fine??
    Thanks
  9. cnc97
    cnc97 Senior Member
    1,418
    1,525
    38
    Evansville, IN
    There is a decent amount of force required to initially move the throttle plate from its closed(resting) position. However, once that spot is overcome, the plate can be held open fairly easily. Make sure that before you turn the car on that all connections are plugged back in. The car will run and drive if the TB is unplugged, but it will be battery only, and the car will be very sluggish. Don’t ask me how I know, LoL.
    Mendel Leisk and Tim Jones like this.
  10. ChapmanF
    15,110
    My recollection is opening it with a finger feels a bit like winding up a wind-up toy. It shouldn't really be much harder than that (with the power off!!).
    Of course you push down on the side of the plate that is already down, and it won't move any farther than full open, when it is straight up and down in the bore.
  11. Mendel Leisk
    38,253
    It takes a firm push to get the plate to rotate.
    Again, car off.
    And no need to disconnect MAP sensor or throttle body connectors.
    To clean it thoroughly I like to remove the throttle body hold-down bolts/nuts and lift it right off. No need to disconnect coolant lines, they have enough slack. Torque values for those are 7 foot pounds IIRC. I'll verify and post correction in the morning, as needed.
    Dutch Uncle time:
    No offense, but if you're stymied by this chore, and insist on disconnecting everything under the sun, and are considering doing the cleaning with the car on, maybe better let someone else do it.
    Or at the least, just slow down and think through what you're trying to do, use common sense.
    Tim Jones likes this.
  12. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi Cnc97,
    Thanks for your feedback.
    Sure.
  13. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi Mendel Leisk,
    Thanks for your valuable suggestions. While cleaning TB, My car was off, coolant line were attached, instead of pushing the Throttle plate, I just loose it from the IM, and cleaned from the front and back of the plate.
    Thanks again.
  14. Mendel Leisk
    38,253
    That's the way to go.
    7 foot pounds (torque for the throttle body hold-down bolts) is pretty low, best to use a 3/8" or 1/4" torque wrench. And go in a criss-cross pattern, a couple of tightening stages.0
    If you don't have a torque wrench, I'd just one-hand a ratchet wrench, like a screw driver, tighten semi-firmly. They're small bolts, and you're snugging the throttle body up against a compressible gasket.
  15. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi Mendel Leisk,
    Thanks for the suggestions. Yes, I tightened it using crisscross pattern but without torque wrench. (as I don't torque wrench below 10 Ft. lb).
    Thanks
