Throttle Body Spacer
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jun 16, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    I know there may be some different opinions on a throttle body spacer.
    However I will give it a try and test it out versus just assuming what it can and will do without actually having one or a prius to test it with.
    This is a 12mm spacer and I will be installing it once I get my latest purchase.
    A Big Bore Throttle Body 20240615_220214.jpeg 20240615_220221.jpeg 20240615_220409.jpeg
    Burna J likes this.
  2. Mendel Leisk
    42,369
    ^ The circled bit, which connects to the air filter box, will move up 12mm; not sure of the ramifications, singificant or not.
    That aside, I googled, and the consensus was if it does anything it's pretty darn subtle.
  3. AzusaPrius
    2,258
    952
    I do not have the stock air filter.
    I am using a Blitz warm air intake.
    This sits lower than the stock intake.
    All should be good with the TB spacer.
    Your concern is valid to those who use a stock intake though and thank you for your input. 20240616_101348.jpeg
  4. darknd666
    darknd666 Junior Member
    177
    24
    Jacksonville, NC
    Does this have any efficiency gains? If so where may I get one?
