1. Ben Pidder
    Ben Pidder Junior Member
    netherlands
    Active
    Hi All,
    This morning our Prius 2 from 2005 (400k km) developed a sort of car cough. It is a repeating ticking sound which originates in the cabin, it is not noticeable from outside, nor with hood open. It continues while the car is activated. It is there when stationary without the motor running.
    It seems as if a something plastic is trying to move something else in a mechanical way, maybe a lever operated by a motor, but fails to and repeats and repeats.
    The sound is kind of familiar, I am quite sure I have heard it before, but i think its is then combined with a whirring noise and the ticks is only a couple of times. Could be that this normally happens only after the car is shut down, but I am not sure about that.
    Any suggestions what this could be? I would think something with the climate control system, but it is still there also with airco off.
    In this thread relays or the brake pressure pump are mentioned: Curious Sound: is this normal?. But what when it does not stop but goes on and on? And how to further diagnose and fix?
    Seems similar to this: ticking sound - new | PriusChat
    I cannot upload audio/video files, here is a pixelfed-link to the video and links to a locally hosted audio file and same sound with video:
    Prius 2 diagnostic issue - Pixelfed
    audio: m4v,177KB: Nextcloud audiofile
    video: mp4, 3.5MB: Nextcloud videofile
    Thanks,
    Ben
    HTML:
    <iframe title="Pixelfed Post Embed" src="https://pixelfed.automat.click/p/Pixeter/877854934272567803/embed?caption=false&likes=false&layout=compact" class="pixelfed__embed" style="max-width: 100%; border: 0" width="400" allowfullscreen="allowfullscreen"></iframe><script async defer src="https://pixelfed.automat.click/embed.js"></script>
    #1 Ben Pidder, Sep 28, 2025 at 5:59 AM
  2. dolj
    dolj Senior Member
    8,343
    4,256
    Wellington, New Zealand
    There are three motors behind the dash that control the fresh air/recirculation mix, the hot and cold air mix, and the vents from where the air will enter the cabin.
    It sounds like one of these motors cannot find its position and keeps seeking.
    If it is one of these motors, then it will have set an air conditioner code in the body ECU. The is a key press sequence using the steering wheel controls that will display the code in the top right on the MFD. You can get the codes by turning the car on while holding the AUTO and FRESH/RECIRC buttons. If you get any codes (other than 21), you can report them here for further assistance.
  3. ChapmanF
    17,757
    In my experience, hunting of the HVAC servos can take place without always incurring trouble codes.
    What generally happens is the position sensor on the servo, because its contacts are dirty/oxidized, sends a fluctuating signal back to the controlling ECU. So the ECU thinks the door has moved from its target position, and controls the motor to move it "back". Which of course changes the position signal again, and the ECU controls the motor to move it "back". And so on.
    The ECU doesn't necessarily notice this is a problem and set a trouble code. It has codes for if the position sense signal goes outside the range of normal, and codes for if the motor is being powered and the position reading isn't changing at all. But if all the ECU thinks is happening is it's correcting the position in response to the position changing, well, that's what it's built to do, so doesn't necessarily raise a code.
    Here's the thread about it, with a video:
    No, that wasn't a mouse in the heater | PriusChat
  4. Ben Pidder
    netherlands
    Active
    Many thanks! Gonna check the codes to see if anything shows.
    Wouldn't be surprised that an oxidized or bad contact is causing this given age and climate, had the same with 12V battery.
    Is the servo of the mouse-thread the one controlling the motors as mentioned for the air/recirculation system?
