Tight idler pulley bolt
Discussion in 'Gen 2 Prius Technical Discussion' started by Conrad, Feb 13, 2013.
  1. Conrad
    Conrad Junior Member
    23
    Santa Clarita, CA
    The bolt thru my idler pulley is so tight that I'm afraid I will break it trying to loosen it.
    Is that bolt a left hand thread by any chance? Thanks a bunch, conrad
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Is this the bolt that goes through the center of the idler pulley or the long brass tensioner bolt?
    If the center bolt it may be reverse so normal rotation does not unscrew it. Not at home and can't get to files.
  3. Patrick Wong
    18,210
    6,515
    No, it is not left hand thread. Use a cheater bar if necessary to provide sufficient torque. Tightening torque is 30 ft.-lb.
  4. Conrad
    23
    Santa Clarita, CA
    Thanks a bunch was very informative. I'll try it tomorrow.
