tik tik sound while braking
Discussion in 'Gen 4 Prius Technical Discussion' started by Asifpop, Oct 17, 2017.
  1. Asifpop
    Asifpop Junior Member
    New jeraey
    Four Touring
    hi
    I feel tik tik sound from front brakes mainly from left side when the car is at slow speed and you push the brakes lightly there is tik tik sound and it slows down with slowing down rotation of tire it happens more when brakes are applied while car is turning right
    I showed this to dealer the service guy says its normal.. while i dont believe its normal.. anyone experienced this?
    52,803
    maybe a pebble caught in the disc/pad?
  3. hill
    9,018
    Even something caught in the tire Treads could make that sound happen. Then again - warped rotors do it too. If it's not something glaringly obvious, best to have the tech look at it.
    #3 hill, Oct 17, 2017
    kithmo likes this.
    52,803
    or a time bomb...
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oops! That's a keyword!!! :censored:
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Does your model have hub caps ?
    If you actually hear this and not "feel" it, then it is often caused by a loose rock inside a hubcap......or similar.
    As mentioned, it could be a rock in the tire tread too........or a nail or other hazzard stuck into the tire.
    kithmo and RCO like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I would think the foreign object in the tyre would make a note at all speeds.
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    Well of course it does but as speed increases, other noises tend to cover it up.
    And one more thought: Sometimes the ticking noise is the hubcap itself flexing because it isn't solidly in place.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Your C must be much noisier than my hatchback.
  10. hill
    9,018
    It gets easier & easier to hear noises that used to get masked by many other driving sounds. The Continental Tires on obe if our current car has a foam liner attached to the inside because the car is so quiet the tire noise is more noticeable. Ergo they use foam to muffle even the normal sounds of tires traveling down the freeway.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Could be a cracked rotor.
    Mendel Leisk and RCO like this.
  12. Mendel Leisk
    42,296
    If the tik-tik is only there when you're braking, not there when you're just coasting, I don't think it would be pebble in tread.
    RCO likes this.
  13. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    RCO likes this.
  14. GreenJuice
    195
    127
    London, UK
    Just realised Asifpop has already found it.
    RCO likes this.
  15. Asifpop
    New jeraey
    Four Touring
    Thanks the issue is fixed
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    So what was it ?
  17. orenji
    orenji Senior Member
    5,887
    3,488
    Lots of Gen 3 do this too. It seems to be a common sound.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sounds like a bad case of:--
    .. we don't know what it is, so it's perfectly normal. Ok?
  19. Asifpop
    New jeraey
    Four Touring
    They replaced the front left axle and there is no more sound
    RCO likes this.
  20. padroo
    padroo Senior Member
    2,763
    2,253
    I was thinking CV joint.
