Tilt sensor
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Feb 21, 2019.
  1. ChapmanF
    19,073
    Weird ... I had never heard of that thingy. It seems different from this thingy.
    It seems there was the RS3200+ thingy that detects glass breakage (but not impact?), or this thingy to detect impact (but not glass breakage?) ... did either one detect tilt?
    Also, I see that the RS3200+ thingy says "Do not install on ZVW30L-AHXGBA" ... just my model. :( Anybody know why?
    (Edit: I see now this is in Gen 2's forum, where the RS3200+ I linked to was for Gen 3. Only just not my Gen 3.)
  2. Victorio Mo
    Victorio Mo Member
    147
    36
    Folsom, California
    Hi guys, the ONLY installation is needed is to connect extra wire to door plunger. This is your extra signal line. This is 6$ project which works on factory alarm. Good addition to your 250K Miles G2.
    To access wire, fold your chair, and pry open that fabric/plywood cover to get enough opening, cut open wide sleeve to expose wire and splice into it.
    No need even to remove plunger (Torx 30).
    I tested it OK: once connected new wire to the ground = like open door then alarm is triggered. (doesn't matter door knob touched or not). Plunger connects single wire to the Ground. I don't care where it goes, wire is thin be careful. Plunger switch is NO = Normally Open ( assume Normal = door closed, when door is closed Plunger is pressed IN, no ground to signal wire). There is no any fancy electronic /brains involved.
    I Plan to splice this line into left and right side for 100% result and connect with simple mechanical ball or mercury sensor or $300 powered brain unit with GPS and callback). Simple tilts usually listed as NC, but for not rocket science application could be reversed. If it won't be sensitive enough then you can install relay.
    I have now wire in trunk. Will play what position to find which is better, I think might be somewhere in the center.
    #22 Victorio Mo, May 9, 2020
  3. richard203
    richard203 Member
    292
    61
    SF
  4. Victorio Mo
    Victorio Mo Member
    147
    36
    Folsom, California
    Today I hacked into neighbor's Gen 3, did same thing, easy too.
    Picture I posted on prev post should explain how it works very clear.
    #24 Victorio Mo, May 10, 2020
    SFO likes this.
  5. richard203
    richard203 Member
    292
    61
    SF
    do you have a link to where you brought ur tilt sensor?
  6. Victorio Mo
    Victorio Mo Member
    147
    36
    Folsom, California
    you can put you sensor in any location you want , doesn't matter. Mine are in the trunk from both sides on floor level.
  7. richard203
    richard203 Member
    292
    61
    SF
    Oh I’m trying to figure out how to wire the 507m tilt sensor I just need to figure out where to tap the trigger wire
  8. richard203
    richard203 Member
    292
    61
    SF
    i was wondering do our gen2 prius have factory alarm? i tried locking the car and open it from the iniside the car didnt go on panic mode. i tried the panic button it works.
  9. The Lizard King
    89
    56
    Mine does.
    Do an experiment. Roll your windows down. Lock your Prius. Put the key fob in the house -- away from your Prius. Go back out to the car and unlock it from the inside by putting your arm through the open window. Report back your findings.
  10. richard203
    richard203 Member
    292
    61
    SF
    thats wat i did i rolled down the window and stck my hand inside to open the door and nothing happen but my key is on me but i dont thnk the key matter since most of my test i have the key next to me too and they worked.
  11. richard203
    richard203 Member
    292
    61
    SF
    oky so i can confirm there is a option on the techstream to enable the factory alarm. now my questioin is when i use keyless entry the alarm goes off. do any1 have that problem?
    SFO likes this.
  12. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    Nope, what you report is not the correct behavior.
  13. richard203
    richard203 Member
    292
    61
    SF
    alright so i took a look at the bottom under the steerng colum and see some devce going up to the driver vent and unhooked the plug for them and the alarm works like a charm. I guess it got some after market alarm installed. Now that my alarm is working as it should I am letting a shop install a tilt sensor next week. I will take a lot of picture so every 1 can copy what the shop did to install the tilt sensor and what tilt sensor they use so they dont need to pay a shop to install.
    SFO likes this.
  14. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Looking forward to your pictures and postings (y)
  15. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Hoping the installation was painless and well documented.
  16. richard203
    richard203 Member
    292
    61
    SF
    i dropped off on thursday but the guy say the tilt sensor got delayed because of the virus which i understand and might come on fri or sat the latest. so today is fri and still no call back yet so i might be getting it tomorrow hopefully. we will see.
    SFO likes this.
  17. richard203
    richard203 Member
    292
    61
    SF
    so i picked my car up and everything lighted up on the dash. went back and the guy was like the relay he put in, he have to redo them and add diod to all the connector. after driving home and getting dark i turn on my headlight but my foglight dont work no work so i will be takng it back to the shop again. from what i heard he using the door plunger wire to tigger the alarm. he triied to wire it on the driver side plunger but i think something is wrong with the driver plunger which giving false alarm and keep tiggering the alarm so he switched to the passenger side and fixed that problem.
    SFO likes this.
  18. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Additional updates, parts list, or photos of the installation?
  19. richard203
    richard203 Member
    292
    61
    SF
    i have to go back this week to let them fix again i tired to jack up the car and see if it activate the alarm nothing happen. i guess when they put the diode they didnt try it and the diode screwed up the tilt sensor somehow. i just know that this installation for this shop is no good. i wasted so much time dealing with them. for the price paid to get this install and they say they install a lot on this type of car its all bs.
    SFO likes this.
  20. AlexY
    AlexY Member
    163
    45
    UK
    Old post but this is important: upload_2020-9-13_18-15-9.png
    So there should be 3 horns in gen 2 prius, there is no way to reach cables of security one without opening the hood.
    SFO likes this.
