Time Change
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 2, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Now that I think of it, I remember being totally shocked when I discovered there were two separate clocks. I remember thinking, "Well, that's stupid!"
    Mark57 likes this.
  2. Mendel Leisk
    42,249
    I think of that, every time we enter the west end of the Barnett Highway on a rainy night, windshield starting to fog up, and I'm TRYING to get the ventilation system into heat/defog mode. First I've got to take my eyes off the (dark and twisty) road to find the "mode" button (it's flush, one in a row of uniform buttons), then push it repeatedly while glancing down after every push, a t a small LCD display, to see if I've arrived at "heat/defog" yet. Overshoot, and I get to go around again:
    Might go with this, next time around:
    If Honda hasn't gotten "clever", ditched it for something more "up to date", or a touch screen. Note too, the additional mode: all the air to the windshield.
    #42 Mendel Leisk, Nov 8, 2019
    jerrymildred likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Or you can just leave it AUTO all the time like I did on my Gen3 and now in PRIME. It takes care of almost all of my HVAC need without fiddling with switches. However, I found out doing this cost quite bit of EV efficiency on PRIME.
  4. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    Yeah, it's a BIG hit in an electric car. I prefer to have the setting of some fan forced air over the windshield to prevent fogging. Of course in modern cars you literally can't do that. It will turn on the AC if you like it or not. The Honda example above is shockingly simple to use and similar designs were used by Japanese automakers for many years. You don't need to look at it after the first couple of times. The new designs are not better they are just different to be different.
  5. Mendel Leisk
    42,249
    Yup: indents at each setting on the dial and the pure windshield one is at the right end of the dial.
    I neglected to mention, it's a Honda Fit.
  6. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Yeah, the natural reaction would be to think the disconnect is stupid, but what would be stupid-er would be paying several hundred (or thousand?) dollars more for Toyota to engineer the integration between them, for something that is so inconsequential. Ever design cue, screw and nut on the car has a cost, unfortunately. So, in that sense, it is a very logical and responsible design aspect. In my opinion. (y)
  7. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    So I finally dug through the settings to find the clock and change it. That was way more convoluted than it needed to be.
    huskers and Mendel Leisk like this.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    No, the stupid part is that there is even a "Them" in the first place. There should be one clock. One car, one clock. It could have a dozen displays and different things accessing it if they wanted. Why the heck did they put the money and effort into having two clocks, when it would me so much simpler to just let one clock talk to the whole car?
    Which leads me to a question I've never checked into because it just occurred to me. Since the clock on the dash isn't the same as the one in the large display, if I programmed the charging schedule using one interface and then made a change using the other interface, what time will the new event actually happen?
  9. Mendel Leisk
    42,249
    Doug Demuro notes that the Corolla Hybrid has three (count them) clocks, in his inimitable style.
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    Which clock?
    :eek: YIKES!! :eek:
  11. Salamander_King
    11,024
    8,977
    New England
    Maybe we all want back to this? lol
  12. jerrymildred
    11,517
    14,164
    Tampa, FL
    I still remember car clocks with stems like wrist watches. :LOL: But they cost a WHOLE lot more per mile to drive.
    Salamander_King likes this.
  13. Salamander_King
    11,024
    8,977
    New England
    I miss those wristwatches. I resisted using digital wristwatch for a long time. I liked the simplicity of the operation. But sometime in the last 15 years, I have switched to all digital. My current wristwatch Casio MT-G 900 which I have been using over 10 years now, has an atomic clock receiver built-in. However, I seem to live a bit too far away from wherever the signal is being sent. Thus, I go through a ritual of trying to figure out how to set the time on this watch twice a year. I can never remember series and sequences of buttons to press to get to the time setting function. Once set, it is accurate until next time change. And yeah, it has a solar battery. No need to change a battery. At least I have not yet changed in the last ~10 years.
    #53 Salamander_King, Nov 9, 2019
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    The "DST is On" menu item in the NAV system does NOT mean "DST is used in my area, so switch to and from DST as appropriate based on the date", like it does in computers and phones and pretty much any other device that knows about DST. Instead, it simply means "DST is in effect now", and thus adjust the displayed time forward one hour from the time zone you have specified. Period. So you have to turn it ON in the spring when DST goes into effect, and turn it OFF in the fall when DST goes away.
    Toyo_Tom likes this.
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    Correct. And I might add that that's the only sensible way to manage DST unless the car is getting date and time from the phone that's connected to the car (as it really should). The governments keep changing when or if it starts and ends. The chaos is amazing.
  16. Washingtonian
    Washingtonian Senior Member
    726
    621
    When I pulled into our garage yesterday my wife shamed me by figuring how to change the clock on the Nav system, so I had to get out the book and see how the steering wheel controls worked to change the other one. Both changed now.
  17. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I have the "cheap" version so there is only one that I see. On the dash. The touchscreen doesn't have an obvious clock in the Plus. Not saying there isn't one BTW, just it isn't obvious. on the screen I usually have.
    Well, jeez. It's right there. Just go to the Gears icon by using the left right arrows. Then make sure you aren't driving. Then go up arrow a bunch of times till time is displayed. Then go right to change it. Totally obvious. Bwahaha.
    What happens in Oregon next year when we go to DST year round? Not Standard time, DST.
    #57 Zed Ruhlen, Nov 10, 2019
  18. Salamander_King
    11,024
    8,977
    New England
    Just keep DST ON all the time? That's how I had mine for the last two years but was no problem for me. I never used the Navi estimate arrival time feature.
  19. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Inexplicably, the clock that is of almost zero consequence can be set to be maintained with the precision of atomic clocks. The clock you see and that I assume controls charging schedules, that's controlled by who knows what. At least it doesn't drift like the clock in my PiP.
  20. CharlesH
    2,798
    1,166
    Roseville, CA
    FWIW, the time from the GPS satellites is always UTC, down to some number of nanoseconds. The GPS receiver then applies the appropriate time zone and DST offset for display.
