Time for a new traction battery
Discussion in 'Gen 2 Prius Technical Discussion' started by don_chuwish, Jan 7, 2023.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    If the orange maintenance plug is pulled you get a red triangle and exclamation point and a code I can’t recall. Not sure you’d even get the point of monitoring the pack modules.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,011
    936
    Southern California
    When the plug is out Dr. Prius puts up battery voltages even though the red triangle is lit. Two of the modules look odd, but I don't recall if they were zero voltage, greyed out, or what. Nor do I recall which two modules were affected.
  3. don_chuwish
    823
    190
    Southern Oregon
    Well, an unfortunate update is that after two years of not much use (which is certainly a contributing factor) my NexPower (Project Lithium) LiFePO4 v2 has coughed up a P3000 error, one module showing overcharged.
    How it played out:
    Over the past month we'd been getting the car out for drives every weekend and all seemed well. Then on Saturday it started and ran, but the dash was blank. The SOC on the MID showed full green, then quickly dropped to 2 purple bars. So we let it sit in park recharging for a bit, got back to 3-4 bars before it would even let us turn it off. Then turned it back on and got "Trouble" and check engine light. We could hear popping sounds from the rear and then a strong smell, like nail polish. We shut it down and I came back later to connect OBDII and the Dr. Prius app, confirming the P3000 and module 10 with way higher voltage than the rest.
    I'm still not ready to quit on this car though. After considering options again and reading reviews I've ruled out GreenBean and Hybrid2Go. Checked online for OEM options but they all require a $1350 core that I can't satisfy now. Local dealership wants over $3K for just the pack, plus the $1350 core.
    But when I originally did the NexPower install I'd sent the old cells to 2ndlifebattery.com for a little cash back. So I checked with the owner, Joe Merrill, and he has some options based on OEM Gen4 cells, with 4 or 5 year warranty depending on how they test out. He was great to talk to and I couldn't find anything bad said about the company in my searching. They're also fairly close to me so that's a little reassuring.
    So I've ordered a Gen4 "brick" with the 4 year warranty option and get to look forward to my 3rd traction battery replacement project. Good thing I've been going to the gym consistently!
    bisco and Brian1954 like this.
  4. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Do you have a contact number and link to share. I'm in the same boat....looks like $1800 for refurbished 28 cells with a 4 year warranty. Or $1,800 for new Alibaba. cylindrical cells from China. But new. Not sure how much longer we are going to keep this old 2008. Hmm let me know how the process goes. I'm not worried about install as I've rebuilt these batteries about 4 times now. I'm leaning towards new.
  5. don_chuwish
    823
    190
    Southern Oregon
    Hybrid Car Battery Distributor | Contact Us | 2nd Life Battery
    Joe answers the phone and email himself. He replied to my initial email yesterday (Sunday).
    ColoradoCrow likes this.
  6. bisco
    52,774
    there have been a lot of problems with nexpower, you're lucky you got two years
    xw20_driver likes this.
  7. don_chuwish
    823
    190
    Southern Oregon
    It is unfortunate. Would have been nice to have a viable alternative.
  8. don_chuwish
    823
    190
    Southern Oregon
    To be fair though, it went less than 1000 miles in two years. Probably spent over a month not even started up on several occasions. Now my daughter finally wants it and will be able to drive it more often, so its worth the effort to fix it again.
  9. pasadena_commut
    3,011
    936
    Southern California
    That would be the highest risk option. You have no idea who actually made those sticks and what their real expected lifetime is. I took that gamble with our 2003 Honda Civic Hybrid, mostly because there was no source of new OEM sticks for it, and because it was all checked out first by a battery rebuilder in the US, and lost. It was great when it was new, but it did not last very long.
    ColoradoCrow and don_chuwish like this.
  10. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Good to know...Hm. OK
  11. don_chuwish
    823
    190
    Southern Oregon
    Working with Joe at 2ndlifebattery.com was absolutely fantastic. Twice he called me on a weekend after I'd emailed expecting to hear from him on Monday. The 28 Gen 4 modules he sent were numbered in the order they should be installed. New nickel plated bus bars and nuts included.
    I finally got it all buttoned up yesterday and did some driving and testing with the Dr. Prius app. All looks good and Life Expectancy test came back as over 100%. Today I got on the highway for a few miles and real time MPG looked great.
    The car drives way nicer now too, low end response is lively again. Hoping to make a longer highway drive next weekend of about 150 miles. Will get a better idea of MPG then.
    I also ended up putting in a new 12V. My 5 year old Optima Yellow Top has had a few too many deaths and resurrections to trust it with my daughter on her own. Ended up getting the Walmart EverStart Platinum AGM S46B24R - $100 less than another Yellow Top.
    Have to admit I was dreading tearing everything apart again but once I got started it was kinda fun. Didn't even have any left over nuts or bolts!
    ColoradoCrow, bisco and Brian1954 like this.
  12. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    I think I will be going this route when I have to rebuild. Maybe this fall project.
    don_chuwish likes this.
  13. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    What are you doing with the old Nexcell modules that you pulled? Seems like they would be a recycling nightmare?
  14. bisco
    52,774
    ship them back to jack, with a nice thank you card
    xw20_driver and Brian1954 like this.
  15. pasadena_commut
    3,011
    936
    Southern California
    The local e-waste collection site/event will probably take them. I have disposed of several laptop lithium batteries that way. The one we usually go to has a weight limit for the trip for all items of something like 125 pounds. That's because it is supposed to be for household waste, not industrial waste. I don't think they actually enforce it though, but like to have it "on the books" in case a person shows up with 500 pounds of car batteries in the back of their pickup, or something like that.
  16. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    I'll give them away if anybody wants them. I'd rather somebody get some use for them...rather then end up in a landfill.
  17. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    I posted my own hybrid battery story (also defunct NEXcell pack) over here. I went with brand new OEM pack instead. I had originally considered obtaining up-cycled modules from 2nd Life before discovering the old pack in the car was not an original pack but had been previously modified with the experimental lithium battery. Unfortunately there was no way of knowing when buying a used Prius what battery could be hidden in the back.
  18. pasadena_commut
    3,011
    936
    Southern California
    That's not entirely true, at least if buying it in person. For starters you can always ask the seller, who hopefully still has the paperwork if the battery was changed during their watch. Also, it isn't hard, and no tools are needed, to pull out the rear deck cover and look over at the battery pack. I put this in the "looking under the hood" level of inspection, and if the seller won't allow it, walk away. If the pack is painted then you know it wasn't the OEM battery the car came with. It is at least a refurb. Dorman paints its name on the sides, some others may too.
    If it is the standard unpainted metal though, and doesn't bear any identifying marks on the visible part, then short of taking it apart in the car, there is indeed no way to know what is going on inside.
  19. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Very true. First time owning any Prius and about the only thing ai knew walking into a private sale was about testing the hv battery using Dr Prius at the time. The seller was either very unknowledgeable or dodgey enough to hide their knowledge at the time. It even fooled me initial pass when I had the rear deck opened months ago before the RTOD to clean the cooling fan that I assumed the HV battery was stock based on the top cover.
  20. don_chuwish
    823
    190
    Southern Oregon
    Haven't decided. Probably get them recycled somewhere. But there is the option of converting them to 12V and creating a UPS. I even have most of what I need. Just not sure I have the appetite to do it.
